Question about Williams 2509612 Ceramic Mid-Size Heater
CHARMGLOW PATIO HEATER WON'T STAY ON MORE
MODEL SRPH02 WILL KIGHT OK - BUT AFTER 5 - 10 MIN IT GOES OUT.
  • Michael Bliss
    Michael Bliss Mar 28, 2009
    I can light my Williams wall heater and about 5 to 10 min later it goes out and The pilot light goes out also.
    Problem Solver:
  • 3 Answers
Try purging the air from the tank.
Posted on Mar 26, 2009
Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
Oct 14, 2016 | Dryers
Indicators work but don't flash. Hazards are ok. Connect 55 reg. Help
Older cars use a flasher that controls the turn signals. New cars kight use the hazard switch or turn signal switch built in. What type of vehicle?
Dec 07, 2015 | Cars & Trucks
My car Renault laguna 1999 model hatchback, stop after 5-10 min run.and start working after 10 to 15 min wait.i also note that the car exhausted more fuel then before
try this ?= renew the throttle fly by wire control inside the the car ,they go just like the way you describe ,car runs then just stops ,leave and it goes again ,trust me been their got the teashirt on this one ,some customer paid out over 2000 euros to a renault garage for the same fault and it was still the same till a little bird told me what to change ,with one from the scrappers it been ok ever since
Nov 19, 2013 | 2000 Renault Laguna Estate
Frontgate patio heater, serial number 01A02 0023562, model number SRPH02, cust number SHCDPH, pilot light won't light (checked gas tank already)
First check that you are getting a spark, if not check lead and ignitor. If getting a spark make sure that there are no leaks, to do a gas leakage test see Patio heater problem solving. Next check the tilt switch if fitted, just short it out by joining up the two leads. If OK look for any debris/insects around the pilot and clean. A worn thermocouple will turn the gas off, these can last anywhere for 2 years up to 6 years but will at some point need replacing.
May 18, 2011 | Frontgate Stainless-Steel Outdoor Patio...
Light does not go on replaced burned bulb light still does not kight perhaps swice?
do u have a tester to see if u have juice there. if not just pop switch out and go around it then it will be the switch. ok.
Feb 11, 2011 | Refrigerators
Pilot light on my Charmglow SRPH02 patio heater will not stay light in order ot light the burner. I have tried all of your suggestions in the manual except replacing the Thermocouple. What is that? I...
The themal couple is probably the culprit. You will see one end of it hanging into the pilot. The pilot heats that end creating a small electric current that allows gas valve to operate. There is a small copper line from the tip near pilot other end goes into gas valve. You can buy universal replacement kits. Usually around $15.00. RV parts store good place to look.
Sep 29, 2010 | Garden
Charmglow 810-7400-S Propane Grill: have a charmglow patio heater, the pilot comes on ...
I have a Charmglow Patio Heater Model SRPH02, it needed a Thermocouple and searching the net was hard to find an ariginal part, but here it is, call 1-866-814-0585 $3.95 +6.00 shipping the original part.
May 16, 2010 | Brinkmann Charmglow 810-7400-S Propane...
Where can I find a thermocouple for a charmglow patio heater
Aug 29, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Charmflow patio heater will not fire
turn the knob on very slowly just enough to fire up the heater. once it is fired up slowly adjust it.
Apr 24, 2009 | Brinkmann Charmglow 810-7400-S Propane...
Williams 2509612 Ceramic Mid-Size Heater Logo
379 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
