Question about Toshiba Satellite P105-S6147 Notebook
I have a Toshiba satellite p105-s6147 when i press the power button the blue light comes on but nothing happens even when i have it pluged in the wall with and without the battery.
    President:
  • 2,653 Answers
Majority of the time with the P105 it's the motherboard that is at fault.
You can try reseatting the memory modules to see if that makes a difference but other than that there's not much you can do but replace the board or send it into Toshiba for repair.
Posted on Mar 09, 2009
Forgot password toshiba satellite p105-s6147 how can I login?
If you do not have a reset disk, you can use Windows Password Reset ( http://www.windowspasswordreset.net ) to create one.
If you have already have one, so just do as below:
Here are the steps to use the disk for your password recovery.
Step 1: If you enter the wrong password when you attempt to log on, Windows will display a message that the password is incorrect. Click "OK" to close the message box.
Step 2: Click "Reset Windows Password", and then insert Windows password reset disk (or other removable media).
Step 3: Follow the steps in the "Password Reset Wizard" to create a new password.
Step 4: Log on with the new password.
Hope you can reset windows password soon
Jul 11, 2012 | Toshiba Satellite P105-S6147 Notebook
My Toshiba Satellite P105-S6147 PC Notebook - has two problems - The screen has thin colored lines running vertically in about 4 places on the monitor and a 3 inch wide "ghost" band on the right...
Sounds like your display panel needs to be replaced.As far as your speakers they sound to have gone bad if it plays sound externally but not on the onboard ones.
Feb 04, 2011 | Toshiba Satellite P105-S6147 Notebook
Toshiba Satellite P105 S6147 screen won't illuminate when on?
first try the fn+lcd/crt and see if it toggles on.if not then try hooking it to an external monitor. if you get the pic on the external monitor then you have a backlight or inverter problem.
Jul 27, 2009 | Toshiba Satellite A105 Notebook
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Mar 19, 2008 | Toshiba Satellite A105 Notebook
My toshiba satellite a135-s2276 won't turn on
A coworker used to work for Toshiba and said that this is common for the Satellite A135 models and under warranty the fix was a motherboard swap for a newer/updated motherboard. Otherwise the unit is unusable.
Dana
Jan 24, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba P105 S6104
Hi Ed;
This is issue has resolution as it has been published on Toshiba's Official Support Website. It seems you need to go to an Authorized Toshiba Center. They have a special tool to re-flash your BIOS and it will resolve the issue. I am adding the original text and link for the solution below
Good Luck
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1827224xml&sliceId=&dialogID=24612375&stateId=1%200%2024610494
New BIOS fixes incorrect power-on password prompt Document ID: 98082329 Posted Date: 08/21/07 Last Updated: 08/21/07 Category: ACPI, BIOS, Password Distribution: Public Applicable Models: Satellite P100-ST7111, P100-ST7211, P100-ST9212, P100-ST9612, P100-ST9412, P100-ST1071, P100-ST9732, P100-ST1072, P100-ST9762, P100-ST9772, P100-ST9752, P100-ST9742, P100-ST9712, P100-ST9012, P105-S921, P105-S9312, P105-S6074, P105-S6034, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6134, P105-S6024, P105-S6054, P105-S6014, P105-S6004, P105-S6012, P105-S6002, P105-S931 << hide Use of any software made available for download from this system constitutes your acceptance of the Export Control Terms and the terms in the Toshiba end-user license agreement both of which you can view before downloading any such software.
Issue
The computer models listed above may display a "Password =" prompt when the computer is turned on, even though no power-on password has been set. If this happens, there is no password that will satisfy the password request. If the computer is turned off and back on again, it is very likely that the same password prompt will appear. The computer will be unusable until this problem is fixed.
If the problem has not happened yet, you can prevent it from happening in the future by upgrading the BIOS to the newest version.
The occurrence of this problem on any particular computer is unpredictable -- it may never happen, but it could happen any time that the computer is turned on. If this problem does occur, it will be necessary to send the computer to a Toshiba Authorized Service Provider, who will fix the problem at no charge to you.
Resolution
If this problem has not yet occurred on your computer, then click the following link to download and install BIOS version 4.00. This BIOS displays a power-on password prompt only when a power-on password has actually been set via the BIOS Setup program.
You may also browse for a newer version of the computer's BIOS at pcsupport.toshiba.com.
For more help, see Support Bulletin 98081213 Obtaining downloads and support docs from the Toshiba Support website.
If the problem has already occurred on your computer, then please make arrangements with a Toshiba Authorized Service Provider to have this problem fixed at no charge. To locate a Toshiba Authorized Service Provider (ASP), please visit Toshiba's Global ASP Locator at http://pcrepair.toshiba.com.
Jan 11, 2008 | Toshiba Satellite P105-S6104 Notebook
Dark screen?
either it is set to use an external monitor, or the backlight or inverter is bad
Jan 11, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite P105-S6147 Notebook Logo
198 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
