Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Buttons won't work
I am unable to use my oven; the display buttons (except "Clear") won't work.
Try unplugging the oven let it sit for thirty seconds and plug it back in. Worked for me.
Posted on Mar 15, 2009
MY OVEN WON'T HEAT
Hello - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failur
Oct 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Electrolux oven won't heat up at all
Hello Le'Cinda Rhone - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another question, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. Then a beep will sound and LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
Sep 27, 2012 | Electrolux 30 Inch White 30" Electric...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    I have a JT955 GE Profile 30"double oven...when the food is cooked, and I press "clear/Off", the oven won't shut off...continues to maintain temperature? Tonight, I had to shut it off,...
    Your wall oven has two main components that control the oven. The main control computer and the user interface. Your problem is probably in the user interface, although it could be the main control or both. I have had some success cleaning the ribbon that connects the user interface to the control with a little rubbing alcohol. That only works some of the time though. Due to the fact that the oven works except for the cancel button I would lean towards replacing the user interface if cleaning the ribbon dose not work.
    Aug 29, 2011 | GE Profile JK955SFSS Electric Double Oven
    The oven won't turn on. We are unable to set the clock either. The display flickers but doesn't display.
    There are lots of different timers on fisher and paykal The last one I reset was a few weeks ago it involves pressing 2 buttons at the same time I think it was the oven on and oven off buttons but I am not sure You will know when you have pressed the right 2 buttons the display will stop flickering set the clock time using the up down arrow buttons The auto light should not be on if it is press the manual button Regards Geoff Stove Recyclers
    May 29, 2011 | Fisher Ovens
    Code E0 and F2 with a little lock displayed on touch board of Whirlpool Gas Range. burners work but unable to operate the oven
    You will need to press the cancel/stop button, this will clear the display and you will be allow to use the oven. If this does not work yoy will have to unplug the stove for five minutes and then plug back up and this should clear the display and allow the oven to work.
    Nov 14, 2009 | Ovens
    Unable to clear error message on panel...oven not operating
    The E1- F5 error is a door lock error.
    The control (TIMER) has likely failed in this instance - BUT...
    Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
    You should disconnect power again for 15 seconds and reconnect and see if that helps.
    If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
    This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
    Sometimes these work, but if the control has failed it won't make any difference.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#RET
    Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
    Panel on double oven will not work except for one button and the clock
    Press and hold the clear/reset button for about seconds see what happens.
    Regards
    Sep 05, 2008 | Ovens
    Wall Oven won't work
    I tried randomly pushing 2 buttons at a time, and when I pushed "Timer Off/On" and "Cancel" together it unlocked and is now working fine. The following day it beeped a lot for an hour or so (must have been catching up on previous pushes) but now is back to normal.
    Mar 14, 2008 | Tappan 30IN ELEC IGNa Oven
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    81 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Mike Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
