Question about Hotpoint NVL333EY Electric Dryer
Long time to dry clothes
I have a Hot point dryer model NVL333EYOWW. It is taking about 2 hours to dry a load of clothes. I checked to make sure the vent hose was not plugged and the heating element gets red hot.
  • robert_al214 Mar 10, 2009
    I took out the drum and checked heating element. It all turns red. Once
    you start the dryer in turns few for a few seconds and then goes out it
    will come back on but just for a few more seconds. I removed the wires
    from the high limit thermostat and it turns red and stays red. I
    replaced the high limit thermostat and it still does the same thing.
    What else could the problem be??
  • Hotpoint Master
  • 8,220 Answers
The dryer has one of its rows of heaters open. Open up the dryer and check the coils behind the drum. read more
Posted on Mar 10, 2009
  • Dan Webster
    Dan Webster Mar 11, 2009
    If you have one of them bias thermostats with 4 wires on it then replace that it might be bad. also electrical breaker. If all is good then your timer is bad. Some of those timers can be fixed by taking them apart and filing down the points on the heating element contacts inside the timer. It will get a burr and half way work.
  • Dan Webster
    the 2 small wires are suppose to heat the stat up to make it shut down the heat faster for kit and permapress. They get whack, it is pretty cheap, change it.
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Clothes take.2 hours or more to dry
Check to make sure that the dryer vent is clean. Most of the time when the clothes take a long time to dry it is the vent. If the vent is clogged then it cannot circulate the air inside the dryer. Also check underneath the lint filter to make sure it is not clogged as well
Jul 12, 2011 | Frigidaire FEX831CS Top Load Stacked...
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
LGR5636kq0 model. not drying clothes reasonable time
It could be the tumbler. Also check the vent coming from the back of the dryer (make sure it is not clogged)
Nov 10, 2009 | Whirlpool LGR5636L Gas Dryer
NOt drying clothes like it should
Has air flow problem, check to make sure the vent going to the outside is not blocked. If it isnt, you should be able to take off back cover of dryer. Should be a duct that air goes through, take it apart and make sure there is no lint in bottom of it. I had the same problem and that fixed it.
Apr 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Hot point model nvl333eyoww will ot dry clothes
your dryer has a belt switch go here to see it www.repairclinic.com once there enter your model # and it will show you your parts
Mar 10, 2009 | Hotpoint NVL333EY Electric Dryer
Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Jan 08, 2009 | Maytag MDE2600 Electric Dryer
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer sometimes works other times doesn't
Check and make sure there is not lint build-up in the venting hose leading to outside. This will cause longer drying times and can be a fire hazard. Also, if you use the Aluminum venting hose instead of the white plastic it can cut up to 30 min. off your drying time. It is a lot safer then the white venting hose which can also be a fire hazard. Make sure all the lint is cleaned out from the inside of the dryer where the venting hose is connected. It could be a clog there. This sounds more like the problem since the clothes are actually drying but it could be a partially burnt out heating element. Good Luck.
Dec 16, 2007 | Frigidaire FEX831CS Top Load Stacked...
Hotpoint NVL333EY Electric Dryer Logo
251 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
