Question about Maytag MAH8700A Front Load Washer
Maytag newtune mah8700aww will not spin ~ reads E3
We are having trouble with
our maytag newtune mah8700aww. I't
will not spin & it reads E3. Book says
hall sensor fault, Is this true?
Or may there be a different problem?
Can you help? I am out of time and
clean clothes!
Thanks
Anne Marie
  • 1 more comment
  • krees17 Mar 11, 2009
    I also have an error code E3....won't spin...help!!!
  • wjwever Apr 10, 2009
    we get E3 errors with almost every load, wiring harness was replaced and so was the motor... what is a hall sensor? what are these guys missing??
  • Anonymous May 04, 2009
    Got the same problem, not too sure what it is, but I know it doesn't have anything to do with the eductor (water draining) pump cause I just replaced mine, I'm pretty sure mine's not spinning, might be because of it's belt or drive system, I don't see how a motor like that could just go bad without catching on fire first.
    I'll check it out and repost if I can
5 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Posted on Sep 23, 2009
  • 34 Answers
SOURCE: e3 keeps poping up
Hello leggettelect,
The e3 code has to do with the Hall Sensor. This is a sensor that looks at motor RPM. There have been some issues with the wire harness or the harness connectors being loose. You can also get the code if the sensor itself is loose and cant read the motor RPM. Here is a link to a tech bulletin from Maytag explaining it in more detail and has some pictures so you can see what to check. Hope this will fix your problem.
http://www.servicematters.com/maytag_library/docs/TDL-0078A-B.pdf
Thanks,
edgin96
Posted on May 13, 2009
  • 1891 Answers
SOURCE: Maytag Front load washerMAH8700AWW.
I have a maytag mah7800 also / great machine . never had a problem yet . if you remove the screws in the back holding the top you can lift it off . inside you wil find the tec sheet . on the side in a plastic sleeve . in it is the code . it will also tell you what to do ,. mm hope this helped . let us know mm
Posted on Dec 12, 2009
  • 186 Answers
SOURCE: I have a Maytag Neptune MAH8700AWW that give an E3
Hello. This link will take you to a web page with a discussion concearning your problem. It's 2 pages long and gets a little technical but does come to a conclusion.
http://applianceguru.com/forum2/6484.html
builderdale
Posted on Jan 20, 2010
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Neptune mah8700aww has a e3 code
The Neptune can sometimes be reset. God knows the repairman for Maytag really needs to get back to work, yet to reset the cpu on your washer/dryer just unplug the unit for 60 seconds. I hope this helps you out.
Oct 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune MAH8700AWW that give an E3 error code. Is there anything I can trouble shoot thru the Service Mode?
builderdale
Jan 19, 2010 | Maytag Neptune Washer
Dec 12, 2009 | Maytag Neptune Washer
May 28, 2009 | Maytag MAH6500 Neptune Front Loading...
E3 keeps poping up
Hello leggettelect,
Thanks,
edgin96
May 12, 2009 | Washing Machines
E3 code showing sometimes on Neptune MAH-3
Mar 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Nuptune Washer
These units seem to all use the same control board and have the same issues. the intermittent and door lock issues are random and frustrating. it will take a person that wants to fix it. see this link for what to do. I have other links that explain the same.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Oct 03, 2007 | Maytag MAH8700A Front Load Washer
Maytag MAH8700A Front Load Washer Logo
622 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
