Question about Panasonic KX-TG5632 Phone
Program hand set
Some keys stick.
Can't program hand set.
Can't store nuimbers.
    Problem Solver:
  • 14 Answers
If this is because it's been around for a while, try this.
Remove the batteries. Then take a washcloth or good cotton rag and soak it in hot water. Ring out the excess, then scrub the face of the phone (like you would use soap and a scrub brush on your hands.) Then shake off the excess water vigorously, and stand it up on a counter or table so it can drain on a paper towel for at least 24 hours. When you can pick it up and shake it vigorously without getting any more water, it's ready to put back together with the batteries and try it. This may not fix it entirely, but it may help. If it's still not working, then a similar process would have to be done after disassembling the phone.
Good luck and God bless!
Posted on Mar 12, 2009
How to program a pro - 135200 channel hand held scanner with out charging me .
  1. 1. Press "MAN."
  2. 2. Press "ENT/PGM" to put the scanner in programming mode. You will see PGM appears.
  3. 3. Use the number keys to enter both the channel storage bank and the channel number you want to assign to a frequency.
  4. 4. Press "MAN."
  5. 5. Use the number keys to enter the frequency and don't forget decimal point.
  6. 6. Press "ENT/PGM" to store the frequency into the channel.
  7. 7. you just stored a frequency into a channel. Repeat steps above until you have your scanner programmed how you want.
  • Hope this helps...
Nov 26, 2011 | Radio Communications
I have just made a new key for my 1999 jeep grand cherokee and when i try to start the jeep a little key light shows up on the right hand dash and the jeep wont stay on
  • When you made the key did "you" make it? Because the key is a transponder key, with a chip in it. You can't just go make a key and have it work. The light you are seeing is telling you tey key is not being recognized either because it is just a "cut key" or because you need to program it still.
  • To program a new key follow these directions. Please note you need two programmed keys to do this. If you do not have two programmed keys then the dealer must program it for you. Not my choice, it's the way it is.
  1. Take original key one and stick it in the ignition and turn it to on for 7 seconds.
  2. Do the same with the second original key as well.
  3. Now take your new key and stick it in the ignition and turn to on and in 10 seconds you will here a chime and after another 5 seconds turn the key off.
  4. Your new key is programmed.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 15, 2011 | 1999 Jeep Grand Cherokee
Re-program Keys
  1. Pry open the plastic key fob with a flat-head screwdriver.
  2. Remove the back of the key fob and set it aside.
  3. Hold the front half of the key fob in your hand; turn it over so the rubber buttons touch your palm.
  4. Use your finger to gently pry the circuit board from the back of the panic button; set the circuit board aside.
  5. Stick a piece of tape over the metal connectors on the back of the panic button.
  6. Replace the circuit board, which should now rest on top of the tape.
  7. Replace the backing of the key fob and press down to snap it into place.
Hope this helped.
Feb 01, 2011 | 2002 Dodge Caravan
How to change extension name in panasonic kx-t7633
depending on programming restrictions:
at ext 101
1) press "PROG"
2) "**"
3) the user programming password (most likely "1234")
4) "004"
5) "ENTER"
6) enter the extension number you wish to change
7) txt out the name (you must use the direction pad in the bottom right corner of your phone if you have 2 letters in a row that are on the same key)
8) press the "AUTO DIAL/STORE" button
9) lift hand set and hang up
Jan 06, 2011 | Panasonic KX-T7630 Corded Phone
Program mouse
Hit the LEFT-side SHIFT-key at least 5 times.
This turns on "STICKY-KEYS" within Windows,
such that touching the CTRL key "sticks" it on,
so that you can use the mouse to select items,
and then touch CTRL once more to "unstick" it.
Sep 11, 2009 | Microsoft Wireless IntelliMouse Explorer
How do I programme my buttons and how do set up the phone for hands free use. The phones were moved and the technician set all the phones to the original settings so none of the phones have hands free...
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change to handsfree.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press the next key 3 times (bottom right arrow)..
The display should say handsfree. Press the show key.(top right arrow) change from none to auto
Press the heading key (top left arrow) til the display says TERMINALS & SETS again.
enter in next extension to program.
repeat procedure.
Press the release key when finished
Sep 01, 2009 | Nortel Meridian M7208 Corded Phone
Wheelwriter 3000 -- need to program
There are three keys on the L. side of the keyboard store, play & delete that control the memory. Hold the store key and press 00-99 to set an address, rel. store type info. then press store again.
To play back press play and the address.
DickyO
Dec 12, 2008 | Lexmark Wheelwriter 3000 Typewriter
Panasonic KXT7453
To set date and time on your phone system you must first enter user programming mode.
Using a display phone with the receiver hung up.
Press PROGRAM
Dial ** 1234 (SYS PROG NO)
Dial 000 (DATE AND TIME)
Press SP-PHONE key once (display shows current date)
Normally this is correct if not dial the changes in with your keypad. Use the FWD\DND key to
move forward on the display and the CONF key to move backwards.
Press AUTO DIAL STORE (Confirmation tone)
Press SP-PHONE key once (display shows current time flashing on hour)
Dial new hour (Two digits) Use the FWD\DND key to move forward on the display and the
CONF key to move backwards. Dial in any changes and when your done:
Press HOLD (SYS PROG NO)
Press PROGRAM
Your phone should be back to normal.
Nov 03, 2008 | Panasonic KX-T7453 Corded Phone
SILLY QUESTION. how CAN I GET a WRITTEN Answers About The Key Letters F1 To F 12. What Each Function Key Means.Thank You Paul Lavigne
The F-keys are just keys. If they had proper meanings they would have glyphs assigned like @ or % or $ or R. If you want a cheat-sheet about the uses of the F-keys in various programs, take notes in a program or on paper and print a cheat-sheet out. It beats buying another screen just to display that info, epsecially with the number and variety of programs out there.
Within the scope of a certain BIOS or OS environment, e.g. the desktop or Microsoft Word in normal editing mode, they can have particular meanings. Accordingly, you can buy neat plastic templates that fit down in your keyboard (from Global Supply, or Corel, or various publishers and special interest groups) or office supply stores, and get some intuition on how to work more efficiently.
I hope I'm answering what you were wondering about!
You know, in Linux, a keyboard with multimedia volume control keys generally has to be set up so those keys mean something manually. On the other hand, you can set up stuff you really want done.
Sep 30, 2008 | Sony Computers & Internet
Panasonic KX-TG5632 Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
