Question about Samsung SGH-a437 Cellular Phone
Cell phone will not turn on when only using battery power
Phone dropped in sink of water. Opened immediately & dried overnight. Ordered new battery but did not solve problem. Phone will turn on only when plugged into charging unit sending message ''battery power low''. Shortly after turning phone on in this manner, it can be unplugged and works normally.
  • Pat Branch Mar 09, 2009
    Yes, I tried leaving plugged in overnight but still would only turn on when plugged in. Also tried procedure with new battery with same result.
  • Anonymous Mar 28, 2014
    Phone won't power up
Have you tried leaving it over night plugged and on and see if that helps? If u pulled it out of the water quickly, that might do the trick.
Posted on Mar 09, 2009
The fone was dropped in water for no more than cpl seconds...it was left to dry overnight and nxt day when switched on it powered up as normal.. however the screen has been totally unresponsive to touch...
Take battery out of phone and let set overnight in a dry area such as oven. I have turned oven on to warm and then turned oven off and let phone set in there overnight with battery out of phone and back off of phone and then replaced battery and restarted phone and it did work again. Rich
Dec 20, 2014 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
Tip
What To Do if I Drop My Cell Phone in Water?
The small convenient size of cell phones unfortunately also makes these electronics accident-prone, especially when it comes to water. If you drop your cell phone in water it is often possible to salvage it. If you drop your cell phone in water, you may have only seconds to retrieve it, so you need to act fast even if it means retrieving it from the toilet!
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. It is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open.
If you drop your cell phone in a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
If you drop your cell phone in liquid that isn’t pure water, you may want to try giving it an alcohol bath. The alcohol will displace minerals and microscopic substances as well as aiding in the evaporation of the fluid. If it is available, you should use an alcohol concentration of 95% rather than rubbing alcohol that usually contains only 70%.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If droped your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours.
on Mar 10, 2010 | Cell Phones
Batteries and phone very hot
There is a short in the phone that causes a high rate of battery discharge resulting in a overheating battery.
This cell phone is faulty and I suggest you get a new cell phone.
May 21, 2013 | Nokia 5130 Cell Phones
My n900 nokia drop into water
Wet Cell Phone
Immediately remove the phone from the water, turn off the cell phone, remove the battery and SIM card. To dry out the cell phone put it in a large plastic bag with silica gel drying crystals then put it in a warm sunny place for several days or in front of a warm fan heater for several hours. Reassemble the phone and hope it will work properly again, but if does not work then it is faulty and you need a new cell phone.
Dec 12, 2012 | Nokia N900 Smartphone
My cell dropped in water, what to do?
Wet Cell Phone
Immediately remove the phone from the water,turn off the cell phone remove the battery and SIM card. When you have driedthe cell phone by putting in a warm sunny place for several days or in front ofa warm fan heater for several hours then reassemble the phone. Hopefully itwill work properly but if does not work then it is faulty and you need a newcell phone.
Nov 30, 2011 | Nokia C601 Cell Phone
SonyEricsson T707 was dropped into water. On recovery (2mins ) later stripped outer covers off and removed battery and sim card. Used hairdryer on unit for about 20mins. Can you suggest anything else I can...
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. This reduces the risk of a short circuit which would render your phone useless. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, but fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one so as not to risk it leaking battery acid in the future.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. If you have dropped your cell phone in water, it is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open for maximum evaporation.
If you drop your cell phone in water that isn’t pure such as a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If drop your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours. Unless you have insurance for your cell phone which covers water damage, there is no point in sending it to the manufacture with the hope that they will replace it under warranty. If you drop your cell phone in water, the technicians will be able to tell immediately due to moisture sensitive stickers that are contained inside almost all cell phones. The best thing to do is to try the tips mentioned above and repair it yourself.
Jan 03, 2010 | Sony Ericsson T707 Cell Phone
I droped my voyager in water
HI,
PLEASE USE HAIR DRYER TO DRY IT AND DONT CHARGE OR SWITCH IT ON FOR A DAY....................................
thank you for using fixya,rate my answer,
vijay
Oct 04, 2009 | LG VOYAGER VX10000 Cellular Phone
Dropped my phone in sink of water
You may have caused a short in the device. Basically once your cellphone is exposed to water, the best solution would be to IMMEDIATELY remove the battery, and place the device in a bowl of rice. The rice serves to absorb the moisture, and within a day, should restore your phone :D.
It doesn't hurt to take it apart and dry it by hand though, but by trying to use a non-dry phone you may have to get a new one.
May 21, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
Samsung SGH-a437 Cellular Phone Logo
99 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
