OH MY!!!! We just found the problem that solves the start / fuel issues on the Maxtra Pole Saw!!!!!!!! My husband noticed the carburetor seemed giggly. He had removed the air cover and been starting it by pouring a little mixed fuel directly into it, It would run a little bit, then die. I watched the fuel line, and even after pumping it up, it would get air bubbles in the line while it ran, and then drain completely. The fuel line is really short so we both thought it just might not be far enough into the fuel -- but that was not it. He saw the two nuts inside the breather and decided to remove those and the carburetor. A little tricky if you have NO mechanical skill at all, but really pretty easy, take photos if you need to remember how it goes. He found that the manifold piece behind that had 2 bolts holding it and they were VERY loose. This created a horrible air gap. He gently tightened those bolts with a hex bit keeping in mind he did not want to strip them. (Now we wish we had used Lock-Tite). We put it back together, pumped the primer AND IT STARTED ON THE FIRST PULL!!!! First pull, ran continuously, and even idled!!!! He added an O-ring to the gas cap, used a Goof-Off cap to replace the bar oil cap, added a flat-washer to hold the plastic saw cover. Since the pole joints slip out of place, he used very short self-tapping screws (made for steel studs) to fasten more permanently. He started the holes with the screws, but then backed them out and shortened them by grinding off 3 threads. Then he tightened them. We are going to replace the fuel line with a little longer tube tomorrow. This baby will hum now!
I have seen this issue before, having trouble remembering the fix though. Is there any more info you can give me about the problem?
Thanks for replying so soon. Not really any other info. It did have an air leak with a poor carb gasket, but solved that. Stripped the carb itself which seems to be ok. Adjusted the max revs down, as it seems to cut out at high revs, but this obviously reduced the power. Even with a happy medium though, it just suddenly races and then cuts out.
Hmm... I will have to ponder awhile on this and try to get back to you. No issues with the throttle cables or linkage?
Thanks again, Chris. No problems with the throttle cables or linkages
