I have a Toshiba Gigabeat model MEGF40> The s/n is 85105475C. When I turn on the device it is frozen. Once I try to run it the light used to make a selection keeps running up and down and I am unable to stop it. Please help!
  • 6 more comments
  • carlosmar2 Mar 11, 2009
    Turning off and on after few minutes doesn't work. The device doesn't follow any of the commands when I press the Plus Touch.
    Is there any way to completely reset the Gigabeat?
    Thank you
    I have tried many times the switch to turn off an on the battery and it doesn't work either.
  • carlosmar2 Mar 15, 2009
    None of all the previous suggestions worked. If anyone nows a reliable place to send the Gigabeat for repair please let me know.
    Thank you
    How can I do the "Hard reset" o "reformat" the Gigabeat?
    The computer recognizes the device but I am still unable to get a response using the Plus touch pad.
  • carlosmar2 Mar 25, 2009
    Unfortunately none of the above mentioned suggestions have worked so far. I think that noe the best solution is send the unit for repair. If you know a reliable site please let me know where is it so I will try to contact them for an estimate.
    Thank you.
  • carlosmar2 Mar 26, 2009
    Please read my comment of March 25 and if you have a suggestion I am waiting.
    Thank you
    I tried to contact Toshiba many times for information of service for the Gigabeat with no luck but I will try again.
    Thank you
  • 13,433 Answers
This is a common fault in the toshiba gigabeat, the control pad button is stuck of the whole keybad is faulty.
I don't remember how much the gigabeat costs as new, have you considered buying a new mp3 player?
well I see 2 solutions here
1. attempt to fix it yourself and inspect the keys by taking the gigabeat apart. possibly replace the keys/keypads NOTE: if you have warranty on the player, use your warranty instead of trying to fix it yourself.
I haven't looked inside this player so I don't know if the keypads are build in to the mainboard or if they are on a replaceable board. Most likely build in, in that case check the buttons carefully that none of them is stuck.
2. send it to gigabeat repairs. From what I hear the RadioShack Repair Centers should be toshiba Authorized. Try contacting a radioshack repair center or toshiba directly.
Posted on Mar 15, 2009
    Brigadier General:
  • 3,614 Answers
It seems that there was a problem on the keypad, try to clean the pad, or better send it out for repair.
thank yoiu for using fixya
  • 6,487 Answers
If this device is being recognize by the computer when its connected you can format it that way ....
  • Mark Gil
    Mark Gil Mar 15, 2009
    If the device is being recognize by the computer you can load some software update on that unit that can help in making it work...
  • 790 Answers
Hi
try the hard reset
Thanks!
Posted on Mar 11, 2009
  • carlos fernandez Jr.
    carlos fernandez Jr. Mar 11, 2009
    Hi
    please reformat your unit because you have virus or corrupted files
    Thanks for using fixya!
  • 10,515 Answers
At the bottom of player there is a little battery on/off switch - its tiny and black but you would have needed to switch it on to first use it. Well turn it off here for 10 seconds and the on again. This removes all power from the hard drive and circuits which occassionally freeze.
Thanks.
Posted on Mar 09, 2009
  • taran_2005
    taran_2005 Mar 15, 2009
    To reset it, you have to press and hold the menu button for 15 seconds.
    Do rate this solution as Fixya as a way of appreciating me.
    Thanks.
    Sergeant:
  • 320 Answers
Reset the device again by turniong it off for few minutes then on again.
  • 19,396 Answers
I think you can reset the unit by holding the start button for about ten seconds , try that first.
  • Ginko
    Ginko Mar 09, 2009
    At the bottom of the Toshiba you also find a little switch to turn off the battery Turn it for 10 seconds and the turn on again.
    This can unlock the unit unless the mp3 is faulty.
  • Ginko
    Ginko Mar 25, 2009
    To locate the nearest authorized service center you can call Toshiba at Phone: 1-800-631-3811.
    Or use the page here.
Frozen?
try turning off the battery switch on the bottom of the player. Use a pen point slide it to the left for about 15 seconds, then back to the right.
Aug 11, 2009 | Toshiba Gigabeat S30 MP3 Player
Gigabeat F40 Frozen.
I had the same problem, would not work and when it did it kept scrolling. Trick is to take the front cover off, and see if the control then works. If so, there are two strips on back of the battery as spacers. I took them off, put back together and have not had a problem since!
Jun 05, 2009 | Toshiba Gigabeat MEGF40S MP3 Player
Frozen screen on Gigabeat S30
I left the Gigabeat on until the battery ran out. It then turned itself off automatically and allowed me to re-charge the battery. When I turned the Gigabeat on, it again worked perfectly,
Jun 23, 2008 | Toshiba Gigabeat S30 MP3 Player
Frozen
i'm thinking the hard drive is messing up... you know when i dropped my gigabeat S30 it wasn't working n it was freezing and the video files weren't playing at all. it would freeze when i turn on or play video. then i turned it off and then back on using the battery switch. it said "contact the manufacturer for repair" with a yield sign. i really thought i killed it...but i still had my hopes high to fix it myself somehow n i really thought it was from the hard drive. so i took it in my hand and gave it a shake on my palm. like i actually hit it on my palm for once n then i turned it on and it worked =D fineee.... i was so happy n now it still works fine ;)
i hope that helps
May 26, 2008 | Toshiba gigabeat S MP3 Player
Toshiba gigabeat
gosh! where did you drop the gigabeat?? It must have been a hard fall, or in an awkward position, because I have dropped mine on cement so many times, but it has a tiny scratch on the back and nothing else.
I once had to send my gigabeat in to the company for repairs. They did a pretty good job, fixed it, and sent it back. I would recommend sending it in, because your problem seems out of your control.
Dec 25, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Computer does not recognize Gigabeat Device
the solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
Oct 12, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat F40
Toshiba Gigabeat support is 1-877-250-8595
Sep 29, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Gigabeat frozen!
Hi Lorna, Yeah I found my Gigabeat froze a few different times when I was getting used to it. Solution: at the bottom of player there is a little battery on/off switch - its tiny and black but you would have needed to switch it on to first use it. Well turn it off here for 10 seconds and the on again. This removes all power from the hard drive and circuits which occassionally freeze. Hope that helps
Apr 23, 2007 | Toshiba gigabeat S MP3 Player
 Grubhead
Grubhead
