Xeroxhttps://www.support.xerox.com > en-us > article
Jan 19, 2021 - Resolve the Duplicate IP Address Conflict With Another Device on the Network. Manually Set a Static (Permanent) IP Address on the Embedded ...
Copytechnethttps://www.copytechnet.com > ... > Xerox
Aug 30, 2014 - This error code means your bustled Fiery or Creo network controller do not communicate with the machine. Check all cable from net controller to ...
Printcopy.infohttps://printcopy.info > code=027-452
Code: 027-452; Description: IPv4 Duplicate Duplicate IPv4 addresses detected upon startup. Causes: Remedy: 1 At the printer's Control Panel, press the Menu ...
Reinstall the printer. It sounds like there is a duplicate IP address problem. The other option is to set the IP address for the printer as fixed not via dhcp.
it is possible that your router gave out a duplicate ip address or that your using a static address and the router is giving the ip address you are using to another computer. please check that your computer is setup to DHCP or that the other device/laptop/pc is set to dhcp or obtain dynamic ip address.
Press and hold the up arrow. Configure Phone - Yes network parameters - yes press no until you see "change" and press yes. You will need to set the following appropriately. IP address, Subnet address, default gateway, ICP controller address, TFTP address, VLAN ID, VLAN priority, DiffServe Value, DNS address.
Normally it is not necessary to set the phone static except for testing. If your network and DHCP server is set up properly, you are not gaining any benefit for setting it static.
Also, you should find out what the other IP addressess are that are static on the Voice subnet. Along with that, you will need to know the DHCP range. These are needed so you don't assign a duplicate IP address to your network. Assign the phone to the wrong device could do great harm to your network. Assign it to use the same IP address as the phone system and none of your phones will operate.
Go to Control Panel, then Network Options. Right click the "Local Area Connection" and click properties. Double click the TCP/IP and once that opens you can specify a different IP address manually for that pc which is different from the one your currently being assigned. If you need to see what address your currently pulling, when in the Network Options, Right click the Local Area Connection and click on Status. Click the Support Tab and then show Details. This will give you the current IP address, the Subnet Mask, the Gateway address and the DNS address(s). When specifying a new IP address, only change the last number to something higher than what it is now. If you currently have 192.168.1.5 for instance, specify a new address that is like 192.168.1.16. For the rest of the info, make it the same as what you saw under details. once you do that and hit OK a couple times, it will change it and resolve the IP address conflict for good. :)
check ipconfig if ur ip adress is correct
configure Ip address statically but then be carefull that u dont duplicate another Ipadress already on network
make sure gateway ip adress is correct as well as dns server ip adress
try to add urself to the domain
check if your pc name is correct
On the phone, press the menu button, then status, then IP status or whatever and get the phone's IP address. Write the ip address down. On your computer, open up a web browser and input the phone's IP address into the address bar and press enter. This should arrive you at the web gui for that phone. It'll probably ask you for login credentials; by default, the name is "Polycom" (yes , it is case-sensetive) and the password is 456. Once you are logged in, you should see several links like "General" "Network" "Sip" and "Lines". click on Lines. under "line 1", you will see the configuration for that line. simply duplicate the entries for lines 2, 3, and 4.
On the basic setup page, under Network Setup>Network Address
Capture(lefemenu.dhcpserverset)Server Settings (DHCP), I changed the Starting IP Address from 192.168.1.100 to 192.168.1.110 and amazingly it worked.
There are several private address ranges that may be affecting the operations you are attempting to perform see table
IP Address Ranges Reserved for Private Use
Class
Networks
A
10.0.0.0 through 10.255.255.255
B
172.16.0.0 through 172.31.0.0
C
192.168.0.0 through 192.168.255.0 All addresses in this range in your network are only directly addressable to machines within your network at most by default. The router to your ISP and the internet as a whole maps these addresses onto the IP address assigned statically or dynamically by your ISP to the WAN side of your router using an address translation (NAT) service. So where you are attempting to connect to this device from may be significant. You may need to review your setup guide to see if it references router configuration requirements to support access to the Web_xpander port from devices not attached to your internal network. If you have multiple internal networks (address ranges and not devices) this could also be an issue.
Secondly -- does the Setup software for the device tell you the IP address assuming it is dynamically assigned. Otherwise how would you know what the address is. Static assignment could resolve that issue however you must understand your network to assign your own address. Given a theoretical network where the router gateway is 192.169.0.1 and the network mask is 255.255.255.0 the valid network addresses are 192.168.1.0 - 192.168.1.255. A router or other device supporting DHCP address assignment reserves another range such as 192.168.0.100 for 50 leases (ending at 192.168.0.149) for dynamic assignment to requesting network adapters. Ignoring the 0 and 255 address this leaves open to the network administrator (you in your home) the possibility of assigning static IP address in the ranges of say 192.168.0.2 - 192.168.0.99 and 192.168.0.150 - 192.168.0.254 or so. You as well as the DHCP server are required to assure that there are no duplicate IP addresses assigned on your network. So statically assigning 192.168.0.100 (which is DHCP assignable in our case) could and would most likely result in duplicate addressing and network problems.
You will first need to find the DNS setting which is probably 255.255.255.0 and IP address of your router, which is probably 192.168.2.1.
Check your computers ip addresses which will be the next number up eg 192.168.2.2.
You then need to go into the psp manual connection set up and use 192.168.2.5 as the psp ip address to be on the safe side and not duplicate an address.
Set the dns primary and secondary server addresses as 255.255.255.0 and set the gateway address as 192.168.2.1( if that is your routers address, as the gateway is your router)
