Question about Mcintosh MC602 2-Channel Amplifier
Mcintosh mc7150 lights dim on higher volume
I bought this power amp used. It looks brand new though it is 15 years old. when i put the volume half way up, the blue lights of the amp start dimming on intense music(bass) and I think  the punch is lost. the sound is clear and open but it seems there is an aging component inside . I am not an expert but I wonder if those power supply capacitors could be  the culprits . Any help would be highly appreciated. Note: I use a dedicated AC outlet for this amp
    Problem Solver:
  • 12 Answers
Yes you could be right about the power supply capacitors as they have a tendency to dry out. Another tip is to inspect the terminations of these capacitors and clean their contact points as often the screw and screw boss is a different metal and corrosion and electrolysis occurs between these and the main power supply connectors. If in doubt clean with a scotch scourer till shiny metal is exposed on connection points. Then coat contacts with electrical contact conditioner (lanolin grease is good too) before reassembly.
Some amplifiers do not have sufficient storage to sustain high bass levels into difficult speaker loads, the Mac should not be one of these however . To verify that your dedicated AC outlet is not a limiting factor - use a power board and plug an incandescent lamp into the same point as the amp and see if you see any flickering of lamp when the amp lights dim.
If no evidence of limiting of main power and connection maitenance does not solve the issue, replacing the capacitors is indicated.
Posted on Feb 17, 2010
My subwoofers in my car are not working properly, I have a Kenwood Hu, 1000 watt 2 channel earthquake amplifier brand new, 2 Sony Xplod 10 inch subwoofers and a pioneer 12 inch subwoofer. the problem is...
I just got done with 10 others like this with the same problem, just look at some of my other solutions to see what you will be doing. Basically you need to upgrade your entire charging system to run these amps, You guys are not even considering the power draw that it takes to keep these things running at full power! You need to plan out your system way before you start to buy things to make sure that you will only have to install it once and do it correctly. It all starts with the power available from your alternator. You will have about 40 to 60 amps of left over current to use from a stock alt after it has to charge the battery and power the car while driving. That means you can have a head unit drawing 15 amps and a sub amp that will draw 35 to 40 amps before you will need to upgrade your entire charging system. Failure to do this will result in Batteries lasting 1 year a new alt every summer, your amps will burn up the insides a few times before you realize the importance of this all.
Mar 30, 2013 | Car Audio & Video
I used my makita 18v 1/2" cordless drill then charged it and put it away. When I tried to use it again a month later there was no power. I tried to recharge the battery but red light would only stay on...
WOW! Count yourself very lucky. Most batteries don't last half that time. The newer battery probably has a lower amp hour rating than the first one. When replacing the battery (and you must replace it) look for the one with the HIGHEST amp hours - which is usually written on the battery or packaging. You can also ask at a Batteries Plus store if they can re-build the original battery for you- since the unit is so old, and Makita might not make replacements for your drill. You could rebuild the battery yourself,it is only 12 AA or C batteries wired together, but ni-cads can be dangerous when soldering and can explode if you slip up. Best bet is to get a new or rebuilt battery.
Jul 02, 2017 | Makita 18V 1/2"CRDLS Drill Kit
Crate Flexwave 120h (Half Stack) volume issues
Perhaps you have a bad capacitor on your volume control?
You can get an ESR meter and test your exposed isolation caps for leakage? The have to be removed so unplug the unit if you are gonna do any work inside the cabinet.
Also, try a shorter or higher quality guitar cable. This will cut impedance between the pickups and the amp.
Good luck and be careful!
Mar 08, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
McIntosh 6100 Integrated vintage 1976
Most likely, one channel is blown plus power supply capacitors have to be replaced, switches and controls cleaning, all lamps replaced. That would be an average repair on that model.
Nov 11, 2009 | Mcintosh Audio Players & Recorders
My red protection light comes on and the amp stops if i turn up the volume on the head unit more than just a little. the settings on the amp are not more than half way up. all other lights are working....
sounds like you need a farat cap, your drawing more power than your cars gerating system and put out....does your stereo dim when the bass hits?
Oct 20, 2009 | Sony Car Audio & Video
Volume reduction with same input ( 4 years old),
What are you using to feed the sub? Are you sure that the signal level you are presenting to the sub is the same?
Dan
Jul 31, 2009 | Mackie SWA1501 Subwoofer
Brand new router works sometimes
the wall plug type power supply (made in China) may be likely bad.
This actually is a switch mode power supply very unlike the old and usual linear power supplies.
It is common the capacitors used in this supply are under rated and do not last very long.
The problem usually seen with dim LED lights on the unit, limited range and intermittent operation.
Try to find a replacement power supply with perhaps higher current rating.
Good luck
Jan 10, 2009 | Linksys Wireless-G WRT54G Router
JVC Car stereo with cd shuts off when volume is turned up
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
Dec 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
Buzzing bass Amp combo
The problem you have mentioned is a common one with old sets, but it also occurs in new ones also, though not frequent. You can fix this just by changing the electrolytic filter capacitors in the power supply and sub filters on the amp PCB. The new capacitors should be of the same or higher voltage rating and same capacity rating as of the existing ones. And as it is such an old one, it is better to change all the electrolytic capacitors to avoid any further problems.
Nov 23, 2007 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Mcintosh MC602 2-Channel Amplifier Logo
502 people viewed this question
Top Mcintosh Audio Players & Recorders Experts
 Grubhead
Grubhead
Jay Plesset
Steve K
Are you a Mcintosh Audio Player and Recorder Expert? Answer questions, earn points and help others
