Question about Dell Dimension 4300 PC Desktop
Im trying to add memory to my dell dim, 4300 desktop!!
Hello all !! please help im trying to add memory to my dell dim,4300 desktop,but when i adding card a and b lights up amber on the th back of pc along with annoying beeps.i tried a couple diffrent ways but still same beeping and lights.i had 256mb memory installed,and trying to install 2 samsung pc133r-333-542-b2 cards that were purchased from ebay,but im wondering if they are bad modules or wrong all together for my system.any help will be great! thanks in advance
  • brandyjames2 Mar 10, 2009
    thanks for ue help,but im still lost as to what to do to try what you have suggested.any other help would be great.thanks again brandy
    President:
  • 1,073 Answers
Hmmm...im not sure that u need a bios update. If the bios cant recognize them it should show the size of your old stick. I think by the descripstion you giving here, that the sticks you bough are bad, you can either take them to a pc-store and have them tested or download a program called MEMTEST and run and test them yourself.
My guess is that you bought bad sticks M8
Good luck
Nic
Posted on Mar 10, 2009
  • Nicolas
    Nicolas Mar 10, 2009
    Hi again!
    I will try to explain to you how to do the test then:)
    Download this memtest program:
    Download - Pre-Compiled Memtest86 v3.4a installable from Windows and DOS
    Its free
    After the downloading, burn it on a cd
    Then boot up you pc whit the cd in, your pc will now start testing the memosticks insteed of booting up your OS.
    If the test shows any failiure, even if it is ONE, then the sticks is bad.
    Now, take out one of the two new sticks, replace ot whit the old one you had, that one you know is working good. If you ant given any errors then you kno that the stick you tok out is the bad one, if you ger an error, take out the new one and out in the other new one and run the test again. If you get errors again then you know that both of your new sticks is bad.
    Every test takes about 15minits to run.
    Good luck
    Nic
    President:
  • 2,653 Answers
That should work without any problems since the chips are 256. You can either try a bios update or clearing the cmos before trying to boot.
Let me know what happens after you try the above.
Posted on Mar 09, 2009
  • RescueTechLA
    RescueTechLA Mar 10, 2009
    Brandy,
    Go to Dell's support site HERE.
    Basically you'll need to download the above bios file, insert a floppy into the computer, and then follow the prompts.
    Let me know if you have trouble following any of the above.
I have a Dell Dimenion 4300, that is in good condition, but I want to add a USB Port 2.0. I am unable to open the cover. I have the computer lying on the side with area pointing up. When I press the...
I have the same PC and mine opens easily. Is it laying on the right hand side? Is there anything holding it on the back where you can fit a padlock? Maybe 1 of the clips is broken you may have to force it but dont blame me please. Good luck cheers from Scott
Oct 30, 2010 | Dell Dimension 4300 PC Desktop
I need to buy and install and ethernet card for my
Ok - try this site for a great card
www.tigerdirect.com
Apr 16, 2010 | Dell Dimension 4300 PC Desktop
I am getting ready to intall additional Rambus memory to my Dell Dimension 8200 and need walked through it... Any help?
Hello d_silverthor,
Here's a video link shoing how to install memory in a Dell Computer:
http://www.memorystock.com/memory/viewvideo.asp?systemtype=Dell+Desktop&Class=Desktop
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 07, 2010 | Dell Dimension 8200 PC Desktop
Dvd/cd rom
It is your dvd drive lense issue .If your computer is in warrenty take it to service shop they replaced dvd drive or lense.
If it is not in warrenty you need to repalce or repair dvd drive lense.
Also you can try 1 more thing pur chase disk cleaner disk and put it in dvd drive then play then it clean dust from dvd drive then check .
Aug 01, 2009 | Dell Dimension 4300 PC Desktop
Motherboard
sometimes dell has a program that can check your hardware for errors. check all the disks they sent you. It won't be on the name of the disk but it should be on one of them. good luck.
Jan 24, 2009 | Dell Dimension 4300 PC Desktop
Steps to add new hard drive to my dell dimension 2300
YOu can refer to this site..they are all the same procedure in adding hard drive in a computer.
http://www.infohq.com/Computer/adding-second-hard-drive-review.htm
melnavz
Nov 10, 2008 | Dell Dimension 2300 PC Desktop
Memory Wrire Read error please please please help.
well sir/mam ...........................as there are 3 beeps heard when u insert da ram in the slot...it seems that u'r ram is not working ......and there is a need that u change the ram immediately without tryin da same procedure again ..............this wud surely help u get out oft this problem .
Sep 07, 2008 | Dell Dimension 4300 PC Desktop
Acer Aspire T-180 Memory Upgrade question
Hello, You might be able to add 2GB more. 1GB per slot. You need to get the model # off your motherboard and verify what the maximum amount of memory it will support. 1GB per slot would be 4GB total but some Operating systems will only support 3GB. So some might be wasted if that is the case. You would need to use the same memory type. So if existing is PC2-4300, use the same. Hope this helps.
Mar 05, 2008 | Acer Aspire™ T180 PC Desktop
Dell Dimension 4300 PC Desktop Logo
152 people viewed this question
Alun Cox
