Question about Logitech Harmony 880 LCD Remote Control
Television input doesn't always match activity
When I have pushed an activity like watch TV or TV2 which is my TiVo the televison doesn't always go to the right input and I have to push the hlep button and somtimes the channel change button before it works. Thanks for your help
Depending on the type of tv you may need to count the TV tuner as an input. My bro-in-law had the same problem. The TV has 5 inputs (S-video, HDMI, etc) but when you set up the remote you need to tell the remote you have 6 inputs, one for the TV tuner.
I hope that helps.
Posted on Mar 10, 2009
Dish remote 2 changes channels on both tvs and dish remote 1 changes channels on both tvs
Is the receiver in dual mode? Go to the receiver, open the door, and hit the mode key. If both TVs are still showing the same thing, then the issue is not the mode.
Go to TV 2 (the one without the receiver) and make sure the TV is tuned to channel 60 or 73. If it is still showing the same thing, go to TV1 (the one with the receiver) and hit Menu, system setup, Installation, modulation (menu 6-1-5). make sure the modulation for tv2 matches which channel you put your tv2 on.
Still showing the same thing? check the back of the receiver, the RCA cables (red/white/yellow) are plugged into the TV1 ports not the TV2 ports.
Showing different things but the remote still changes channels on both tvs? Go to TV1, hit menu twice, near the bottom there are two boxes each with a number. This is the address for each remote (tv1 and tv2). On the TV2 remote hold sat until it stays lit, choose a number different than on the screen, touch pound (#), the sat light blinks three times, hit record, the number on the screen should change to match the one you typed in.
Still being silly? Call a priest, you have a poltergeist!
Oct 24, 2013 | DISH Network IR Remote Control
Lost my manual, need to reprogram my Logitech hand control for replacement TIVO HDVR
Hi. Programming of the Harmony remote is done in the software, which you can download at http://logitech.com/myharmony.
You'll have to add the TiVo deivce by clicking 'Add Device', then set up an Activity for it. In the 'Activities' tab, click 'Add Activity', and select 'Watch TV (TiVo)'.
Hope that helps.
Mar 24, 2010 | Logitech Harmony 550 Remote Advanced...
I have harmonyH659, I am getting Cable when I push 'watch tv button'. But when I push 'more activities", I amnot getting my dish connection. Used to be OK for last 3 years. what do I do?
Changing the Input settings within an Activity:
1. Login to your Harmony Remote Account.
2. Click on the Settings button next the Activities you are having issues with.
3. Choose Review the settings for this Activity.
4. When the software asks What input does the TV need to be on, change these to the correct settings.
5. Continue through the setup until you are brought back to the Home Screen.
6. Click on the Update remote button and follow the on screen steps.
7. Once the update is completed, please test the Watch TV Activity.
Jan 25, 2010 | Logitech HARMONY 659 Remote Control
My dvr remote 2 has been taken over by my other tv2 remote is there a way activate the former remote? I just had a hdtv dual dvr installed and a new dual reciever. I already had a dual dvr. When I had the...
Unplug one of the receivers. Now go to the second and with the TV1 remote press MENU-MENU and you will see the two remote addresses displayed. On the TV 2 remote that is associated to turn off the TV2 with this receiver press and hold the SAT button on the top left of the remote until all the buttons across the top illuminate. Now key in a two digit number that differs from the one for TV2 displayed on the screen. Now press the pound sign and the SAT button will flash three times. Next press the small record button until the TV2 address changes to the correct two digit number. Now you should be able to turn the other receiver back on and be able to control each TV2 independent of each other. Thanks for using Fix Ya. If you need further assistance let me know.
Sep 17, 2009 | DISH Network IR Remote Control
Abilities of Universal Remotes
Yes!
When you define different activities (such as Watch TV, Watch DVD, etc.) the remote will ask which of the TV inputs your device is plugged into.  After programming, when you select the appropriate activity, the remote will automatically select the correct input.
Jan 02, 2009 | Logitech Harmony 890 LCD Remote Control
Mutli purpose TV control
To add or remove an Activity, click Add an Activity or Remove an Activity.
• To customize an Activity, click Customize next to an Activity icon, and then click the appropriate
option.
• To change the names of Activities click Customize next to the Activity icon, and then click
Rename Activity name.
• To have more than one Activity of a given type (e.g. If you have both a cable converter and a
satellite receiver, you can add a second Watch Television Activity) click Add an Activity. When
you're done, rename the Activities to help you distinguish between them (e.g. For the Watch
Television Activity you could rename one "Watch Television" to "Watch Cable" and the other to
"Watch Satellite
Dec 12, 2008 | Logitech Harmony 880 LCD Remote Control
Logitech Harmony 880 LCD / TV screen ''check signal cable''
This is a configuration problem. My guess is that when you set up the "Watch TV" Activity, the input source was not properly selected. Remember, you should almost never need to control devices separately,(as you would with a typical remote). In fact, the only time you need to specifically control a device would be a situation where you need to access a little-used function that was not programmed as part of an 'activity'. Sometimes, you may need to control a device to tweak an activity that did not start correctly, but apart from these situations, you will almost always be concerned with starting "Activities". This is very different from your typical universal remote! Instead of operating 'devices' like your TV, cable box or DVD, you configure and select "Activities" that automatically control the devices that are used during that activity. So, go back into the Logitech software and make sure that your Watch TV activity is selecting the appropriate input. If everything is setup correctly, and you still are unable to go to the correct input, you may need to adjust some of your delay settings, especially the Power-on Delay. Power on delay is the amount of time it takes for the device to turn on and start accepting IR commands. On most electronics when you first turn them on if you hit other buttons too quickly the device will not respond to them. This delay helps to keep that from happening. Hope this helps!
Dec 10, 2008 | Logitech Harmony 880 LCD Remote Control
Rca universal remote RCR4258/RCR4358
mi televison es marca emerson y el televisor no quiere hacer nada
Jun 09, 2008 | Televison & Video
Logitech Harmony 880 LCD Remote Control Logo
162 people viewed this question
Top Logitech Televison & Video Experts
Brian Sullivan
Brian Sullivan
Terry Hair
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
