Question about HP Officejet 6310 All-In-One InkJet Printer
When I copy, send a fax, or scan it turns out HP 6310 all in one
With my HP 6310 all in one, when I copy, send a fax, or scan it turns out solid black
  • sdwalker Mar 10, 2009
    I have tried this, This is a fairly new machine,(6months maybe) the bulb is still working, any other problems it might could be,
  • sdwalker Mar 13, 2009
    Hi, thanks for the help. I ended up calling HP and they are sending me a new one. I tried what they told me for an hr and nothing worked.
  • 45 Answers
This is a hardware issue..connect the printer to the wall outlet..and then try to make a copy..if its still the same then machine should be replaced..reason is scanner blub is gone bad..
Posted on Mar 10, 2009
  • Srekanth Kumaar Mar 13, 2009
    if you have tried connecting the printer to the wall outlet and if its still the same..then you need to perform a full reset on the machine..
    1)unplug the power chord from the back of the printer..
    2)press and hold OK and CANCEL button simultaneously..
    3)while pressing those two buttons plug in the power chord to the back of the printer..
    4)after you plug in the power chord do not release the buttons..keep pressing the buttons till the screen goes blank..
    5)once the screen is blank..release the buttons and then turn on the printer..
    6)once the printer is completely ON..try to make a copy..if its still the same then get the machine replaced..
    please let me know what happens..
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp officejet 6310 all-in-one send fax configure
1. Press Setup on the front panel of the All-in-One.
2. Press 2 to enter in to Print Report.
3. Press 1 to enter in to Fax Confirmation.
4. Press 1 to turn on Fax confirmation
5. Press 2 to enter in to Image on Fax Send Report
6. Press 1 to turn on Image on Fax Send Report
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Black lines when you fax and copy
Open up the document feeder and clean the small scanner glass.
Feb 18, 2009 | HP Officejet 6310 All-In-One InkJet...
6310 has a fine black line down the entire length of the page
Need the clean the pinch rollers on the top of the unit. Use a small amout of alcohol on a piece of paper towel. Clean all the pinch rollers and then let unit sit for about 15 to 30 minutes.
My new 6310 HP won't receive faxes.
Hi
when you installed did you get the fax setup wizard during the installation. If not, you can get it by opening hp solution center-> settings-> fax settings-> fax setup wizard.
You can have the HP solution center icon in the desktop or try with hp Director.
if not you can look at the
hard-copy user guide walks you through all the setup variations, depending on what type of line you have, what components (answering machine, for example), and how you want to handle incoming calls and faxes.
Good Luck
Jan 29, 2009 | HP Officejet 6310 All-In-One InkJet...
HP C6180 prints but won't copy or fax...
i can not recieve faxes. It use to work fine. I can send them out, but not receive.
Jan 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Officejet 6310 wont copy or fax from top loader. To send a multipage fax I have to send each page separately
When you slide the pages into the top loader you reach a small plastic tab and probably stop there. Push pages in another 1/2 inch or so and you should hear a beep indicating the paper now is in far enough.
Dec 05, 2008 | HP Officejet 6310 All-In-One InkJet...
Faxing a word document
hi, i would like to know if you have an HP officejet 6300 fax icon???if you have try to print the document using the fax icon DO NOT used the normal HP officejet series icon.if you did used the fax icon it will display the FAX dialog box,input the necessary information needed.just follow the window..
i believe you can now send the fax..
send me feedback for further troubleshooting....
Aug 04, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
147 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
