Question about Precor 9.31 Treadmill
Precor 9.31 treadmill shuts off during workout
Appears to lose all power. I have to turn power switch on
  • Anonymous Apr 09, 2009
    Starts up... during acceleration, abruptly shuts off. Turn on switch and it (usually) works.
  • Anonymous May 08, 2009
    Treadmill works with no load, then when you step on the track it slows down, you hear a lot of noise from the motor brushes, and the power switch trips off (circuit breaker function I guess). 9.33, same motor as the 9.31
5 Suggested Answers
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
  • 43 Answers
SOURCE: healthrider s5001 treadmill stops during workout
check manual for maintance on walking belt lubercation- mtr shutting down to over heating-pulling too many amps to rotate rollers/belt and to move you. Friction problem
Posted on Jan 08, 2010
  • 6 Answers
SOURCE: Precor 9.4 Treadmill Incline Problem
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
  • 15 Answers
SOURCE: My Precor 9.35 treadmill keeps shutting off. At
Is it on an extension cord? Take it off any extension cords and make sure it's on a dedicated 120v circuit. No other items on the circuit. Also, how old is it? Precor made a bunch of the 9.3x series from 2002-2005 with an aluminum tail roller that can cause problems. Check the back roller. Is is silver and non-magnetic? if that's the case, you have an aluminum roller and you need to contact precor. If you're the original owner of the machine, they should warranty the replacement of the parts, if not, you'll have to buy at the very least a running belt and new roller.
Posted on Jun 21, 2010
  • 218 Answers
SOURCE: treadmill shuts off in middle of workout
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend replacing the motor controller,walkbelt,deck and applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
Posted on Aug 10, 2010
Error 27
Precor Error 27, Too Much Drive Motor Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 27
Feb 18, 2014 | Precor 933 Premium Series Treadmill
Precor efx 576i resets everytime user changes direction
Does the lift work? If not, the battery is dead. Replace it.
Feb 17, 2014 | Precor Efx 576i Experience Elliptical...
Error code 1 and 3 on my Precor 9.21s treadmill?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Precor Error Code 03 E03 EEPROM Test Error
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
How to change precor932i lenguage
When start-up prompt "PRESS ENTER TO BEGIN OR PRESS QUICK
START" appears, access the Club Program by sequentially pressing
STOP, SPEED , SPEED , SPEED , RESET, SPEED , SPEED , and
SPEED . (Numbers on the display appear in sequence: 4, 5, 6, 5, 1, 5, 6,
and 5.)
Note: You must sequentially press each key within 4 seconds of each other
or the display reverts back to the start-up prompt.
6. Maximum Speed: Use any or key to designate a speed limit between
1 and 15 mph (1 and 24 kph). The speed you designate limits the speed of
the treadmill. Press ENTER when the desired speed appears.
7. Maximum Workout Time: Use any or key to designate a time limit
between 10 and 240 minutes. The amount of time you choose limits the
length of a person's workout. (This does not include the automatic 5-minute
cool-down period.) Press ENTER to accept the time limit.
Note: Continuous pressure on the arrow key lets you scroll through the
numbers being displayed.
8. Language: Use any or key if you want to change the language. You can
choose between English, German, Spanish, or French. When you change
the language, you affect all the prompts and informational messages that
appear on the display. Select the language being displayed by pressing
ENTER.
9. Custom Courses (C964i only): The course profile appears in the center
display. (If you want to customize course number 2, press ENTER.)
When you enter custom mode, you have the ability to "draw over" an existing
God bless you
Feb 22, 2013 | Precor 932i Treadmill
Precor 9.27 Control Portion Not Turning On
1) Reset the c.breaker from your house
2) See the c.breaker or blown fuse in your treadmill see the block diagram +c. diagram
3) Try again, and proof.
4) Test the main switch from treadmill, and replace if necessary for OPEn, see the diagram how to do it.
God bless you
Jun 10, 2012 | Precor 9.27 Treadmill
On my Precor 956 i the Stop Key prompt appears
There is a micro switch under the red "Stop" button. The switch is stuck and needs to be replaced.
Oct 24, 2010 | Precor 956i Experience Series Treadmill...
Treadmill shuts off in middle of workout
Aug 09, 2010 | Precor 9.31 Treadmill
Key STuck Error
The key pad is not functioning properly thus this error is flashed you will need to replace key pad. Since I don't know where you are then the place to get the part is from precor directly the will ask Model & Serial #s
WORLD HEADQUARTERS20031 142nd Avenue NE
P.O. Box 7202
Woodinville, WA 98072-4002
T: 425-486-9292
T: 800-786-8404
www.precor.com
Jun 30, 2010 | Precor C954i Experience Treadmill
My Precor 9.35 treadmill keeps shutting off. At first I thought this was due to use or it getting overheated. But, today I turned it on several times and it would shut off as I was walking on it. The...
Jun 21, 2010 | Precor 935 Premium Series Treadmill
Precor 9.31 Treadmill Logo
977 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
