Question about Meridian Lands Phones
I've got on old meridian phone system in our office, trying to change the clock on the display.
  • bolhuis69 Mar 10, 2009
    hi there...so it's M7324...I'm trying to figure out how to change the clock on the display. Do manuals even exist for these phones anymore, they seem so old.
    Thanks, Shirley
  • formulacoop May 11, 2010
    Can you look on the bottom of the phone for a model # so I can provide the correct info for your phone system? Look for something like M7324 - M7310
TallBourbon
  • 30 Answers
SOURCE: Merian M7324 display name
you would need to get into the admin programming to change the name, have your system admin person make the change for you.
Posted on Jan 07, 2009
consultel1
  • 860 Answers
SOURCE: Find free complete user manual for 7310 Meridian Norstar system
The 7310 is a phone model number. The system is going to be a CICS, MICS, or a BCM. If you look on the top corner of the box it should be there. Once you find out the model go to http://pdf.textfiles.com/manuals/TELECOM-F-R/
that should help with documentation.
Posted on Feb 13, 2009
consultel1
  • 860 Answers
SOURCE: Old reception phone now regular office - reprogram
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear& ring
press the Chng key till it says appear only
press next key (lower right arrow)
The display should say line 002: appear &ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Posted on Oct 27, 2009
Phonesmith
  • 113 Answers
SOURCE: Im trying to change the clock on phone system. I
Hello, the default password is 1234. If it does not work with PROGRAM *# try with PROGRAM ** as described in the steps below:
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
Posted on Mar 29, 2010
SOURCE: Adding new extension to Nortel Norstar Meridian Phone System
They should have terminated your voice on a block in your phone room. If that is the case you now need a punch down tool and a spool of cross connect wire. You would punch down one side of the cross connect wire on the tip and ring of the switch pairs and the other end of the cross connect wire on the blue pair of your station cable.
Posted on Sep 21, 2010
Meridian 7310 - Issues
Mod cord, cable, jack or system port issue, call in your local tech/vendor to repair it.
Nov 13, 2012 | NorStar Meridian M7310 Phone
Meridian M8X24-DS System Problem - All handsets are blinking on all lines
Sounds like a defective software cartridge
try a swap and see if flashing stops
Nov 26, 2007 | NorStar Meridian M7310 Phone
Hello. Can I make the Extension Numbers stay with the phone jack instead of the phone? For example I got a new phone and moved the old one to another office and it still wants to keep the old extension...
Of course it's possible, however, you need to turn off Auto Set Relocation. I'm not sure if it's an Administrator or only an Installer function.
There is a trick....and I've never tried it because I HATE ASR, if you unplug the old phone, move it to the original location, and wait at least 5 minutes, then unplug it from the original location and plug in the NEW phone before you plug in the phone you just unplugged, the new phone will become the old extension and your original phone will be unprogrammed. It also says you have to wait at least one minute before you can change the DN of a new phone, but that requires INSTALLER access.
Like I said......
Carl
Jun 14, 2011 | NorStar Meridian M7310 Phone
I have been assigned an office with an old Meridian NT4X36 telephone. It has not user guide available and I need to know how to transfer calls - there is no transfer button on it. Thank you.
When on a call you would like to transfer, try pressing the FEATURE button then dial 70 followed by the extension number you are transferring to. Typically the transfer button is one of the programmable buttons, try pressing the FEATURE button then dial *0 and press one of the programmable buttons to identify what it is programmed as.
Jan 26, 2011 | NorStar Meridian M5209 Display Phone
Change date & time on meridian M2616
how do I change the time on the phone from 24 hour clock to 12 hour clock
Aug 16, 2010 | NorStar Meridian M2616 Phone
Are you able to move or change extensions?
First, move the telephone sets back to where they were.
Next, we'll have to change the system programming.
Programming2.gif is done on 7310, 7324 and 7316 type sets.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the next key 7 times(bottom right arrow).
The display should say system programming.
The display should say hunt groups
Press the next key 2 times(bottom right arrow) .
The display should say Featr Settings
The display say Backgrnd music2.gif.
press the next key 20 times (bottom right arrow)..
The display should say set relocation.
Press the chng key. change from N to Y.
Press the release key when finished
Move sets from their old locations to their new locations
Sep 28, 2009 | NorStar Meridian M7310 Phone
Jan 02, 2009 | NorStar Meridian M7310 Phone
Need to change the names on display within the office alls
You have to go into programming under sets, and change the name. If you are unsure how do get into the system admin, then I would call a professional in, as you can do more harm....
Dec 17, 2008 | NorStar Meridian M7310 Phone
Lands Phones Logo
133 people viewed this question
Top Meridian Lands Phones Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Meridian Lands Phone Expert? Answer questions, earn points and help others
