Question about Samsung TX-R3080WH 30" TV
I bought my Samsung TX R3080WH, 30 inch tv in Sept of 2005. I thought it would be too early for any problems with it, but after being shut off for 3 days, the picture became distorted and concave at the sides and what really scared me is that when I was standing near my entertainment center, I heard a loud pop and there was smoke coming out from one of the shelves. As a precautionary measaure, Comcast was called and exchanged the DVR but they did not smell smoke from the DVR unit an suggested it had to be the tv. Any ideas on what my problem is? Many thanks, millsstar-1
  • millsstar2 Mar 10, 2009
    How do you test a power supply?
    I thank you. Just need to know how do you test a power supply, as commented?
    Sergeant:
    Novelist:
  • 277 Answers
Yes its the problem of capacitors and ic on the main board got overheated and blown out.they just needs checking with multimeter to locate the exact faulty componenrt.and do not on the tv till it get repaired to avoid more and more damage.its worth getting it repaired. thamks.
Posted on Mar 09, 2009
  • 523 Answers
Change the fuser could be the dust destroy it.
  • 4,234 Answers
Most likely a capacitor has failed in the pincushion circuit. This should be a simple repair for any shop. Expect a parts cost in the $10 range.
Dan
  • 11,896 Answers
Sounds like the capacitors in your power supply had burnt out causing to high of a voltage which can cause a threat to other system boards and components. You will need to have your power supply tested firstly.
When i turn the T.V on it turns right back off
The capacitors on the power board have most likely blown
Simply re solder new caps in place of the ones that have buldged on top
If you have soldering iron and skills you can do it yourself
The parts will only cost you about £2
a TV shop will charge you £80
Apr 05, 2011 | Samsung TX-R3080WH 30" TV
Buzzing sound after warm-up won't go away even if muted??
This problems are comming from the power supply board it iself.That the board,where the power a/c cord plug into it.Tries putting in supper glues all over the those big tranformers on the power supply board to cover up those gaps for exscapping high pitch current humming.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jan 27, 2011 | Samsung TX-R3080WH 30" TV
Yesterday the picture was clear in in the middle of the tv, but blurry on all the edges. Now it is blurry everywhere
the cables in the backpart of the tv may be bad connected to resolve this problem reconect them again or just check the manuals for help
Jan 26, 2010 | Samsung TX-R3080WH 30" TV
Samsung TX-R3080WH, tv is less than 2 years old and the picture is too dark to see it. some channels, you can "make out" a picture, but for the most part, channels are black. but you can still hear it.
not sure about this model but it sounds like the backlight has gone out. You can call samsung at 1-800-samsung and they may be able to help or give you the # of the nearest service center.
Dec 08, 2009 | Samsung TX-R3080WH 30" TV
My tv txs3082 blink constantli
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
Jul 22, 2009 | Samsung TX-R3080WH 30" TV
Turns off and on with no help from me
are you a technician if so go to the relay circuit and fix that circuit more than likely has bad ic like the eprom .
are leaky transistor also check the power button for lose connection they are tiny little switches now a day
Feb 22, 2009 | Samsung TX-R3080WH 30" TV
No picture
Bad solder connects....needs chassis pull,careful soldering..
not the picture tube.....................T.
Feb 11, 2008 | Samsung TX-R3080WH 30" TV
Dropped TV
Hi craigaloid your problem is the flourecent lamp on that side it could be broken after it fall have a tech look at your tv for repairs.good luck
Apr 26, 2007 | Samsung TX-R3080WH 30" TV
Right 2 inches on edge of screen are darker than the rest of the screen
What is the model of the TV? Samsung DLP TV's start with HLS,HLP,HLW.....
Feb 06, 2007 | Samsung TX-R3080WH 30" TV
Samsung TX-R3080WH 30" TV Logo
70 people viewed this question
Henry  Thomas
Henry Thomas
