Back to:
Tags:
IBM 8mm Tape
Where to repair 8mm tape (7208-011/Exe 8205)?
By pawa - usenet poster
Other than IBM maintenance, has anyone had to have an 8mm tape drive
repaired? We have an IBM 7208-011 external drive that fails to read.
Stange thing, it passes diagnostics perfectly but fails to read any
tape that can be read by any other drive. We therefore need to send
this drive out for service. Can anyone suggest a depot maintenance
site that we can contact regarding this? And, if anyone has had this
service performed, what is the general cost?
Thanks in advance to anyone who can respond.
Bob Mariotti Financial DataCorp (FDC)
Credit Union Specialists
(860) 657-8983 voice 703 Hebron Avenue
(860) 657-8987 fax Glastonbury, CT 06033 USA
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Odud
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Are you sure that the device is set correctly (i.e. blocksize the same
as the drives that work)? If it is not the same as what the tape was
recorded with, it will fail with an I/O error. It happens all the time
around here.
Regards,
Dennis
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Where to repair 8mm tape (7208-011/Exe 8205)?:
I don't want to Accept this solution
Can you Help with these Tape Drives problems?
Tape Drives
We just upgraded our tape drives from AIT3 to AIT5. I...
Tape Drives
Inserted tapes into the tape library and put it back...
Tape Drives
My External LTO drive senses the tape is write protected...
Tape Drives
hi, I have a bright scanner s/n 52d313023071. I lost the...
Tape Drives
Performance of writing to tape has been degraded...
Loading problems.
Repair Service
Find Tape Drive Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
