Question about Carrier Heating & Cooling
Combustion blower turns on and never stops running
I have a Lennex furnace 80MGF. The combustion chamber blower stays running. I have checked the outlet to make sure that it was not plugged all ok. It will not allow the furnace to start becauce this is always running. I dont know what else it could be. I have checked the wiring and i have checked the wire connections. I can get the furnace to run one cycle by tricking the pressure switch. Please help.
  • Bret Maynard
    Bret Maynard Mar 10, 2009
    i have tried that and it is still the same
    Problem Solver:
  • 8 Answers
Sounds to me like the furnace isn't getting enough fresh air for combustion and the pressure switch isn't closing. try taking the cover off the burner assembly and c if that works
Posted on Mar 10, 2009
My Rheem Criterion II gas furnace makes metal slapping noise when the blower comes on. It is not the blower or the motor.
Is there noise when the inducer motor comes on? The small motor that comes on first. It sucks the co out of the combustion chamber. It comes on first. Then the burner lights then the blower comes on. And the noise continues while it's running and doesn't stop till the blower stops? Is that correct? But it's not the blower wheel? Could it be out of balance and hitting the blower shroud?
Feb 18, 2017 | Heating & Cooling
Tip
When the furnace blower runs all the time.
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Make sure the fan switch on the thermostat is not in the "ON" position it should be in the "AUTO" position.
on Dec 30, 2009 | Heating & Cooling
I have a goodman mfg gmp100-4 furnace. When I turn theromsat to heat I hear blowing for sixty seconds but that is all that happens. What should I check first?
Your furnace has a combustion blower on it. If it runs and don't pull in the vacuum switch the furnace will not start. On the combustion blower you will find a little rubber hose follow that hose to the vacuum switch. You will see 2 wires on the vacuum switch connect the 2 wires on the vacuum switch together. If your furnace starts and runs fine for 15 to 20 minutes you need a new vacuum switch. Try this first
in this image A is vacuum switch B is combustion blower
Hope this helps......
Nov 16, 2010 | Goodman Heating & Cooling
We have a White-Rodgers 1F80-51. The fan blows
May 31, 2010 | Heating & Cooling
Outside heating unit runs all the time
Feb 19, 2010 | Heating & Cooling
Furnace blower won't stop running
Jan 04, 2010 | Amana Comfort Zone 12M32PBEH Air...
Main limit switch
I am providing some information, but I encourage you to have a furnace technician look at your furnace. The reason is; the limit switch trips when there is a problem that may present a fire or combustion hazard. I've seen these switches go bad, but not very often. Usually they are tripping because the plenum is sooted up and excessive heat builds in the combustion chamber. This is common in older furnaces that have pilot flames- the flame runs all year and soot deposits in the plenum, plugging the air flow through the combustion chamber after years of use.
The limit switch is a safety control switch located on the furnace just below the plenum. If the plenum gets too hot, the limit switch shuts off the burner. It also shuts off the blower when the temperature drops to a certain level after the burner has shut off. If the blower runs continuously, either the blower control on the thermostat has been set to the ON position or the limit control switch needs adjustment. Check the thermostat first. If the blower control has been set to ON, change it to AUTO; if the blower control is already on AUTO, the limit switch needs adjusting.
To adjust the switch, remove the control's cover. Under it is a toothed dial with one side marked LIMIT; don't touch this side. The other side of the control is marked FAN. There are two pointers on the fan side; the blower goes on at the upper pointer setting and turns off at the lower pointer setting. The pointers should be set about 25 degrees apart. Set the upper pointer at about 115 degrees Fahrenheit and the lower one at about 90 degrees Fahrenheit.
Mar 15, 2009 | Heating & Cooling
Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
134 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
