Question about Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop
Attempted to install New 320G hard drive in a Dell Dimension 3000, but the BIOs refused to see the drive at all. Despite double checking jumper settings and using other cables. The OS is Windows XP SP2, but got a screen telling me it would not support drives over 137G ?
  • joatmas Mar 10, 2009
    Western Digital 320G 7200Rpm
  • joatmas Mar 11, 2009
    It's unavailable...Sent it back from whence it came...Will try a smaller Gig drive...160 maybe...The drive acted like it was not spinning up...At All...So sent it back will aquire another and retry...What perplexed me was the XP SP2 should have support for larger drives...You may be right about the BIOs...Current BIOs on this rig is AO2...Checked AO3 is available...Will try...FOR God's sake...Do Not Try to put SP 3 on it like this...It went crazy...Was able to recover...THNXU G...Thank for your help...
    President:
  • 2,653 Answers
Check to see which bios version your computer is using. An update is probably necessary in order for the computer to detect the drive correctly.
If that doesn't work most hard drive manufacturers have software that you can install so that the bios will detect the drive correctly.
What's the make and model of the new drive?
Posted on Mar 09, 2009
  • RescueTechLA
    RescueTechLA Mar 10, 2009
    What's the exact model?
What do I set my CD-Rom Jumpers to in a Dimension 1100
Which is it a Dell 3000 or Dell 1100 ?
The jumper settings on the rear of the DVD drive; set the jumpers to "cable select" mode (if you are uncertain how to set the jumpers, check the documentation that came with your drive or look for a diagram printed on the drive itself). Insert your DVD drive into the selected drive bay and connect the IDE and power cables. Use the screws that came packaged with the drive to secure the component to the drive bay.
Dell Dimension 3000 Service Manual
http://support.dell.com/support/edocs/systems/dim3000/en/SM/sm.EXE Dell Dimension 3000 Users Guide http://support.dell.com/support/edocs/systems/dim3000/en/OM/j6758A04.pdf
Mar 02, 2013 | Dell Dimension 3000 PC Desktop
Hard Drive Upgrade to Dell Dimension 3000
Try this Boot to the BIOS
press ALT+E (single Beep)
ALT+F another beep
ALT+B system will reboot and re-detect drives
once done, you should be able to install XP on HDD
Dec 30, 2009 | Dell Dimension 3000® Pentium® 4...
My computer cannot find he primary hard drive
Hi friend,
this is not your system problem. it is your wire problem. You need to change your hard drive cable then try.
Dec 17, 2009 | Dell Dimension 3000 PC Desktop
Quantum Fireball lct 30gig not recognized in Dell Dimension 3000
Turns out this particular drive needs TWO jumpers on it, to set it to CS. I received it used with a single jumper in the Master position, but after checking the Maxtor/Quantum website, it listed the jumper positions and showed the second jumper. As soon as I installed the TWO jumpers in the correct position, the Dimension 3000 booted right up and let me reinstall Windows. I had scoured the internet for many hours looking for a solution, none solved it until I decided to check the manufacturers website. Always start there!- Solved!
May 18, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Computer will not boot, and makes error sounds
If you mean the computer is emitting a series of "beeps", then I would try reseating the memory modules. If that doesn't work, try using only one memory module at a time to determine if one might be defective.
Oct 16, 2008 | Dell Dim.9150 Pentium D 820 Dual...
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
Seagate 320g internal hard drive
Hi-
How bout on device manager? right click on my computer icon then go to manage, go to disk manager and check the disk management and configure the new hard drive
hope this helps
Aug 16, 2008 | Computers & Internet
Dell Dimension 3000 reformat trouble
please re partition the hard disk and install the operating system. if the same error continues then change the ram and try
Jan 28, 2008 | Dell Dimension 3000 PC Desktop
Used Dell Dimension 3000 drive issues
If you mean you need to install windows, you need to set your cdrom drive as first boot device in advanced bios settings or it will try to boot into a non-existent windows. Make sure your hdd is showing as the master drive, save settings and exit bios. Re-boot pc with windows disc in cd drive and hit enter when prompted to boot from cd.
Jan 26, 2007 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop Logo
145 people viewed this question
Alun Cox
