Question about Samsung BlackJack II Smartphone
Could i revert my balck jack 2 into factory setting
Some how my black jack 2 ,just got stucked into a freeze mode, though some times i can receive and make calls, though its on/off
and its acting insane.
  • 105 Answers
Yes you can factory reset it with this
  1. When the handset is powered off, Press and Hold the up navigation button then power on the handset
  2. Press the 1 key at the format prompt then press the Y key at the erase all data prompt
hope this was helpful:)
Posted on Nov 15, 2009
I want to revert to factory settings
To make it a factory settings, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Apr 05, 2014 | RCA Televison & Video
Hahnel Giga T Pro II remote function not working
Hi Jack,
I assume you have an answer by now but if not. Cable between receiver and camera is the issue. One of the jacks has 3 black rings on it, which must go into the receiver. The other has 2 black rings and goes into the camera.
regards
Kent
Mar 27, 2013 | Hahnel Giga T Pro Ii Wireless Remote...
I turned my unit on to "humidify" by mistake, and unfortunately it is stuck in that mode. It will not let me change modes. How do I reset this?
Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. The plug the unit back in, turn the Master ON/OFF Switch to ON and you should be able to set the controls as you'd like. Hopefully, that 15 minute timeout, gave the electronics enough time revert back to the original factory settings.
Hope this helped you.
Jul 06, 2011 | Royal Sovereign ARP9011TL Air Conditioner
Okay my problem is its stuck on 5.1ch input and anything els i do it says CAN`T USE. (M. NO#. AV-D58U)
When turning it on hold the enter key at the same time to reset the machine back to the factory settings...worked for me when I had that exact problem.
Feb 23, 2011 | Aiwa AV-D58 Receiver
Wenn I connect the coax cable the display show --------, and the Receiver can't detect the digital audio signal, even though I can mesure a PCM signal with the Osilloscope.
http://www.retrevo.com/support/Sony-STR-DH510-Receivers-manual/id/23637ci375/t/2/
Page 71
There is no sound from digital sources (from COAXIAL or OPTICAL input jack). • Check that the INPUT MODE is not set to "ANALOG" (page 52). • Check that the Analog Direct is not being used. • Check that the "A. ASSIGN" function is not used to reassign the audio input of another source to the selected input (page 53). • Set "ARC" to "ARC OFF" when no sound is output from TV OPTICAL IN jack during TV input (page 58).
Feb 07, 2011 | Sony STRDH510
Black screen on my notebook pc
Black screen encountered is due to data corruption. You cant ry booting in other boot options like safe mode by hitting F8 during strt up and select safe mode. If it works on safe mode try doing a system restore to revert it to an earlier date and time when it worked. If Everything else fails, what you need to do is to re-install your Operating System from the recovery disc provided by your manufacturer or reload the factory defaults.
May 17, 2010 | Computers & Internet
My sansa e260 turns on and shows the sanddisk page(balck and whit) then it changes and says load main image failled switch to recovery mode. so i do that and it doesnt do anything when i do,, what is wrong...
RESET: Go into the settings and scroll down to reset all, push center button, scroll to yes, push center this will restore factory settings.....
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.
This is what it states in the manual for the 260 sansa Page 29
Recovery Mode also resets system settings when unplugged...
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa. http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related here is a link to a kid showing you how to goto recovery mode.
Update software from this link..
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
and install the software before you recover
Apr 08, 2010 | SanDisk Sansa e260 MP3 Player
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
Akai PT5250A - I cannot converge correctly.
this fixed this problem
Plugs on the chassis coming from keyboard and side video input are switched (they have same plug)
redoo convergence save and auto focus in factory mode after switching plugs
Jan 13, 2009 | Akai PT5250A Television
26PF5521D wont show menu after reseting factory defaults
Switch the TV to analogue mode (if possible)
Press and hold the "MENU" button on the side of the TV. The settings menu should appear. Continue to hold the menu button until this menu disappears. (If you let go before the menu disappears, start again)
The TV should now go blank for up to 2 minutes, and then revert to factory settings and intitial installation screen.
Procede as per original installation.
Oct 26, 2007 | Philips 26PF5521D 26 in. HD-Ready LCD...
Samsung BlackJack II Smartphone Logo
89 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
