Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Lights work, door won't operate (lightening strike)
Lightening strike at our house shorted a Sears#139.53640SRT. The lights work from the remotes and the wall switch but the door won't open or close. the green LED on the PC board blinks 5 times and then remains off for 5 seconds before blinking again. This is a code for troubleshooting. What is it telling me? Lee
5 Suggested Answers
  • 244 Answers
SOURCE: Craftsman Garage Opener Clicks only and LED blinking 5 times
first off, hitting extra button on remote would not do anything. Is door up or down/ where is trolley that attaches to chain, by door or motor. Is is jamned against a bolt. Try a paper clip and jump from white to read terminal. Does it work. Does light bulb blink 10 times. I ignore the diagnostic lights and go by symptons. Give more info.
Posted on Feb 12, 2009
  • 10 Answers
SOURCE: garage door indicator light blinks 5 times
this probably means you have a bad photo eye if you happen to have to doors side by side may be picking up on other sides photo eye just switch sides from left to right, however if the lights are coming on but does not mean that photo eye is not bad it has a small circuit board inside of it...
Posted on Apr 05, 2009
  • 3197 Answers
SOURCE: I have a sears craftsman door opener. I replaced
There isn't a reset code. It sounds like you may be having a door sensor problem. Is the small light on each sensor lit and not blinking ever so slightly? Does your door start down and then reverse to the open position? Is the door stuck in the open position? Check to make sure the trolley isn't jammed against the bolt just in front of the motor unit. If it is then remove the bolt and run the door until closes. Then adjust the up limit on the side of the motor unit. Turn it in the opposite direction of the arrow printed on the cover about 3 turns. Be sure to then replace the bolt.
Posted on Jun 04, 2009
SOURCE: sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks
Posted on May 13, 2010
Liftmaster 3265M. Two units. Why does neither work since lightning storm?
Chamberlain Liftmaster garage door opener problems ...
? 3:10
Jul 2, 2013 - Uploaded by Mike McCarron
Might have taken a lightening strike, knocked out GFCI that was on the circuit that garage door opener was on. When I ... And sometimes after it happens it takes 30 or so seconds before the opener will work again. ... The keypad unit worked well butneither the homelink or the remote units worked.
Garage Door Openers - Lightning Strike - Forum - Bob Vila
Aug 6, 2005 - The house did not lose power and I do not believe the house was actually hit. ... the light comes on on the unit (as expected), but neither door opens or ... Afterplugging it back in, try opening the door with the hardwired button first - if it still doesn'twork, chances are your opener's taken some damage but not ...
I Have A Liftmaster Garage Door Opener Unit. The Remote Work ...
Jan 01, 2016 | Building Materials
Dehumidifier not coming on at all
I hope it is only the fuse, but lightening can damage lots of things.
If the dehumidifier has an electronic component, like a thyristor or worse an integrated circuit, it is likely that part is damaged.
So if it has something like a wireless remote control there is damage.
It is the very fast change in electronic field caused by he lightening, what will induce a current in the electronic equipment causing the damage.
Als read ESD (ElectroStatic Discharge) and EMP. Although the change in EMP is much faster than in lightning.
Jul 20, 2014 | Dehumidifiers
Twice now our router has failed to work after lightening strikes. The UPS means its lights still flash etc but the router itself does not work. Why does the UPS not protect it and what do we need to do...
A UPS is generally not designed or manufactured to protect against lightning strikes and / or power surges. Its purpose is ensure that whatever it is supplying power to does not turn off in the event of a power outage. You would be better served by getting a lightening protection strip from a hardware store that comes with insurance against damge from lightening and power surges. Alternately at substantially more cost, you can have an electrician or lightening protection contractor install whole-house lightening protection. Lightening protection strips with insurance included are relatively inexpensive.
Please don't forget to rate this if you found this helpful.
Jan 14, 2011 | Computers & Internet
I had a lightening strike at my home. Since then, the garage door does not function with wall switch or remotes. when i press the switch, light comes ON on the door opener and i hear a click but nothing...
Well, I don't think that disconnecting the garage door from the garage door opener would affect function.
The lightning strike could have destroyed the circuitry inside the garage door opener, seeing that it won't operate with the wall switch or remotes.
It's likely that a board was fried by the lightning which would render the garage door inoperable.
Aug 08, 2010 | liftmaster Chamberlain Garage Door Opener...
Oven will not light
yes this is most likely do to the lightning i have been to a couple houses hit by lightning that all of the appliances were shorted due to lightning try first unplugging the power cord then replug to see if you can get it to trip back to the normal fuction mode most of the time this does not work most likely your main control board has shorted out due to the lightning most of the time this is covered under you homeowners insurance if you rent then you can speak with the landlord. your other option would be to open the unit and find every shorted spot which might get a bit costly hope this helps
Jul 18, 2010 | Whirlpool Kitchen Ranges
I would pull the logic board and check for burnt or missing traces on the printed circuit. Garage door openers hate electrical storms. I really doubt it got to your start capacitor.
Jun 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
After lightening strike, Aqualink control panel reads 6700 rev c. All lights on, none work. Outside, power center won't work. No lights. Reset doesn't work. Battery good, fuse appears good. Any ideas?
ok check all the braker even the one for the house .turn them off all and back on if this do not fix check for 220 v if voltage is present the board is bad need replacement get the number from the back to check for prices
What causes power door locks,dome lights, trunk release button, and self leveling on 2001 buick lesabre to stop working at the same time
A heavy jolt of electricity like a mini lightening strike will cause all the above to stop working instantaneously..................sodeep
Jul 30, 2009 | 2001 Buick LeSabre
Craftsman GDO 1/2 HP - Remotes not working after storm
sounds like it blew the reciever crystal buy another and return the motor thats fried 4 refund
Jul 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
69 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Are you a Sears Building Material Expert? Answer questions, earn points and help others
