Question about Peavey EQ215FX Home Equalizer
Old peavey amp cutting out
I have a pretty old peavey bass amp and it cuts out alot. whenever i hit it on the top it sometimes works. it will work at very low volumes.
  • danospizza Apr 22, 2009
    I have a KB100 Peavey that has the same problem. Had it in the shop a month ago and they said they fixed a couple of loose connections, but the problem showed back up in the middle of a gig. NOT GOOD! I can also play at lower volumes and when it cuts out, I have to bash the top of the combo and sometimes it comes back on. Any ideas?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Peavey Expert
  • 232 Answers
Time to resolder everything, got a good 10 power eye loupe?
Posted on Sep 20, 2014
3 Suggested Answers
arthurroger
  • 170 Answers
SOURCE: Peavey Bass Amp TKO115s
Start with a clean setting - zero cut and zero gain on the Eq. Play a song close to the amp, and then move away, playing the same notes. Do you still get the distortion? Change lower the input gain and repeat the test. Lower the output gain and repeat. Are any outboard distortion pedals in the mix, such as overdrive? Eliminate them. Run straight through from your axe to the amp. Check for any distortion settings. Set everything including reverb to zero. When the distortion disappears, this is your base setting.
Change only ONE parameter at a time. When the distortion comes back, you have found your problem.+
Posted on Dec 03, 2008
  • 211 Answers
SOURCE: Peavey TKO115 bass amp. Any help on where to buy
If you're living in the States, you can go to any RadioShack store.
They can help you, it's nothing special.
Good luck,
Gerard
Posted on Jan 24, 2010
My peavey amp worked fine. then it wouldnt turn on.
possibly it has a thermistor in the mains voltage line to the switch which cuts out when hot, I have this same problem with my Peavey TX210 combo. Pretty sure it is just the thermistor which is easy to track if you follow the mains cord wiring towards the switch and switched on light with your meter.The voltage does not get to the switch, but is stopped at the thermistor.
Sep 08, 2009 | Peavey Audio Players & Recorders
Amp cutting out when bass hits
With an amp like that you can not pull enough power from you cars battery alone. That is why when it hits hard it drains the amps from your battery and you amplifier cuts out. The light on the amplifier most likely dims when the bass hits. You need to get a capacitor. They are easy to hook up on the main power wire. You can get one from http://phatcaraudio.com/capacitors.html or get a used one off ebay.com. Good luck
Jul 01, 2009 | Alphasonik PMA1000D Car Audio Amplifier
Peavey TNT115 AMP cuts out
The problem is in amplifier section caused by change value resistor or leak capacitor or cold ,loose or crack solder joint parts this the common problem of over heating and shuts out the amplifier caused by abnormal distribution of current,try to check all the capacitor and resistor and replaced the defected parts ,so your receivers works normal again.
Hope it may help you;
Regards;
VOTIT
Jan 05, 2009 | Peavey Audio Players & Recorders
Wiring my peavey 112xt subs with my peavey 2xt tops
hi don't know if you have sorted this yet, you need to wire your cables that go from sub to top +2 -2 on the speakon (on the sub end only) HTH
Jan 04, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Dec 03, 2008 | Peavey EQ215FX Home Equalizer
Protect light flashing on and off, sub cuts in and out
there is a wire crossed somewhere in the system or the sub is damaged how old is the amp
Dec 01, 2008 | PPI DCX-600.4 Car Audio Amplifier
Amp cuts out when turned up
that amp cutting out like that means that its probably shot and it time to start looking for a new one
Apr 09, 2008 | Directed D800 Car Audio Amplifier
Amp cuts off
You may have a problem with the power source feeding the amp. You need to check the voltage across the amplifier's B+ and ground terminals when the amp is playing/cutting off. If it's dropping below ~11 volts, you need to determine why it's dropping so low.
Sep 18, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Sub cuts out when I switch to CD player?
It shuts off because the remote turn-on wire to the amplifier is connected to the power antenna wire behind your head unit. The power antenna wire is only activated when the tuner is selected. You need to switch the remote wire to the blue/white wire from the head unit (currently you're using the blue wire). This is the true remote output, and will activate the amp whenever the head unit is powered on.
Jul 06, 2007 | Alpine CDA-9885 CD Player
Peavey EQ215FX Home Equalizer Logo
384 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
