By Grant - usenet poster
Is it possible, to use a Processor Card from a Proliant 2500
to upgrade a Proliant 1500?
Bryan Smith
Sent via Deja.com
Solution #1
posted on Aug 02, 2007
Phoebe - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
one post was fine, ...but 3?
The abosolute best upgrade path for the 1500 is a dual PPro board (if you
can find one, that is affordable. I have seen these sell for $750+ on ebay,
for the board w/o procesors or memory!). There is a company called PowerLeap
that makes a Celeron-based socket8 performance upgrade. They have a 500Mhz
model the will go SMP, and a 600 that will not. If you really want to get
jiggy with it, you can ditch the standard 500Mhz and opt for the 533PPGA
processor. That will give you 1066Mhz of dual processing power. I can hear
you moaning from herestop that! There is also a PII Overdrive that is a
socket8 chip that runs at 333Mhz with full speed cache. It is said to out
perform the PII450/512k processor. And, the PII OD can be used in SMP
configurations (these are not cheap, but they are less than the
PowerLeapII's). You might be better off sinking your money into either a
Quad system (4000, 4500, 5000, 5500) or a higher-end PII/PIII Proliant
server. 1850's (i know, they are only Dual SMP) are getting cheap, and they
scream compared to the 1500.
As for other CPU's, I like the idea of the AMD's, but they dont support SMP.
I have the dual 133/166 board. On the 1500, the system speed is determined
by the processor card, and the cpu multiplier. A P5/75 board runs at a
system frequency of 50Mhz, with a 1.5x clock multiplier. the 133 is a
66.6x2.0 and the 166 is 66x2.5. always opt for the higher system frequency,
and if you choose to run a dual config, make sure that the chips have
compatable stepping values. so, you could actually put 2 chips in there that
have 66Mhz frequencies with 3.0x and 3.5x multipliers. that would give you
200 and 233 respectively. I dont think the SystemROM supports the MMX chips,
so choose your CPU carefully!
this stuff is sooooo much fun, isnt it?
Todd MCSE, ASE
eBay ~ lordcompaq
Todd MCSE, ASE
eBay ~ lordcompaq
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Horner - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I have Compaq Proliant 1500 rackmount. I want to know more about upgrade
cpu. Which cpu card and cpu tht we can upgrade. Do we ned to change any wire
or jumpers on it? I have cpu board spare number is 169174-001. Please help
me. I am very interesting to upgrade cpu.
Reid
Reid
Solution #3
man1 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Reid
Reid
Solution #4
Bomber - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Reid
Reid
Solution #5
Pasty - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
It is possible to update a proliant 1500 with an AMD processor.
My proliant 1500 is running at 300 MHZ
you have to by an slot card wich fits on the board that supports AMD
processors. I've found this card on a big PC meeting
The proliant only displays 100 mhz but the operating system displays
300 mhz.
The physical AMD processor is 500 mhz
300 mhz.
Solution #6
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
No. There is no CPU board in a 2500. While the 1500 is board upgradeable,
the 2500 is only chip upgradeable.
HTH
Todd MCSE, ASE
eBay ~ lordcompaq
HTH
Todd MCSE, ASE
eBay ~ lordcompaq
Suggest a new solution for this problem
Post a New problem for Compaq - Processor Board
Email this problem
Email this problem
Can you Help with these Processors problems?
Repair Service
Find Processor Repairman Near You:
