Question about LG LRFC25750 Refrigerator French Door
Broken water line inside of refrigerator door
It is a hotpoint side by side refrigerator
  • 28 Answers
Check if there is any sound when the water dispenser lever is pressed, if there is click and no water, check on the filter and incoming. if there is no clicking sound, maybe you have a damage solenoid valve.
Posted on May 09, 2009
Where do I direct the hot air from an hair dryer to thaw out the water line in my hotpoint side by side refrigerator ?
Hotpoint ref.
made by GE
There is 2 different place they freeze up inside door water line for cold water dispenser & water feed to ice maker.
for cold water disp. Water line depends on model # will start at bottom of door loop over the disp. control and back down from top of control to cup area to defrost this line best way is to shut down ref and leave door on freezer open can take up to 12 hours.
taking door apart is a major project.
If its your ice maker fill tube easy fix turn water supply off.
on back of ref. there is a water line going up to the top of freezer
this tube will pull out from back the whole fill tube will come out
take to sink thaw with warm water replace tube You may need some caulk to seal area tube meet ref.
Mar 24, 2015 | Hotpoint Refrigerators
Water leaks from bottom of freezer door
You need to remove the door from the refrigerator, then remove from the door the plastic frame carefuly, its snaping, and attach the new (1/4") line to the end of existing line then pull up the existing line softhly until the new one appears, check before all this if the line is broken at then of door or in the middle and if leak is below the refrigerator check from the solenoid to the door.
Jun 13, 2014 | Hotpoint HSS25GFP Side by Side...
Water not getting from filter to water dispenser
I have this problem as well and called GE (Hotpoint) for guidance, absolutely no help from them. After searching I found others with same problem and same results from GE but did find a solution. The water line is freezing inside the door! I had to emty the door, put a plstic sheet over the freezer area to conserve the cold inside and leave the door open for about 45 minutes VIOLA' Water again. Unfortunately it happened again about a week or so later, I did the same procedure then raised the temp in the freezer section from 2 to 4. seemed to work for a month and happened again. raised another notch and works OK now.
Mar 23, 2010 | Hotpoint HSS25GFP Side by Side...
Refrigerator makes ice and dispenses ice, but does
could be valve, it is located underneath on back. it also could be the mother board. Check valve with ohms metter. Also make sure water resevior or water lines are not frozen inside refrig section. Also water feed line going up through door bottom hinge on freezer is not frozen. Disconnect at couplin at left bottom front and blow through line
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
I have a Hotpoint Refrigerator Model HSS25GFPH and the water dispenser won't work. The icemaker is still working. I have changed the filter and still no water. Any suggestions? Ben Kirkpatrick,...
My daughter's Hotpoint has the same problem (not sure of the exact model). Discovered that the water line inside the freezer door is freezing up. However, I don't know why and the dealer says they have no clue either. This may be your problem.
Jan 04, 2010 | Hotpoint HSS25GFP Side by Side...
Water in the door doesn't work
Did you check the filter behind fridge its on the small water line or can be on the line somewhere or inside fridge depends what make and model number you have.Be carefull
Nov 11, 2009 | Hotpoint (HSM25IFTSA) Side by Side...
Have a hotpoint side by side with water and ice in the door....and you can get ice but no water....we put in a new filter but no water will come out,,,,,help...thank you
Shawn- I had the same problem. Take a hair dryer and blow on the inside of the freezer door behind the water and ice dispenser. The water lines freeze up occasionally. Heat it for about ten minutes, spread the heat around so it doesn't melt anything. When you are done, let it stand for about five minutes before you try to get water out of the dispenser. I hope this works for you. Good luck!!!
Oct 03, 2009 | Hotpoint HSS25GFP Side by Side...
Water not coming from spout,pressure in the line into door to spo
I have the exact problem with my side by side, water gets to the bottom of the door, and no further. Like Dan said, don't see how to open up the door.
J Bod @
Mar 14, 2009 | Hotpoint HSS25GFP Side by Side...
Everything works but no water
Try turning down the freezer a little.
You can 'thaw' the water line in the door by hanging some towels in the freezer with the door open. Should thaw in a couple hours. At least this way you don't need to empty the freezer.
Dec 08, 2008 | Hotpoint HSS25GFP Side by Side...
Water not getting to dispenser, but does get to ice maker.
Hi All,
The fix to the "GE/Hotpoint Secret" frozen water dispenser problem is the Dispenser Water Tube Heater Kit, P/N WR49X10173 that can be purchased at Sears. Just a few bucks. My Hotpoint (model HSM25GFRA5A) had the same issue and GE would not tell me anything but required a technician to come out. The technician had no clue but after making some calls found the heater at Sears and ordered it delivered to me. He had to setup a return appointment but I canceled it after getting the parts and fixing it myself. The instructions are in the kit. Since most all GE/Hotpoint refrigerators (same model group of course) use the same parts/assemblies this will work for lots of folks. See pic below. If the area behind the cover looks like this it may be the part. Feel free to email me for help on this ( Piece of cake.
Jan 18, 2008 | Hotpoint HSS25GFP Side by Side...
LG LRFC25750 Refrigerator French Door Logo
235 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
