Question about Troy Garden
Won't fire up. has gas. - Troy Garden
  • 40 Answers
If this mower has been sitting for a while it is likely that the gas that was left in the carb is bad and quite often contains water. this will cause the rubber seat in the carburetor to swell. thus shutting off the gas supply. you may want to take this in for a tune-up. gas is bad after 30 days. (if in doubt throw it out)
Posted on Mar 11, 2009
2007 flhtc won't idle
Hi Anonymous, try a fuel stabilizer. Good luck.
Apr 23, 2013 | Harley Davidson FLHTCUI Electra Glide...
Won't start can't even get it to fire got spark getting gas ,don't know.
Check the compression! It has to be around 120 and no less then 100 to fire off. If it is ok, Have your carb checked out. It should fire off with some spray.
Feb 10, 2013 | Poulan Garden
1992 dakota v6 stalled while driving, won't start and not firing ?
Crank sensor.should be on back side of engine on passenger side were bellhousing is. controls spark and fuel pump.
Dec 06, 2012 | Cars & Trucks
94 Oldsmobile 88 Royale turns over, gets fire and gas but won't start
Crank position sensor...i have same car and that happened to me
Oct 14, 2012 | 1994 Oldsmobile 88
Tappan gas oven won't stay hot
bad flame sensor or check gas pressure
Aug 24, 2017 | Tappan Ovens
94 volvo 960 wagon engine turns over but it won't
have you check for injector pulse? if no pulse or no ignition fire, most likely it is the ECM.
Jun 13, 2012 | Cars & Trucks
I had to take out my carver 3600 stc gas fire out now it won't light
seems confusion recheck everything and put it once by once together
Apr 15, 2012 | Audio Players & Recorders
Replaced igniter and valve assembly still won't fire up?
check the door locking mechanism, if the door isn't giving a signal that the door is closed it won't fire up,
Jul 21, 2011 | LG D2526 Gas Dryer
90 toyota pickup won' start -- battery good and ignition good but not firing .
How about gas, are you sure gas pump is working? Can you see if it gets gas to sparkplugs? Are they wet or smelling gas?
Sep 16, 2010 | 1990 Toyota Pickup
Car won,t fire up but trying to turn over its as
Lots of reasoons for a no start this answer is as if it was running OK just the other day and was starting OK. The gas tank has gas? Spinning real freely indicates to me that the timing belt broke. The oil cap off the valve cover look in there to see the cam and crank engine you should see it turn. The fuel pump may not be coming on. The fuel filter could be frozen not letting the gas go though. The spark may not be happening as A senser or also a plug wire or other wire off inspection of these things something off can be the only problem
Feb 08, 2010 | 2002 Volkswagen Golf
Garden Logo
35 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
