Question about Toshiba Satellite A55-S1063 Notebook
I can barely see information on my screen
My screen is almost completely black. I can see just a bit to be able to log on, but then it is hard to find the cursor.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
This is really easy to fix
hold down the FN key (its blue)
then press F7
stop pressing it when the resolution is bright enough
Posted on Mar 09, 2009
Erorr 2000-0146 in hard vostro 1050
source/original from dell community
Welcome to Dell Community.
Let me first appreciate the fact that you have tried the steps yourself to isolate the problem.
Error code: 2000-0146 (DST Log contains previous errors) refers to previous errors in the hard drive which might not really be a hardware failure. In order to confirm this, I recommend you to run a custom test on the Hard drive which takes longer time than the Pre-boot System Assessment which you have already performed on the computer but it will give the accurate result.
Once the Pre-boot System Assessment is completed, the computer will give you an option to "Run the remaining memory test", please select "No". Then the computer will launch the 32-bit Diagnostics from the utility partition (if available).
After the diagnostics is launched, in the main menu, please click on "Custom Test", then select the "Hard drive" and click on "Run Tests". If the test completes without any error then the hard drive is fine and PC Restore can be performed to restore the computer back to the factory condition (which will result in data loss).
Please refer to the following article for more information on running the Dell 32-bit Diagnostics Utility:
If you have any further questions feel free to reply.
Nov 28, 2013 | Dell Computers & Internet
Computer screen barely visibleL
Take it to the shop. Your Motherboard has a problem.
Oct 08, 2013 | Lenovo ThinkStation E20 4222 P G6950 8 GHz...
My lightning got really dark and i can barely see anything,i have to put the frame really up close to see a little not sure why it got like that.need help
LCD screens have a backlight. When the backlight starts to dim it will eventually completely fail, causing the image to be really dark, barely viewable. You will need to replace the LCD screen, or replace the entire unit.
Feb 17, 2011 | Philips 6.5-Inch Digital Photo Frame...
"Computer screen goes completely black,
first check your screen and verify if your monitor is problem. you can use known good monitor to verify.
Second, check your VGA cards. you might want to reinstall VGA cards drivers. If you know the brands you might be able to download your driver here.
Oct 30, 2010 | Computers & Internet
Vista x64 Screen goes black after Logoff or Switch User
I'm not sure this is pertinent, but examine this article and see. Also similar post here, search links here, and FAQ link here.
I'd suggest you post in one of the MS forums, either here or here.or at this link, and you'll be asking in the midst of more vista experts.
Have you gone to the event viewer to see what kind of errors may be logged in connection with this behavior? See here, here, here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 17, 2009 | Microsoft Windows Vista Home Premium with...
Screen went almost completely blank. could barely see the picture.
If this tv is and LCD the black screen is now the answer of a problem in the back light. the problem can be resolved. the worst case scenario is to replace the lamps. is an average repair an estimate could be a good idea.
May 02, 2009 | Televison & Video
Computer problems.
You want to start the laptops in "safe mode" When its up and running, run the anti-virus program and see what comes up.
Mar 07, 2009 | Acer Aspire One Netbook 8.9" Notebook
Screen Black can barely see images when boot up
well seems like the lcd has lost or the video card has an issue easy way to find out is to hook it up to a monitor and if the pitcure comes out fine then its your lcd screen and if it appears the same then its your video card.
Feb 09, 2009 | HP Pavilion dv1000 Notebook
Screen went almost completely dark, can barely see at all.
I had a similar problem with an HP DV2000 notebook computer. Here's the solution for the HP model DV2040TX: Problem identified and FIXED. Not the screen, not the screen power supply. The problem was the micro-switch within the right-hand-side screen hinge. This switch turns off the screen when you close the lid of the notebook - probably to prevent overheating. The switch had failed mechanically (technical term: "fallen to bits"). As a low-cost fix, I have unscrewed the main casing including the screws inside the battery compartment, removed the silver panel covering the speakers, flicked the switch "ON" using a jewellers' screwdriver, and removed the small metal tongue that is operated by a cam on the hinge. Thus, the switch is PERMANENTLY ON. Computer operates normally, shuts down normally using Windows. Just need to be aware not to close the lid without shutting down the computer beforehand. Hope this helps you. All the best, OzKluger
Jan 23, 2009 | HP Pavilion dv2000t Notebook
This is a hardware failure of the LCD back-light or a loose connection which requires partial disassembly to verify. Most likely it will require an LCD replacement. If you have an external monitor you can connect it to the video output so that you can see.
Nov 28, 2008 | HP Pavilion dv4000 Notebook
Toshiba Satellite A55-S1063 Notebook Logo
79 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
