Question about Nikon COOLPIX S5 Digital Camera
When I turn on my camera and its in shooting mode
When I turn on my camera and its in shooting mode - i have a red hand flashing, there is a 'ticking' sound as though the lense is trying to ocus on a shot and any picture i take on this setting is blurred. How do I get rid of the red hand?
  • cvsdesign Mar 15, 2009
    I just posted this same problem with my Nikon CoolPix S5. The tip to work on the focus did squat though. Sorry. It is driving me crazy as to why this is happening.
    this tip did not help me with the same problem as "weardrobe" - thanks anyways.
  • 11,896 Answers
In your menu settings, there should be a setting for auto-focus or focus notifications.
All cameras have this setting, but you can google it and find one for free download.
Posted on Mar 09, 2009
How do you turn o and off flash
Your camera has 4 modes flash function : 1; Flash Off ( flash will Off in any shoot) 2. Flash Fill in ( flash always On) 3. Auto Flash (Camera decided flash) 4. Red Eye reduction flash ( Camera decide flash).
You can set your flash base on your need.
Nov 29, 2010 | Polaroid i531 Digital Camera
How do I disable the flash on my camera?
Look at the thumb pad on the back of your camera (see picture below, courtesy of www.cameras.co.uk). The uppermost part of it acts not only as an up key in the menu selections, but in shooting modes controls the flash (as per the lightning symbol next to it). With the camera turned on and in automatic mode (the green camera icon on the mode selector dial) just press the flash button and look at the screen. Eventually you'll get an icon of a lightning flash behind a red circle with a bar across it, this disables the flash.
Note that if you have any of the other shooting modes selected then the flash may still operate as in those modes everything is pre-selected by the camera with no or few override options.
I hope this fixes your problem, please take a moment to rate my free answer.
Sep 30, 2010 | Nikon Coolpix 4600 Digital Camera
My flash isnt working on my A835 camera and i have only had it for 6 months
Check the flash mode that your camera is set to. The flash modes are: Auto, Red-Eye Reduction, Forced Flash, No Flash, Slow Synchro, and Red-Eye plus Slow Synchro. You might have the flash mode set such that your camera detects that the lighting doesn't require the flash mode selected. You can try manually overriding the flash mode by pressing left on the circle function button next to the LCD view screen. If you are still unable to manually turn the flash on, try changing the shooting mode with the mode select dial on top of the camera, then if necessary repeat the flash override step mentioned above. Repeat until successful. There is also the possibility that the flash is malfunctioning, but that is less likely than a setting issue. Let me know how you make out.
Jan 02, 2010 | General Electric A835 Digital Camera
Pictures that I take come out very white/bright. you cannot tell details. I have changed batteries and have the setting on auto.
Double-check your flash settings. You mentioned the camera is in Auto mode, but the flash has separate settings from the camera's shooting mode. With the camera in shooting mode AUTO check the Flash settings (Auto, Red-Eye Reduction, Fill-In, Off) It may be set to 'fill' causing your photos to be too bright.
Also, depending on how close you are to your subject the flash may not be needed. Using the flash when too close to your subject (less then 3 ft.) will cause bright/white photos. Turn the flash OFF if you are taking macro or photos closer then 3ft.
If neither of these fix your problem, turn the flash mode OFF, and camera shooting mode to AUTO and in a naturally well lit area, take a photo, if the photo is still too bright, you may have something mechanically wrong with your camera.
Nov 03, 2009 | Olympus FE-210 Digital Camera
Shooting in low light with a canon rebel xt
Hello parr_alp,
Please keep in mind that when shooting in low light, you will ALWAYS get some amount of blur when you are hand holding the camera unless you use a flash. The only way to increase your shutter speed is to crank up your ISO setting to 800, 1200, 1600, etc. If there is no tripod handy, brace yourself against a stationary object and remember to keep your elbows tucked down near your body when shooting (no sense in holding up your arms, too).
There is no way to increase the ISO limits of your camera while maintaining quality of your images. And once again, you will ALWAYS get a certain amount of blur when hand holding the camera.
The external flash not firing is an entirely separate issue. This could have to do with your metering, a bad flash, bad connection in the hot shoe, what shooting mode you're in — the possibilities are numerous. The next time your flash doesn't work, write down all the settings of your camera and keep track of them (i.e. shooting mode, metering mode, flash settings, current lighting situations, etc.) You may start to notice a pattern and perhaps we can help you here.
Anyway, happy shooting, and if this response was helpful, please rate it! Thank you!
Jeff
Mar 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Flashing icon
Low shutter speed icon means that when you take photo the image will be blurry if camera moved.
Is there this icon when flashlight is turned on?
Feb 13, 2008 | Nikon COOLPIX S6 Digital Camera
Settings that must be set before... the external flash feature
Yes, set the camera mode dial to P, A/S/M or any shooting mode except the movie mode. Turn on the extension flash unit's power then select the camera's flash mode. The flash mode button on the camera controls the built-in flash as well as the extension flash. Only the built-in flash and the Olympus FL-20/FL-40/FL-50 extension flash can use the red-eye reduction flash mode. All flash units can use the fill flash, flash off, and slow-sync flash modes.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Any settings that must be set before you can use the external flash feature
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Settings that must be set before you can use the external flash
Yes, set the camera mode dial to P, A/S/M or any shooting mode except the movie mode. Turn on the extension flash unit's power then select the camera's flash mode. The flash mode button on the camera controls the built-in flash as well as the extension flash. Only the built- in flash and the Olympus FL-20/FL-40 extension flash can use the red-eye reduction flash mode. All flash units can use the fill flash, flash off, and slow-sync flash modes.
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Are there any settings on the camera that must be set before you can use the external flash feature?
Yes, set the camera mode dial to P, A/S/M or any shooting mode except the movie mode. Turn on the extension flash unit's power then select the camera's flash mode. The flash mode button on the camera controls the built-in flash as well as the extension flash. Only the built-in flash and the Olympus FL-40 extension flash can use the red-eye reduction flash mode. All flash units can use the fill flash, flash off, and slow-sync flash modes.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
Nikon COOLPIX S5 Digital Camera Logo
124 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
