Question about Dynex 19 in. LCD Flat-Panel HDTV
Problems hooking up dvd player to Dynex 22"
I cannot seem to get my dvd player to work with my Dynix tv. I have the cables plugged in, but I keep getting a 'No Signal' message on the screen. Has anyone else had problems. Maybe my dvd player is not compatible?
  • Anonymous Apr 08, 2009
    Same problem!
MY PROBLEM IS THAT WHEN I HOOKED UP MY DVD PLAYER (PANASONIC) THE MOVIES COME OUT IN BLACK AND WHITE. WHY IS THAT. PLEASE ADVISE
Posted on Aug 26, 2009
I had a similar problem hooking up my Xbox, which uses just a box, then lets you use your own cables the rest of the way to the TV. At first I tried cheap thinner cables, and I got no signal. But I had some nice thick gold-plated sheilded AV cables (they're the Red Yellow and White kind, but if you put the same color with the same color they are the same thing, don't waste your money on Monster cables, cause audio signal isn't as picky) and it worked great. So my only suggestion is check the kind of cables your using. Length also makes a difference, if your player is right near your TV don't get cables over 2'.
Posted on Jun 17, 2009
I have a Magnavox 15MF400T/37 LCD TV operating with a cabel connection. As of yesterday it has no functions but when I turn it on I get a message that says Attention No Signal. I have checked the cable...
Some of the newer TV's dont turn on if there is no input signal. Try a DVD player and see if that works. If it does, then the issue is most likely with the cable jack on the TV, which may need to be replaced..
Jul 21, 2008 | Televison & Video
Why is it reading no signal
  • what did you plug the antenna into on the DVD player ?
  • was the cable plugged into the tv and you pulled it out of the tv and put it into the dvd player?
  • What device is reading no signal ?
Aug 31, 2015 | Televison & Video
I am trying to copy VHS to DVD [using quality DVD-RW] but keep getting screen message of NO SIGNAL - Please check connections.
Hi try this set up to check if you're scart set up isn't the problem connect 3 rca lead to the output of the vcr into the input of video recorder then plug 3 more leads from output of video recorder into the TV set you're TV to AV INPUT AND set YOURE VIDEO RECORDER TO THE CORRECT INPUT MODE ...good luck
Aug 03, 2015 | Televison & Video
No signal fromdvd player video 1 (av)
yellow is video and red and white are audio you a get by with one audio. i think you are missing your video cable you can get by with two cables just use the white cable as a yellow and plug it into the yellow dvd plug and tv yellow plug and the red will stay hooked up for sound ( you wont have stereo but it should work)
Aug 05, 2012 | Audio Players & Recorders
The input dvd screen says no signal and the DVD player doesn't seem to have any power.
If it is in warranty return it---parts for the DVD unit are not available--they would have to replace the entire DVD unit inside the set.
Mar 12, 2012 | RCA 32LA30RQD TV
The disc is stuck in the player and the tv screen says it cannot get a signal.
Barbara, your dvd player needs to be either on channel 3 or 4. If you have a local channel 3 or 4 switch it to the one that is not local. Or it could be a video 1,2 or 3. Just keep using the remote in that format and you will find the signal.
Nov 21, 2011 | Cyberhome CH-DVD 300 DVD Player
I have a 32" LCD TV that I can't seem to get any of my DVD players to work on. Keep getting error message "no video signal" but They use to work. help
How do you have your DVD player hooked up to your TV(i.e. composite, s-video, component)? Some DVD payers and TVs have menus to switch inputs and if you somehow switched off the input your players are connected to, you'll get a "no signal" message.  First try hitting the input button on your TV or the Input/connection option in your TV's menu.  If that doesn't work try hooking up the DVD player(s) with the composite Cable(yellow), the component(red,green,blue) and S-Video(black/round) at the same time. If you scroll through your TV's inputs you should get a picture on one of these connections and the TV should display which one. The display will usually be in the corner of the screen.
Apr 27, 2009 | Televison & Video
I get a "no signal" message when using HTMI or Component cables
on the remote, press "progessive" until you get a signal through hdmi to your tv
Jan 13, 2009 | Toshiba SD-K860 DVD Player
Dynex 19 in. LCD Flat-Panel HDTV Logo
826 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
