Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart dishwasher rinse buket filling water
Hobart LxiH
Rinse bucket filling with water, I check the manual there is no recommendation for check
Value.
  • 1 more comment
  • hankttt206 Mar 18, 2009
    The water is not poring out of the rinse bucket, slowly filling when the machine is working. I made sure that rinse pump is ON.
    I have the manual for the machine I see no recommendation for bucket foot value (check value)
  • Anonymous Mar 18, 2014
    Attempting to figure out why water spills through rinse aid tube. Currently have set primer pump for rinse aid off but this issue happens in either mode.
  • Anonymous Mar 25, 2014
    hobart ecomax 500 is not filling water in the dishwasher
  • 640 Answers
Can you be more specific please?
Posted on Mar 11, 2009
I have Hobard LXIH dishwasher, it is working OK but during rinse cycle instead of taking in rinse agent it is actually fill rinse bottle back with water. Rinse pump is working, it was replaced in June
Check the rinse pump. The tubing needs to come from the supply into the bottom of the pump, and the pump should be running clockwise. If the pump tube is worn, the rinse pressure will blow through the pump filling the bottle
Dec 12, 2013 | Hobart Dishwashers
Hobart LXI-H rinse doesn't work
water flow pressure needs to be a min. of 15 PSI..
Apr 26, 2012 | Hobart 25 in. LXIH-4 Built-in Dishwasher
Hobart SR24H dishwasher will not spray, arm does not rotate
ck. flow press. of water , when fill solenoid opens press. should be @20 p.s.i because this is a time fill machine. this is important .not static press. flow press. also ck the screened washers in the fill hose to see if they are plugged .let me know what you find so i can futher assist. dont forget to vote tks
Jan 10, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
E5 everytime we run the wash
Try running the drain hose into a bucket next to the machine. If it drains Ok, look for the restriction in your plumbing. If it won't drain into the bucket, look for a closed drain valve, open fill valve, bad middle or top probe, check power at drain connector ( it's DC volts from the bridge rectifier in the top drawer on the relay board.. Basically, water is at top probe at beginning of rinse, or it didn't drain down after the wash. Drain hoses can kink from hot water if not routed well.
Jul 17, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Programming LX18H for TRUE FILL AND DRAIN
The LX18 series was a compromise machine, the lack of a sump heater causes numerous rinse temperature problems due to it's increased water use (over the sump-heater equipped, fresh water rinse LX30 series).
The LX18H can be reprogrammed for true fill and dump operation. If you still need to do this, please let me know via e-mail or post a reply, otherwise a won't post the long answer!
(I worked for Hobart as a service tech. from 1994 until 1999, and have been independent since then)
Jun 24, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lx30 : rinse cycle
The rinse water in a LX30 is driven by water pressure. A solenoid valve, bottom front - gold body, opens up and allows the water to flow.
If you are referring to the rinse agent pump, there must be NO leaks in the tubing or the hose that runs through the pump. And if the unit has lost its prime, using your hand to "seal" it, and forcing water from the faucet into the line can prime it.
Good luck - Mike
May 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Rinse cycle has no water
check the sump probe under the screen and the 2 probes in the right back corner.clean them with a light grit sandpaper.let me know.
Mar 28, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LXiH
Hobart doesnt release service manuals but you can get an operation/installation manual for free here http://www.hobartservice.com/Manuals/ Im a service tech for hobart so if you have any questions let me know.
Dec 03, 2007 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
237 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
