Question about Sony KDF46E2000 46" Projection HDTV
Projection lamp nearing end of life replace lamp still coming on
Projection lamp nearing end of life replace lamp soon was showing on screen. we replaced lamp but projection lamp nearing end of life still showing on screen please help
  • 1 more comment
  • Scottie 99 Mar 09, 2009
    THank you so much The model is a 2006 KDF 46e2000 I do need help on resetting the counter. You are a life saver because we have not received any help until you came through.
    Thanks so much. It worked!
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    What is model and brand of your TV?
  • 4,234 Answers
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Posted on Mar 09, 2009
The screen goes black and the green indicator lights flash, after a few seconds the picture comes back on. This has happened about 4 times w/in the last day. sony kdf-55xs955
Most common resolution to this is to replace the lamp. When nearing the end of life cycle for the lamp, it will either warn you with a "Low Lamp Life" on the display or cycle power on/off. Replace the lamp and the problem should stop. Other possibility AFTER you replace the lamp and have the same issue is the ballast board. Not as common, but it happens. Your lamp has a life cycle of approx. 6000 hours, give or take. Replace with ONLY the Phillips factory bulb. It should be The XL-2200 and can be found on EBAY Google Shopping etc. for anywhere from 120.00 for just the lamp to 190.00 for lamp and housing. It's easy to replace and comes with instructions. Hope this helps
Feb 13, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
MY LG MODEL RU52SZ30 ( 2003), HAS A YELLOW LIGHT SHOWING BELOW THE LAMP ICON. IS THE LAMP BAD? IT STILL LOOKS PRETTY GOOD ON SCREEN EXCEPT FOR THE A BLUE TINT AREA ON THE RIGHT SIDE OF THE SCREEN
Yes, the lamp is nearing the end of life when the lamp light is a steady orange (yellow). Order a new one and replace it. (When other parts of the lamp system fail, you will see a blinking red light.)
I hope this helps.
Oct 14, 2010 | LG RU52SZ30 52" Television
Powers off with a blinking standby light for 45 blinks
Yes, its clear symptoms of weak lamp that is going to end of its working life, soon tv will show you lamp light.
Replace lamp to solve the issue, lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
May 25, 2010 | Sony KDFE50A10 50" HDTV
When I turn the TV on, it has good picture, then 30 seconds the screen goes blank, then 30 seconds later it comes back on. Repeating this continuously. What do I need to do.
Its time to replace Lamp in tv as current lamp is near to an end of its life and causing this problem.
Lamp replacement is easy and user level job, procedure would be mentioned in user manual.
Please buy Sony original lamp for better picture quality.
Let me know if you have additional question.
Thanks.
Apr 12, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
What does it mean by projection lamp is nearing end of life? how can i fix this?
Ur tv have bulb,it a lamp that project the picture.It have life spans about 1400 hundred hours.It come close to the time near the end.Change another lamp when the front LED lamp indicator flashes.
Mar 17, 2010 | Sony KDF46E2000 46" Projection HDTV
Sony projection lamp is nearing end of life
Here is a link to a website that sells the replacement lamp for $99 dollars. http://electrified.com/Catalog/Items/?CampaignID=Dealtime&ItemID=36414
There might be a local store in your area that carries replacement lamps but probably will not have yours in stock and would have to order it. After you replace the lamp you will need to reset the lamp timer for your TV using the lamp replacement option on the TV general settings menu.
Jan 09, 2010 | Sony KDF46E2000 46" Projection HDTV
When i turn tv on i get a message that says projection lamp near life end please replace soon. what is this & can i replace this or do i need to have someone come out to replace it
You can do it!! Unplug the tv.If you look on the side of the set you will find a small door, open it. You should see the bulb, you can order a replacment from www.purelandsupply.com/Sony-DLP-TV-Lamps.html all you will need is your model #, it will come with step by step directions for replacment, good luck
This will be an easy fix, Trust me
Jul 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
Sony KDF46E2000 46" Projection HDTV Logo
1,102 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
