Question about Coleman 10' X 10' Sundome Tent 9160K101
Does coleman 8960 jumpstarter use a 12v converter to charge?
I have an old 8960 coleman leadacid battery jumper, I can't find the charger that goes with it, is it a standard 12v wallcharger and is there a Mv requirement?
2 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: In the Coleman 5312 Retro Series Lamp is it
Brentonb, In the event that you don't get a direct answer (which is likely, since this is a pretty obscure question) I suggest you troubleshoot it this way. Remove the bad battery. Use the charging device that came with the lantern and wire it temporarily to the device in place of the battery. This will supply the correct voltage, but takes the possibly shorted battery out of the circuit. If you are certain you have the polarity correct and you know that the charger works, then you have your answer. good luck.
Posted on Dec 03, 2010
Hi i have a colman hot water on demand but have lost the 240 volt charger.i was wondering what milliamps or amps it needs to puchase another one from a elec store.
Coleman Charger mine is a 240~volt ~50Hz 12V~600mA
my other is a 240v ~5oHz 12V~1mA battery should only be( 6V4.5Ah)
with a 1mA hour change should only be 4 hours to charge as its a fast charger.
Jan 27, 2012 | Coleman Hot Water On Demand
Battery died, charged it took it for a drive half way back home dashboard lights went out heater also went out van almost died, when we finally stoped to park turned it off then decided to try again and...
Take your battery in for testing after charging it. Then, to avoid pulling the Alternator for nothing, drive to a local Autozone, Advance, or Oeilys and ask them to check your charging system on the Van.
Consider taking an extra battery if you have one to fit, so you can get back home after the test. Run the van with the charger connected until you get good heat, then reduce the blower fan speed to minimum. Then disconnect charger.
If you are still stuck on the road, jumpstart the van until it is warm, using the jump car to charge the battery so you can go home and try again. Just leave the battery jumpers connected to the struggling van battery a few minutes so the old battery has a chance to charge.
Jan 19, 2012 | 2000 Ford Windstar
I have lost manual for clarke 4000 jump start having never used it since purchacing,how do i charge it up,is it with the start switch turned on or off.i would be grateful for any help or can i download a...
The manual for the Clarke 4000 is available here: http://www.clarkeservice.co.uk/manuals/jumpstart/jumpstart4000.pdf .
You can charge the unit either with the 230V DC adapter plugged into your wall outlet or by using the 12V adapter plugged into the cigarette lighter (assuming the battery is good) of your vehicle.
If you are using the wall outlet, plug the end of the power cord into the charger then plug it into the wall outlet. Then turn on the charger. Disconnect when the red charging LED goes out. (If you press the TEST button, you can find out the state of the battery. After a number of charge/discharge cycles (even when unused), the battery will need to be replaced every few years.)
I hope this helps.
Sep 21, 2011 | Garden
Hello, Leoch 12V battery, DJW12-12Ah, is no longer charging. We bought a John Deere riding toy at a local Toys R Us in Michigan three years ago. My children have only used it for two summers and is...
Sounds like a battery problem.
Lead acid batteries should to be charged every 3 or 4 months even if they are not being used, or they can slowly self-discharge and will start to deteriorate if the voltage drops below about 12.2v (for a 12v batt.)
They can then be difficult or impossible to charge. The charger can see this as fully charged and show green.
You can test for this if you have a voltmeter. You should be able to work out if it's the battery or a connection (or the charger).
Measure the battery voltage (use a DC voltage range greater than 12V). The normal voltages you should see:
A) Key off, no charger: >12v, <14
B) Key off, charger connected: >12, <14.2, but higher than A)
C) Key on, no charger: >12, <14, but lower than A)
If voltage A) is low and immediately goes high when the charger is connected then the battery needs replacing.
If A) and B) are exactly the same then it could be the charger is not connecting or is faulty. Measure the charger output, should be >13.8v (unless it's an "intelligent" charger in which case it might need some voltage applied to its output before it starts charging).
Note: If A) and B) are low, say <8v it's possible that an "intelligent" charger will refuse to start charging. In this case it's probably worth jumping the battery to a good 12v battery (e.g. car). Be very careful to connect the batteries (+) to (+) and (-) to (-). Leave connected for 10 - 20min or even overnight and then disconnect jumper leads and check A) and B) again. Sometimes a battery can be recovered by this method (it's unlikely to regain full capacity though).
Jul 19, 2017 | Lee-t.com Facebook Apps
I have a 5000 w maxa ER generator that has a battery assist added ( PM 0525312.17 ) Question...Is the battery a regular 12v car battery, or maybe a lawn tractor battery?? Once the generator is started...
Replace battery with your choice of 12v products considering physical size, amp range and warranty. Lawn tractor batteries seem to have the least life/duty cycle. There are two methods of charging the battery used by Coleman. One is to charge the battery with charger/alternator coils installed under flywheel of the engine and second is to charge with built-in circuit in generator itself. Examine your wiring diagram to discover which you have. Simple test with volt meter will show if system is charging. Test voltage at battery with engine off, then start engine and retest looking for slightly higher voltage indicating charge. The charging system is like a trickle charger and not like your auto with initially high amp charge then taper to minimum. If your run your generator for long periods of time and you feel that the battery is being overcharged, then rig a switch to stop charging after one hour or longer. Good holiday
Nov 27, 2010 | Coleman Powermate Powermate 5000W...
Hello. I have a duralast jumpstart kit. After
Hi, usually after you drain the unit down it will take up to 4 hours for it to charge up 100%. but do not leave it on the charger all the time when not in use because this decreases battery life.
May 23, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Dead Battery wont even stall should I charge it using jumper cables??
You can jumpstart using jumper cables. Then drive car around to get battery charged back up or get a battery charger and charge battery.
Jul 17, 2009 | 2008 Pontiac Grand Prix
Old battery not charging plug in charger green light goes out
If the system will not power on, and the LED on the AC adapter goes out when plugged into the system, then the most likely senario is the motherboard has failed. Remove the battery, Wireless card, Drives, RAM and connect the AC adapter see if anything changes. If no change, the MB is most likely bad.
May 01, 2009 | Dell Latitude D505 Notebook
Coleman 10' X 10' Sundome Tent 9160K101 Logo
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
