Question about Maytag Bravos MTW6600T Top Load Washer
F 50 fault code and will not spin
This Maytag Residential washer Model# MTW6600TQ0 gives a f 50 error message and will not spin.
  • 40 Answers
F 50 is a control issue needs to be replaced 3 screws in back of control panel pull top forward control is on the right part #w10189966 its about $160 to $190 easy to change
Posted on Mar 10, 2009
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 | Dishwashers
Kenmore front load model 40272900 e codes (control Error)
If the washer's full model number is 79640272900, then the unit was made by LG. Looking up LG front-load washing machine error codes will give the available codes. Here is one listing: http://www.appliancefactoryparts.com/blog/2010/02/washing-machine-fault-codes/#LG . Some of these codes are also available in the manual in the Trouble-shooting section. Manage My Life has the manual as a PDF here: http://www.managemylife.com/mmh/owner_manuals/17952/KENMORE-Residential-Washers-L0910072?brand_name_search=79640272900 .
I hope this helps.
Sep 21, 2013 | Computers & Internet
Maytag washer giving error code A0
Maytag Neptune Priority One Service
(888) 462-9824 call to the company to due the error code.
God bless you
Aug 01, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag Bravo Washer flashes F50 code
Most likely a bad machine control,can also possibly be a motor per whirlpool but I have never had to change a motor,changed a lot of machine controls.
Sep 01, 2009 | Maytag Bravos MTW6600T Top Load Washer
Maytag washer model # mtw6600tq0 error code f50
Two things cause the dreaded F50 code. (motor)
1. The machine control
Bravos MTW6600T
http://www.repairclinic.com/SSPartDetail.aspx?s=t-Maytag+MTW6600T+-%3d%3di1469076&PartID=1469076
2. The stator
Item 17 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136402&diagram_id=1303991#d1303991
The upper cover of the stator comes in kit form and has been known to also cause the dreaded F50 code.
http://www.appliancepartspros.com/part_details.aspx?part_id=4327312&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5136402%26diagram_id%3d1303991
All of them are some what costly repair(s) in my book but cheaper than a new machine.
I have yet to change a Stator for an F50 Code.... but have changed a lot of machine controls (most often failure) and stator cover kits (occasional failure) that corrected the problem.
Just being honest. Thanks for using FixYa!
Kelly
Jul 29, 2009 | Maytag Bravos MTW6600T Top Load Washer
Washer starts, then shows fault code
Bravos MTW6600T
2. The stator
Item 17 this link:
Feb 21, 2009 | Maytag MTW6500TQ
No spin
Code Lr indicates a fault or failure with the motor. Manual refers user to contact a service rep. First check your warrantee and do a look up on recalls (you can use the Maytag homepage) as some of the earlier versions of this model were recalled and Maytag has agree to some forms of restitution/repair and or replacement assistance.
Dec 10, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
1,135 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
