Question about ViewSonic Televison & Video
Viewsonic N2750W has no picture
TV has worked very well for several years. Now I have sound but no video on any of the inputs. Any simple solution? I have heard that this is a common problem with this model. Serial number is PJL052002320 and it was manufactured in May of 2005.
Allan Nutt
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
  • 90 Answers
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Posted on Feb 13, 2008
  • 286 Answers
SOURCE: Picture full of lines and flicker
Zdenko did an excellent job. Voltage regulators and the capacitors on the main boards and in the power supplies are always suspect. Some times you can narrow down the culprit buy purchasing a can of freeze spray. Let the TV warm up and try freezing suspect components to see if this causes a reaction. Thermal problems can often be found in this way.
Of course, if you're not able or willing to replace components on the circuit boards, you can always replace the main board or power supply board after determining which is causing the problem. These parts should be available at your local Viewsonic service provider at a reasonable price.
Posted on Feb 14, 2008
SOURCE: Hitachi plasma tv
you trow away you're tv and you buy a new one ok
Posted on May 14, 2008
SOURCE: VIEWSONIC VPW505 Screen flickering
Got it. I was the 'guest' who posted that I had the same problem. Not the CTRL board as I earlier thought. It boils down to the Y-SUS board (right hand side as you face the back of the display) In the upper-upper left hand quadrant you'll find a small capacitor labelled "C70".
This is the naughty one.
You can verify this by removing the back of the display, powering up and then with a small extended flame lighter, GENTLY warming C70. All it takes is about 2 to 3 seconds and the display will steady up just like always.
C70 is a surface mount capacitor, most likely 33uf at 25 volts. Haven't confirmed this yet. Will post again when I've affected the repair on my VPW505.................
BTW: This is not something you want to attempt unless you have experience with electronics. No.....really!
Posted on Dec 30, 2008
I also have the Viewsonic N2750w. I have power but when I turn it on I can very briefly see the screen and picture then it goes black, The power indicator always stays green, This happens when I hook my HP...
Follw the link below and chak out page 6 for control butons. fumction and then look at page 19 to check that you have the correct video surce type selected
Sep 24, 2017 | ViewSonic VA702b 17" LCD Monitor
How to connect digital converter box to viewsonic n2750w lcd tv
You can use the RCA cables to the input of the LCD TV so that the HD can be viewed. If HDMI is available it can be used to connect. The cable line must be connected to the box.
Nov 26, 2011 | ViewSonic N2750w 27 in. HD-Ready LCD...
I am trying to hook up my Dell inspiron 1520 to my viewsonic n2750w tv. Is there an easy way to do this?
Yes there is... You are going to need a VGA cable and an 1/8 audio cable (for sound) - On page 29 it shows a picture of the right side of your computer. You will hook the VGA cable to the VGA port (Number 8 on the diagram).
The on your tv you will hook it up to the vga port as well. Page 7 of the following document shows a pictures of the back of your tv. You will hook it up to "L" on the diagram. Be careful to not bend the pins in the connector.
Switch your tv over to the PC input by clicking the "Input" button. Then make sure your PC is sending a signal, you might have to hit the function key to switch the view.
Mar 05, 2011 | ViewSonic N2750w 27 in. HD-Ready LCD...
Picture goes away not sound ,hit the back of tv
You need to take the back off the set, with the power off, turn it on, then probe around with a long, wooden chopstick until you find the problem.
Apr 05, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
Sound but no picture, has worked for 4 years and went black. Cycling power displays video for a half second then goes black again.
LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will get the picture back.Tries websites, to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Feb 28, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
just press the "PIP" button on the remote it happened to me and i just thought that it looked familiar and i pressed it and it worked hope it helps :)
Nov 19, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Viewsonic with a black square in the midle of the picture
I spoke to someone at Best Buy yesterday because I had the same problem. In your TV functions you have a text box on. You have to change this to off or to a closed caption setting. Hope this helps.. :)
Aug 25, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
ViewSonic N2750w on the fritz
have the scaler board replaced and LVDS cabe replaced
Nov 24, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Televison & Video Logo
88 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
