Question about Kyocera Copystar CS-1820 Black and White Copier
Does anyone have the service manual for the Copystar CS 1820 Multifunction Printer?
  • Chris Kennedy Mar 12, 2009
    Please send a copy of the manual to crksolutions@netzero.net
    Thanks!
    Chris K.
  • delegend Mar 20, 2009
    i would like the manual also
    my email is delegend@hotmail.com
  • 523 Answers
Send me your email and will send you the service manual.
Posted on Mar 12, 2009
    Problem Solver:
  • 20 Answers
Indicate your problem service manual cant help, if your not really familiar with the machine
Posted on Aug 30, 2009
4 Suggested Answers
  • 5 Answers
SOURCE: kyocera cs 1820 or copystar = error message = 3200
3200 is a problem with the exposure lamp. If you are in a dirty enviroment, the problem could be dirty mirrors under the scanner glass.
Posted on Apr 09, 2009
goalie39
  • 469 Answers
SOURCE: Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Posted on Apr 28, 2009
  • 523 Answers
SOURCE: Installed upper & Lower Fuser, Turn Copier on saying paper jam 03
its not really a jam, its the cover you have to play with it on order to lock well.
Posted on Jun 14, 2009
Owners manual for copystar cs 1820
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here are the manuals / guides:
There are multiple manuals available for this, some of them refer to it as a KM-1820, but that is the same thing as the CS-1820.
Regular Operation Guide:
http://usa.copystar.com/americas/jsp/upload/resource/14773/0/1820ENOGR1.1-BASIC.pdf
Advanced Operations Guide:
http://usa.copystar.com/americas/jsp/upload/resource/14774/0/1820ENOG-ADVANCED.pdf
Printer Driver / Printing Basics:
http://usa.copystar.com/americas/jsp/upload/resource/16473/0/KX%20DRIVERENUGR-5.9.pdf
Fax System Operation Guide:
http://usa.copystar.com/americas/jsp/upload/resource/14635/0/FaxSYS-K-ENOG.pdf
Oct 15, 2010 | Office Equipment & Supplies
How do you set the fax mode to manual reception? Copystar cs-1820
i would call up kyocera tech support they would gladly help you with that question or any other operational question... very friendly bunch... or goto usa.kyoceramita.com and search for the operations guide... it will walk you through everything for the copier...
Sep 29, 2009 | Kyocera Copystar CS-1820 Black and White...
How to put an IP address on the CopyStar CS-1820 printer
putting an ip to 1820, just go to system menu, scroll down look for the network setting, you will find ip address, then fill it up.
Apr 21, 2009 | Copystar CS-1820 Copier
Kyocera cs 1820 or copystar = error message = 3200
Apr 02, 2009 | Kyocera Copystar CS-1820 Black and White...
Paper Jam
Ok, The Copystar CS-1820 is a Lemon, as an Authorized Independant dealer for Copystar. I can attest to this. This is a common problem from Copystar and their's not much that can be done. Unfornatel they should of stuck to the CS-1810 design they would of been better off/
Mar 09, 2009 | Kyocera Copystar CS-1820 Black and White...
What does C710 stand for?
GO ON LINE AND TYPE
KYOCERA COPYSTAR CS-1820 ERROR FLASHES C710
ENTER
GO ONLINE AND TYPE THE FOLLOWING INFORMATION
MANUFACTURE NAME,MAKE,MODEL SERVICE GUIDE AND DRIVERS
ROD
Feb 09, 2009 | Kyocera Copystar CS-1820 Black and White...
SERVICE ERROR c7980
The errorcode comes up when the waste toner is full.
Unfortunately the waste toner collection is in the process unit.
You will have to replace the whole cartidge.
Dec 05, 2008 | Copystar CS-1820 Copier
KYOCERA copystar CS-1820 ERROR C6000
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
Sep 22, 2008 | Kyocera Copystar CS-1820 Black and White...
Kyocera Copystar CS-1820 Black and White Copier Logo
148 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
