Question about Brother IntelliFAX 770 Plain Paper Thermal Fax
Receiving fax I have a Brother Intellifax 770. I have tried to change the Easy Receive to On, and Off, and Semi, but I get the same results. I have to pick up the handset and hit the start key in order to receive my faxs. I want them to just come in automatically.I don't want to have to pick up the handset to get them, sometimes I am not near the machine, or do not know when they will be coming in. Help????
  • 13 Answers
You need to press the "mode" button until the mode on the right side of the display says "FAX ONLY" ( if the line is just for faxes) or "FAX/TEL" ( for fax and voice calls) in the fax/tel mode it will ring with a "double ring" if it is a voice call.
Posted on Mar 29, 2009
How do I receive faxes with the 240c
Manual mode turns off all automatic answering functions unless you are using the Distinctive Ring feature or you are using an external answering machine on the same line as the Brother machine.
*Distinctive Ring is a function of your Brother machine that allows a person with one line to receive fax and voice calls through two different phone numbers on that one line. Brother uses the term "Distinctive Ring," but telephone companies market the service under a variety of names, such as Custom Ringing, Personalized Ring, Smart Ring, Ring Master, Ident-a-Ring, Ident-a-Call, Data Ident-A-Call, Teen Ring, SimpleBiz Fax & Alternate Number Ringing and BT Call Sign.
  1. Setting the Receive Mode
    1. Press Menu.
    2. Press the up or down arrow key to select Initial Setup.
    3. Press OK.
    4. Press the up or down arrow key to select Receive Mode.
    5. Press OK.
    6. Press the up or down arrow key to select Manual.
    7. Press OK.
    8. Press Stop/Exit.
Receiving Faxes in Manual Mode
  1. Lift the handset of a telephone that is on the same line as your Brother machine.
  2. When you hear the sending machine's fax tones (short beeps that occur at regular intervals), do one of the following:
    • If the telephone you answered is near your Brother machine or connected to its EXT jack(socket), press Black(Mono) Start or Color(Colour) Start.
    • If the telephone you answered is not connected to or near your Brother machine, press *51 (*91 for New Zealand) on its dial pad.
  3. Your Brother machine will produce receiving tones.
  4. Replace the telephone handset. Your Brother machine will begin to receive the fax.
< Easy Receive (Fax Detect) >
The Easy Receive (Fax Detect) feature allows you to receive faxes in Manual Mode by simply lifting the handset of a telephone that is on the same line as the Brother machine. Your Brother machine will automatically generate fax receiving tones, at which point you can replace the telephone handset and wait for your fax to be received and printed.
Your Brother machine's Easy Receive (Fax Detect) feature is turned ON by default. To adjust your Brother machine's Easy Receive (Fax Detect) setting, please follow these steps:
  1. Press Menu.
  2. Press the up or down arrow key to select Fax.
  3. Press OK.
  4. Press the up or down arrow key to select Setup Receive.
  5. Press OK.
  6. Press the up or down arrow key to select Easy Receive or Fax Detect.
  7. Press OK.
  8. Press the up or down arrow key to select On, Semi or Off. *In some brother machines, Semi may not be in the options.
    If you choose Semi, your Brother machine will only answer an incoming fax if you answer using its handset or by pressing the Hook, Hook/Hold, Hold, Speaker Phone or Tel/R key on its control panel.
  9. Press OK.
  10. Press Stop/Exit.
Note Here are a couple of points to keep in mind:
  • If Easy Receive (Fax Detect) is ON, but your Brother machine doesn't automatically answer the incoming fax when you lift the extension telephone's handset, press *51 (*91 for New Zealand).
  • If you send faxes from a computer that is on the same telephone line as the Brother machine and the Brother machine intercepts the calls, turn Easy Receive (Fax Detect) OFF.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | Brother Multi-Function Center MFC-240C...
Brother Intellifax 770 - how to connect to PC?
The intellifax-770 deffinetly cannot connect to a PC. There are several other models that can, but not this one.
May 29, 2010 | Brother IntelliFAX 770 Plain Paper Thermal...
It rings but wont pickup unless you pickup handset and press start fax
Your machine has the Easy Receive function. Although it's enabled, there's another setting the turns the feature ON, OFF, SEMI. To set the machine to automatically accept/print ALL faxes, do the following:
  1. Press Menu, 2, 1, 3. you will see 3.Easy Receive in the window
  2. Use the <--> keys to change from OFF to either ON or SEMI (in your case you want the feature fully enabled so change it to ON)
  3. Press Stop/Exit.
Your machine should now accept and print faxes automatically.
Oct 27, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 770 - can not fax out
You probably need a prefix to dial out of your office. If it's a home fax machine, you may need to dial the number "1" plus the phone number you wish to dial.
Jun 25, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Check paper
change feed rollder or rub them..........
Aug 12, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 770 fax machine failure to receive faxes
I HAVE A BROTJERS 770 AMD ALL I DONE WAS GET A 2 SPACE TELE JACK AND PLUG IT INTO MY MODEM FROM COMCAST AND PLUG MY PHONE AND FAX INTO IT AND CAN RECEIVE AND SEND
Mar 24, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Set up
Try this links for download manual http://www.amazon.com/Brother-IntelliFAX-770-Fax-Machine/dp/B00000J4WS/ref=dp_origpkg/103-1633732-4035849#productDetails
Sep 17, 2007 | Brother IntelliFAX 770 Plain Paper Thermal...
Brother IntelliFAX 770 Plain Paper Thermal Fax Logo
88 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
