Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Message Upon Start Up of my Computer
I get a message ATI video bios poller client. Ox7c910edw application error. The memory could not be read." Cancel to debug.
I tried cancel and it does not debug the problem
What the heck is this and how do I make it go away?
  • 271 Answers
Download the updated drivers of your ATI graphics card.Then install them and restart your pc.
Posted on Mar 10, 2009
MAPI error message when import or export messages in Outlook Express
·You import mail from Outlook into Outlook Express, but you removed Outlook from your computer before you tried to import the mail into Outlook Express.
·You configure Outlook Express to be the default Simple Messaging application programming interface (MAPI) client.
·You import or export mail from Outlook Express, and you do not have Outlook installed on your computer.
To resolve this issue, try one of the following methods, as appropriate for your situation.
Method 1: If you want to use a special program you can use Outlook Express Fix Toolbox
https://www.fixtoolbox.com/outlookexpressfix.html
Method 2: Change your MAPI Settings
Configure Outlook Express to not be the default Simple MAPI client before you import the mail items. To do this, follow these steps:
1.Restart your computer, and then start Outlook Express.
2.On theToolsmenu, clickOptions.
3.On theConnectiontab, clickChangeto open theInternet Propertiesdialog box.
4.On theProgramstab, click an e-mail application other than Outlook Express in theE-maillist. ClickApply, and then clickOK.
5.ClickOKagain to close theOptionsdialog box.
6.Exit Outlook Express, and then restart Outlook Express.
You can now import or export messages.
May 31, 2016 | ErrorExpert
Trying to load Google chrome and I get 0xc0000a5 app wont start error
Hi There
You do not mention your Operating system, or specs of the computer. That error message is normally a RAM message indicating that part of RAM cannot be read. It might also that your virtual memory is low. Try closing alother applications then run Google Chrome again.
Andre
Sep 17, 2011 | Computers & Internet
Hi! i'm getting a message ATI video bio poller client: Ati2evxx.exe-Application Error, and in the message box it says the instruction at ''0x7c911129'' referenced memory at ''0x008c3005''. The memory could...
Uninstall your Graphics Drivers and reinstall after a reboot. Also clean
out your \Temp folders by deleting all files and sub-folders not currently
in use at the end of the day. Then run Disk Cleanup.
Also run your Windows Registry Cleaner. This will help speed up your PC.
Schedule a Chkdsk /f and reboot to run.
Run your Defragmentation program.
Mar 30, 2010 | HP Compaq Business Desktop dx2200 - P4 524...
Application error message
This msg caused by the Memory problem. Sometimes System can't Accesed the your computer RAM properly or may be your RAM is not giving good performance. pls replace your RAM accordigly..
Dec 26, 2008 | Microsoft Windows XP Home Edition
Graphics card causing system to shut down?
Please go into the BIOS of the system and Set the BIOS as default
  1. Restart your computer.
  2. When the computer first starts, it performs the power-on self test (POST). This test checks that all connected devices are functioning. As part of the POST, the memory is checked. During the memory test, a message will appear that tells you how to access the BIOS. For example, you may see the following message or a similar message that explains how to start the BIOS setup: PRESS DEL TO ENTER SETUPIn this example, you must press the DEL key immediately after the memory test is finished to start the setup process. You may have to press the key several times to make sure that you access the BIOS setup.
    Tip There are other keys that may provide access to the BIOS. They include the following:
    • F1
    • F2
    • F10
    • CTRL+ENTER
    • ALT+ENTER
    • CTRL+ALT+ESC
    • CTRL+ALT+INSERT
    If you are not sure how to access the BIOS setup, see the user manual for your computer's motherboard.
  3. Look for the Set BIOS as Default settings. You can usually use the arrow keys to move through the menus and settings.
Do that and then try to
Regards
Dec 22, 2008 | Power Color ATI RADEON 9200 256M DDR...
Problems with Dell Inspiron 9400 Video Memory conflict -
Your video card memory went bad, has to be replaced,
You have to have it serviced, you can take it to Best Buy to have it serviced if you don't want to pay the premium from the vender!
Dec 21, 2008 | Computers & Internet
I have to hold down keys for 2-3 seconds to type. How to correct?
It might be due to a service called "ATI Hotkey Poller" running
which is intermittently slowing the keyboard typing down.
To disable it in Windows XP Home:-
Go to Start->>Run->>type "msconfig"->> click the "Services" tab->> uncheck Ati Hotkey Poller->> Then Ok, then Restart computer.
hope this helps
chris
ziraffa@hotmail.com
Dec 15, 2008 | Toshiba Satellite A105 Notebook
I got a thinkpad 2635 yesterday from a friend and upon powerup it displays an error message with 00161 and 00163 printed under it with two options ok and cancel what do i do to get into this thing
These error message relates to the BIOS and it appears the BIOS battery requires replacing because it is flat.
error 161 usually BIOS has lost its configuration/ checksum error.
error 163 usually BIOS clock not updating.
Replace this battery and go into the BIOS setting and configure the date/time settings, and hardware settings (if you are not sure select the factory default settings) save and exit
Dec 12, 2008 | IBM Thinkpad T20 Notebook
Keyboard lag
Does external kybd do same? if yes, ck disk space (c: properties) and mem usage (task manager-performance)
IF No, then you may have a bad kybd...suggest shop replace-easy fix to screw up :(
Dec 09, 2008 | Dell 0Y3740 Keyboard
Windows start up
Hi Booty - this might be the Netsky virus. Follow the link below for a removal tool. Read the instructions. If you need help with this just add a comment. If this solves your oroblem please rate this as fixed. If it doesn't help, DON'T RATE YET, just add a comment and I'll help you further. Thanks.
http://securityresponse1.symantec.com/sarc/sarc.nsf/html/w32.netsky@mm.removal.tool.html
Jeff
May 11, 2008 | Dell Microsoft Windows XP Home Edition
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
