Question about Adobe After Effects® CS3 Professional Edition Full Version for PC (25510629)
My system reboots when i run certain softwares
It doesn't happen with all the softwares..only when i run certain softwares my system reboots n next time in the explorer gives a msg that the system has recovered from a serious problem...this has happened when i ran adobe after effects cs3 n counter strike source
  • 102 Answers
Always open files after closing all the other programmes.... maybe your RAM is low or ur hard disk is getting full.......
Posted on May 09, 2009
  • AJAY YADAV
    AJAY YADAV May 09, 2009
    Try reinstalling those softwares of yours. If it still fails then
    update your drivers. If still having problem....Well the only way I
    know is to reinstall OS. Some files may have been corrupted. If it
    fails even after that then the software is a damaged copy.
My HP 6500 Wireless printer doesn't even show up. It worked fine yesterday! I can't find the disk to start it over. What happened?
Hi Dave,
Open www.hp.com and enter your product # as 6500 in search bar and hit enter key
Select Software and Drivers Download ( or support for HP Officejet 6500 Wireless ) and choose the operating system to download the drivers and install
Regards,
Sean
Feb 26, 2013 | HP Officejet 6500 Wireless All-in-One...
My toshiba laptop was recently swiped clean and rebooted running vista. Everything was running smooth.until i shut down the system. the next time at start up it didn't recognize any OS. the next t
I recommend reinstalling Vista, and replacing the Hard Drive as well. The errors being sporadic could be indicative of a hardware failure or a software failure and could be both in tandem.
Dec 09, 2012 | Toshiba Computers & Internet
E7342z lapyop keeps crashing
This can be a number of things. "Blue Screens" indicate some piece of hardware is going bad. Most likely it is add-ware or some spy-ware happening in your system files. I use Spybot search and destroy. It is free and it will clean that out. It may be time to do a reboot as well on your system software "Operating System" from the restore disc and start fresh. I have to do this once in awhile to keep things running smoothly if I do not catch certain things coming into play on my machines. John
Apr 09, 2012 | eMachines Computers & Internet
I got error on printer LBP2900 when connect to my laptop (windows 7) It show communication error but usb connection and software installation no problem. Any idea about it?
Most likely it is a corrupt software installation.
You can try the easy things first: 1) Unplug the USB cable from the computer 2) Reboot 3) Plug the USB cable back into the computer, see if the communication error happens again
If that doesn't work, time to reinstall the software: 1) Go to Control Panel > Add Remove Programs OR Programs (depending on which version of Windows you have) 2) Remove every piece of software related to your printer 3) Unplug the USB cable from your computer 4) Reboot 5) Disable any Anti-Virus or Firewall software that you have running 6) Re-run the printer installation software
Jul 04, 2011 | Computers & Internet
I need to reboot my computer, what does that mean?
This means you need to restart your computer. This typically happens after installing software or updating certain programs. Just go to the start menu, and click on turn off computer or just click "OK" or "Restart Now" next time the message comes up.
Dec 10, 2010 | HP Media Center m7060n PC Desktop
WONT LOAD .
cERTAINLY ANOTHER APP LOADED USES the same system files as roxio,
so it is waiting "in the queue" for its to be usable,
manage to close all running applications. (some need to CTRL-AL-DEL "end process"
(in the process tab) 'cos they're not in windows with a red cross upright)
or bad version of aspi drivers
down & install
http://www.adaptec.com/en-US/speed/software_pc/aspi/aspi32_exe.htm
reboot before cheking
Nov 22, 2008 | Roxio Easy Media Creator 10 Suite
Doesn´t work anymore
Hi. Forgive me for asking, but did you try unplugging everything, including the firewire, and plugging it in again?
If you try this and it doesn't work, try shutting your laptop down gracefully, then unplug all the Firebox connectors including the electricity. Wait about 10 seconds, then reboot your laptop. Don't open your recording software yet.
Connect the electricity and the firewire as described in the Firebox manual, and then open your recording software. If this doesn't work, something might be wrong with the Firebox.
The problem you have happens once in a while with mine--it seems to be connected with overheating or something. Anyone else have this problem?
Oct 01, 2008 | PreSonus Firebox 6x10 External Sound...
My computer is running very slow
hi
Remove unwanted programes from the startup and defragment the harddisk this will speed up the system.
Jyothish
Jul 17, 2008 | Computers & Internet
Roll back phone software
The phone is in a continuous because it is trying to connect to the NBX. You need to make sure it is on the same network as the NBX. Also, within the NBX you need to make sure Auto-Discovery is enabled. You also need to check how many group 2 licenses you have, as this phone requires one to run on the NBX.
Aug 31, 2007 | 3Com NBX 3102 IP Phone
Adobe After Effects® CS3 Professional Edition Full Version for PC (25510629) Logo
48 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
