Question about Dell Dimension 8300 PC Desktop
Can't get on the internet after installing memory--Did I uplug?
Dell Dimension 8300. Did I accidently unplug something? I have a 4 pin connection hanging loose There are bundles of wires coming from the power souce and mother board to the hard drive--this is where the four wire connection is hanging loose
  • Stephen Scheneman
    Stephen Scheneman May 11, 2010
    These four pin connectors coming from the power supply are typically used to power the drives...you probably have the same type of connector plugged into the back of the hard drive, the optical drive, etc...There are sometimes other uses for them (such as certain AGPcards, SCSI cards, whatnot.) The reason there is one just hanging loose is because the manufacturer uses a power supply that can support additional drives. This connector has nothing to do with your internet or network connections. What did you install, and what other hardware is your system running? How are you connecting to the internet?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 167 Answers
- I would think so that the network cable is unplugged to your computer. Just like a telephone cord,
Posted on Mar 09, 2009
I'm trying to find out if the whole front panel power switch on the dell dimension 8300 can be replaced with a generic brand . I have changed the motherboard, replacing it with a SIS 648FX Foxconn board....
The problem you're running into is that Dell uses proprietary parts,like quite a few manufacturers still do.The board you bought should have come with a manual on a CD or DVD.You can look through the manual and see what the connections are,they're even printed,usually,on the board beside each set of pins.It's very small print.
What you have going for you is that the Dell multi-plug is also labeled as to what wires are for each application.You'll have to cut the plug off and put individual connectors on each wire,then connect them to the corresponding pins.You can get the parts at an electronic supply store,even Radio Shack.
Just be careful,and make sure that if your hands are inside the case,the cord is unplugged.
Bob
Sep 01, 2010 | Dell Dimension 8300 PC Desktop
Can't open dell dimension 3000 to add memory
A tool-free side panel slides open easily to reveal a roomy interior with two free PCI slots. ... The Dell Dimension 3000 is an affordable computer designed to handle essential multimedia demands for the home user. The Dimension 3000 comes with the latest processor and memory technology, and won't break your budget.
May 14, 2010 | Dell Dimension 8300 PC Desktop
I installed windows 7 on my dell dimension 8300 and now I have no sound
follow these steps:
1.go to the official site
2.select your device
3.download the sound driver for windows 7
4.instal the driver
5.restart
Jan 08, 2010 | Dell Dimension 8300 PC Desktop
UNPLUGED
Ribbons you should have 2 one for the cd rom drives and one for the harddrives, Look closley on the borad and it will say next to the connector which is which, the ata one will go to the harddrive and the ide one will go to the cd rom drive the end that only has one connector goes into the borad, the one with 2 connectors kinda close goes into the compoents, DO you have more than one hd if so you may need to find out which one is the master and which is the slave!
Nov 17, 2009 | Dell Dimension 8300 PC Desktop
I cant find sound driver
Suggest you download, and install the Audio driver, for the Dell Dimension 8300.
This is Dell Support and Downloads, for the Dell Dimension 8300 Desktop PC,
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8300&os=WW1&osl=en&catid=&impid=
Sep 04, 2009 | Dell Dimension 8300 PC Desktop
Dell Desktop Dimension 5100 is not booting up
please check first your bios settings.. its could be on the boot up settings. you must configure it out correctly..
May 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 8300 wouldn't start
Sounds like a power supply. You are getting the standby voltage and not the switched. plug all your wires in except the big 20 or 24 pin motherboard connector, take a small wire and short the green (PSU_ON) to black (ground) wires. This will simulate the computers "ON" signal. The fans should all spin up and your plugged in accessories should work, which means bad motherboard, if not bad power supply.
Mar 24, 2009 | Dell Dimension 8300 PC Desktop
Inter net browser opens but doesn't connect, internet connection is connected but cant connect to the browser? I'm using either Firefox or IE on a dell 8300 that had a vundo problem. since I ran a clean up...
this is typical, there's a new virus that overwrites the dns server details and the only fix for this problem is either to waste hours recovering dns or doing a clean installation will fix it. "clean installation means format the hard drive, and re-install your operating system"
please rate me.
Mar 07, 2009 | Dell Dimension 8300 PC Desktop
Install memory
No. Your Dell Dimension uses PC-2100 type memory. Your Dell Dimension can support up to 1GB of memory. For optimal performance install the maximum amount of memory in each socket. Your Dell Dimension 4500 has 2 banks of 1 socket each for a total of 2 memory sockets.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 25, 2009 | Dell Dimension 4500 PC Desktop
Dell Dimension 8300 PC Desktop Logo
60 people viewed this question
Alun Cox
