Question about Electrical Supplies
Generator won't start
My generator (MQ Power Whisperwatt generator model DCA-45SSIUII)was running during a power outage and it shut off and will not start back up. The oil and water were fine. It was about 20 degrees outside at the time. It did not run out of fuel. It usually starts with just one turn of the motor. I did spray ether in her and she did crank up for a second. Thanks for any advice. Wayne
    Problem Solver:
  • 11 Answers
Some of the generator has a control or tripping device like over speed, over voltage, overload or overcurrent or other trip device, try to find & reset it.
Posted on Mar 21, 2009
Anyone know how to fault find a 1968 C6tfl powered petbow generator 3 phase 187.5kva that only generates electricity when it feels like it!!??? - power across 2 phases drops to between 80-245 instead of...
Did you exercise the generator or did you only start it during a power outage. If you don't put a load on the generator, when you need it you will get the problems that you have. Most generators this size have a resistive load bank that puts a load on the generator to exercise it. If you don't have a load bank to exercise the generator, turn your main off and let the generator take the load on at least once a month. This may solve your problems.
Sep 22, 2017 | Electrical Supplies
Choosing a home generator to use in the event of outages
if you can afford a real standby genset id get one of those. reasoning is this way you do not have to store gasoline and rotate it every few months. and if you have a backup style genset you may not be able to get fuel for it when your supply runs out. that and you have to hook it up when the power goes out. safely hopefully. they are sized depending on the size of your power needs. most places that sell them will come to your house and tell you what youd need. easy stuff
Sep 17, 2017 | Electrical Supplies
Electric company shut off electric to my neighbor -can he run a generator for electric legally?
This depends on where you live and Local Regulations... But yes it is possible to run a House from a Generator...
I have a generator on Standby for Electricity Outages... I am on Oxygen full time so Need my Electricity to remain ON all the time... You probably need to get a special Lead to go from the generator to somewhere that will supply it to the House.... I have my Generator hooked in Permanently by an Electrician
Jan 04, 2017 | Green Living
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Jun 21, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
Need to know if I can run my fridge on small generator if there is power outage. Generator is 1600/1650 Watts; Amana fridge model TC18HG nameplate says 6.5 Amps. But I'm unsure about the starting...
Hello Bob,
There should be absoluty no problem on that 1600 watt generator..at max when compressor just starts its drawing about 750 watts, that is the max usage when running its about 500 and on defrost its like 850 ..so on 1600 watt generator no problem
Aug 25, 2011 | Amana Refrigerators
I have a generac 22kw model QT02224anan that will run for a few minutes then shut down , then the over speed led is lit. It only happens when it is under load or during a power outage. it goes through...
its possible the overspeed is set to sensitive. or your rpm are to high. these are preset in the factory as a safety, check your manual to ensure your rpm speed is in the pre set area. generators will do this under load when you have a big load on them or take a load off. the governor will some times over compensate causing it to trip on overspeed.
Aug 10, 2011 | Generac Power Systems Generac QT02224 22...
My Coleman powermate generator 6250 won't start. We used it last month when we had a power outage during the coldest of winter weather. We checked the oil, gas compartment and found that there was...
Make sure the sparkplug is clean and gapped. Unloosen the float bowl slightly and drain about a half cup of gas out of the bowl. It is possible a little condensation got in to the fuel. Tighten the bowl nut slightly and try to start the generator.
Mar 10, 2011 | Heating & Cooling
Mq whisperwatt 25 k with izuzu engine has new airfilter good on fluids good air flow fairly balanced on 3 phase 240 between 32 amps and 36 amps all legs. running hard at like 1700 rpm supposed to be 1800...
Although packing it in dry ice could be an option I would recommend checking the thermostat and the coolant pump. Check to see if the hoses have pressure in them by gently squeezing them just as the engine is warming up. 100-105 degrees. Be careful after that. If you don't have callouses ;) Good luck
Joe
Feb 18, 2011 | Diesel Electrical Supplies
Electrical Supplies Logo
443 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
