Question about RCA TruFlat 27F520T 27" TV
Cold start tv picture will not stay
Untill tv has been on for more than 1 hour (gets hot) it will lose the picture to colored lines, shut it off turn it back on it works again.
  • mdfedge Mar 12, 2009
    Thanks for trying!
  • 111 Answers
To try and isolate: get a can of dust off and tip it upside down and spray one area at a time to try to get the problem to go away. Possibly you will locate the bad component, be careful and be safe..
Posted on Mar 10, 2009
My tv will work fine for say 1 minute then keeps flashing green and shuts off i have looked up the code it says its the D borad thats gone bad is there a wasy i can self fix it.
The "D board" is the flyback transformer, but if it was bad, you would have no picture at all. Here is a proven method to get it to work (for a while....)
The adjustment method is to put the set on a video input with nothing conected
to that input. Turn the screen control up slowly until those fine lines appear
and then down until they just disappear. Do this with all three colors. You
might need to turn one of them down a little initially if the set won't stay on
long enough to get to adjustments. You cannot do the adjustment on a TV station
or on live video input. If the adjustments are too high, the set will turn
bright and shutdown. If they are too low you will never get a picture at
all.
You would want to touchup the adjustments after a warmup of a few
hours, then recheck the next day when cold.
successfull and the set stays on but the color reproduction is very poor then
one of the tubes is probably bad.
If you are lucky and everything turns
out OK, you will probably need to do it every year or so.
Dec 01, 2010 | Sony KP-57HW40 57" Rear Projection...
3-D picture with color lines
Seems TV has dry/ cold solder joints (loos connections) in convergence out section.
Please check cold/ dry solder joints in convergence out section in TV, specially on pins of convergence out ICs. resolder these solder joints and all would be fine.
Sep 28, 2009 | Sony KP-57HW40 57" Rear Projection...
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
98 Buick Regal -engine quits
ok its one of two things you need to check when it cuts off if you have spark or fuel if you lose fuel pressure replace pump it gets hot and makes noise like its running but its not pumping fuel and if you lose spark you need to replace ignition control module has a hair line crack in it and when gets hot the crack expands and loses contact and wala no spark
Aug 15, 2009 | 1998 Buick Regal
Pioneer SD-P62A3 62" shuts off - won't stay on
If this TV turns back only when it is cooled down than it has cold solder joints tha have to be resolderd.
Jul 07, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Zigzag lines in picture when first turning on the tv
possoble cold solder connections breaking when unit is cold they expand when hot thus making connection.
Oct 11, 2008 | JVC AV-27530 27" TV
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
TV will lose picture then go into standby!
Yes it is a temp problem as you found out for your self Great call on that BUD.. the best thing to do is contact sharp to see if they have had simular problems and if there are any recalls on this model . If not they will instruct you where to send the monitor into to be fixed.
Mar 31, 2006 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Pt 56tw53 picture trouble
I had the same problem with my TV, It seems the high voltage trasnformer blew which in turn casued the pin cushion?? to blow. It then shuts the tv off to prevent more damage to it. $500 with service charges to get it fixed!
Nov 05, 2005 | Panasonic PT-56TW53 56" Rear Projection...
RCA TruFlat  27F520T 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
