Question about ASUS Eee PC 2G Surf Notebook
Asus don't start :S
I am prees the button of power and the notebook don't start i dont no why
the windows is putting on in starting system and next is a black window and don't work in that moment frecuently is restart in that window
please help
  • 74 Answers
Hi
Try without battery with dc power direct or send me more details
Harry
Posted on Aug 08, 2009
My laptop hp compaq is not able to start it is showing fatal error as mentioned in the picture i tried to reeboot restore the computer launched startup repair command prompt is not Opening too pls help...
start computer. you see compaq sembol and prees esc key you see startup repair and prees f11 key.you can see windows is loding fills and microsoft corporaation and now you can see blue windows read and click next next next .
try this .
May 31, 2013 | Computers & Internet
System Recovery
Hit the Power Button and immediately start hitting the F8 key repeatedly until you see the Safe Mode Options. Select Safe Mode and see if it will boot up. If it does shut down normally and reboot.
Try safe mode again, and this time when it comes up click Start/Accessories/System Tools/System Restore. (If you have windows 7 click Start then type System Restore in the search box and select it when the results are returned). Select a Restore Point (date and time) before you started having problems. Don't worry, System Restore does not delete your data, documents, music, pictures videos or programs (unless the program was installed after the restore point you selected).
System Recovery on the other hand deletes everything and sets your system back to when you first purchased it.
If it happens again on the reboot, get back into safe mode again and see if you can force it to run the check disk utility the next time it starts up. In Safe Mode click Start/Accessories and look for the RUN command. Type cmd and press ok. It will bring up a dos prompt (black screen with white lettering). Type chkdsk /r and press enter. If it says something about drive is locked and it will do it on the next reboot, then select yes.
Read the Manual for System Recovery.
Get online and got to www.google.com In the google search box type: "ASUS Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals and search them for System Recovery.
May 16, 2012 | Computers & Internet
My asus u52f-bbl9 doesn't want to move past the boot screen
Have you tried booting into Safe Mode?
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
If all fails Sounds like your operating system needs to be reinstalled or you can do a system recovery to set it back to when you first bought it.
Apr 09, 2012 | ASUS U52F-BBL9 Laptop
Ok i have a asus notebook and i'm unsure why at 3am est every morning for about the past week my computer has been freezing but i can still move my mouse but when i go to close a program or window i wont...
3AM is when the Windows Auto Update program runs. Which version of Windows do you run?
Try disabling auto update:
Goto Start > Control Panel> Windows Update and click on Change Settings
Select the radio button next to "check for update but let me choose whether to download and install them"
This way the system will always prompt you for your permission before running the updates
Apr 21, 2011 | ASUS K50IJ-C1 Notebook
Hello. i have a 7"
from the problem description i guess the password which u r mentioning is for the BIOS.... u will have to contact the manufacturer to resolve this issue... they might have set a default password...
Mar 18, 2011 | Computers & Internet
Blue blank screen is my problem
Problem: An update being pushed out to EEE PC 701SD causing machine not to load to full GUI
Symptom: Machine will start to load into GUI but will get stuck after loading taskbar.
To fix:
Open the Terminal window by pressing Ctl-Alt-T.
Enter the command 'sudo apt-get remove asus-p901-system-update azurebt'
Press power button to turn off machine.
Turn machine back on, open the terminal window again with Ctl-Alt-T.
Enter the command 'sudo apt-get install asus-eeepc-core'
Restart the machine.
May 23, 2009 | ASUS Eee PC 701 Notebook
Black screen
hi,
do you see any error or does it go blank after you see the windows logo,
if it goes blank after you see the windows logo, that means that there has been software misconfiguration at the level of windows operating system, restart your system using the power button and wehn you see the asus logo at start start tapping F8 key, it will lead you to a menu that will say boot into safe mode, select safe mode and enter, see if you are able to boot into safe mode, if you are then what we can do is restore your system back to a previous date
to do that in safe mode follow the following instructions
Caution: After a system restore the configurations/software that are done after the restore point will be lost
for system restore
click on start button > go to run > in there type in without quotes
"%systemroot%\system32\restore\rstrui.exe"
system restore window will open
  1. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  2. On the Select a Restore Point page, click the most recent system restore point in the On this list the dat eon which your computer was working, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  3. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  4. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  5. Click OK.
further Queries are welcome
If you find my solution helpfull please do rate me
Feb 24, 2009 | ASUS Eee 4G Notebook
Winsock eee pc
Use system restore and go back. START ALL PROGRAM ACCESORIES SYSTEM TOOLS SYSTEM RESTORE
Jan 17, 2009 | ASUS Eee 4G Notebook
Waking up after going to sleep
I have had similar problem. I found, by trial and error, that using Windows hibernate mode actually works every time! Windows makes a "System screen shot" and stores it on hard drive and then powers off. Just be aware that you must ensure enough hard drive space for this. I am using this mode every day now.
Jun 21, 2007 | ASUS W7J Notebook
ASUS Eee PC 2G Surf Notebook Logo
182 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
