Question about Whirlpool 24 in. DP840D Free-standing Dishwasher
How do you remove the bottom kick panal on a not free standing Wh
  • Whirlpool Master
  • 3,361 Answers
Remove the 4 screws holding it to the frame.
Posted on Mar 09, 2009
Bosch classixx
your absolutely right, remove kick panel and check for leak/ water. if there is none you may need to replace the control
Nov 25, 2011 | Bosch 24 in. SGS43C12 Classixx...
F 21 error message. Not completing wash cycle
f 21 slow drain remove front kick panal//clean out pump..if it helped please vote Good luck need more help please ask....
Feb 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F22 error (in any washer setting) will not start, and cannot get door open. What "electrical "problem is this? Also, how do I get my clothes out short of using a crow bar on the front door!
F 22 is door lock error most likely need door lock but check door strike on door..To get clothes out remove lower kick panal reach up inside washer //at the bottom of door latch there is a small round tab pull down on it to release door..while you have the kick panal of there is a tech sheet inside washer try putting in die test/////but I would say door lock..Hope this helped If it did please vote...If you need more help please ask...Good luck
Feb 02, 2011 | Kenmore HE2 Plus Front Load Washer
I have a wirlpool duet shes abou 5 or 6 years old i cant wash she will get about half way throug a wash and statrs beppen and in the window it shows f2 what does F2 mean
F-2 would be slow drain meaning it takes to long to drain over 8 mins///Remove your frount kick panal at bottom of washer//behind that you should see your pump your unit should have a cleanout that you turn counterclockwise to take out//remove it and you will find all kinds of goodies that will slow the flow of water/if there is nothing in there then you will have to test the pump....need more help just ask....good luck
Jan 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher will not fill up with water and i already replaced the water valve
make sure the overfill switch is not stuck open. Under the bell like structure inside tub. Switch is behind kick plate on bottom front.
Oct 29, 2010 | Whirlpool 24 in. DU850SW - Multiple Color...
Hello, I have a whirlpool duet washer, modelwfw9200sq. It is leaking. We had a repair person fix this last year ( just a small rubber tube comes loose) Can you tell me again where this was located on...
Front - bottom. You must remove the front kick panel to view.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 28, 2010 | Whirlpool WFW9200S Front Load Washer
My control panal is locked, I have tried holding the cancel button and I have tried unplugging the washer
Manually unlock the door lock system by removing the lower kick panel. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. Located on the bottom of the door switch/lock unit is a tear drop shaped tab. Gently pull the tab down about a 1/4" or until a click is heard. The door may be opened. Remember to unplug or disconnect power first.
Nov 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Does not drain. makes horrible grinding noise when trying to drain
you probably have something stuck in the pump
it is a very easy repair actually
pull out the machine and unplug it
remove the back panal two screws, and remove thae back panal
you will se the pump on the bottom of the machine with tow hoses and two wires
grab some towels and disconnect the hoses and wires
turn the pum 90 degrees it should pop out
inspect the pump
as well as the sump hose,
that is the hose that goes from the tub to the pump
hope this helps
Oct 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wiring diagram
remove bottom panel ck on back side or possibly taped to a side wall
Sep 19, 2008 | Whirlpool Dryers
Whirlpool 24 in. DP840D Free-standing Dishwasher Logo
75 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
