Question about Refrigerators
Vinotemp VT-182 wine fridge that does not get cold
I have a new Vinotemp VT-182 wine fridge that does not blow cold. The unit has no damage and the fans work, but it does not get cold. Help?
SOURCE: Vinotemp VT-60 Condenser won't shut off, unit running way too cold
It might be a sensor or control board problem. Any appliance repair place should be able to help you out with this. Or you can try contacting the manufacturer directly for help or if you need to purchase replacement parts. Otherwise, my cheapest suggestion would be to hook the cooler up to a timer, so you can turn the unit on and off maybe every 20 minutes or so. That should help keep it from causing more harm and then you can monitor the temperature with a thermometer. Hope that helps!
Posted on Sep 04, 2008
projdoc
  • 2237 Answers
SOURCE: This VinoTemp vt 60 just quit working. No
if the evaporator coils are warm, you have a leak and no refrigerant.
Posted on Aug 26, 2009
  • 14 Answers
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
Posted on Sep 21, 2009
  • 183 Answers
SOURCE: i have a vinotemp VT-12TEDi
The thermostat may be bad. Test it with multimeter set in "ohm" to confirm that is defective before replacing.
Posted on Dec 12, 2010
  • 11800 Answers
SOURCE: I have a Vinotemp VT-12TEDS-2Z Dual Zone
This cooler uses the Peltier effect = the current passing thru a very special resistance provides the cooling. Because of that there are effectively 2 separate electrical circuits inside your cooler:
1, the mains voltage that powers the Peltier element and the cooling fan - controlled by a relay
2. the low voltage that powers the control board and the display - this is the one that failed in your case.
To fix it you will have to open the front cover , access the board and test it: if it gets power then the board itself has failed; if it doesn't then its the power source and you will have to find out why it failed - probably it was damaged when another component failed and you will have to find out which one before putting a new source in.
It's a relatively complicated job that requires a good experience - if you don't have it then call an certified repairman.
Posted on Jan 08, 2011
Need to replace compressor on vinotemp wine coooler
Return the compressor and buy another wine cooler. This work is too complex for people that do not do this every day, Thanks Sea Breeze
Nov 19, 2012 | VinoTemp VT-60 Wine Cooler
Aug 25, 2009 | VinoTemp VT-60 Wine Cooler
My Vinotemp VT60 makes a clunking sound
You may want to contact Vinotemp's customer service @ 800-777-8466... you may need a new compressor
May 06, 2009 | VinoTemp VT-60 Wine Cooler
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Aug 29, 2008 | VinoTemp (VT60GNV) Wine Cooler
Wine-cicles
I found the vinotemp trouble shooting webpage that has good info for several different VT models. Here is the link. http://www.vinotemp.com/troubleshoot_pdf.htm
I emailed VT and they gave me a price for the parts
VT-TC32ECB -$34.95 (control board)
VT-60Sensor -$14.95
here is their services information
Jane Barron
Service Department
VINOTEMP INTERNATIONAL
jbarron@vinotemp.com
T 310.886.3332 x231
800.777.8466
F 310.886.3310
Mar 18, 2008 | VinoTemp (VT60GNV) Wine Cooler
Refrigerators Logo
316 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
