Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Red is off focus
I have a 3-D look to my picture as Red is below everything by a 1/4 inch for the most part, but it falls into the corners even more.
  • ramon49
    ramon49 May 11, 2010
    check STK's on heatsink for burned resistors or coils, usually the stk close to the burned part is bad, change all 3 if your set has STK's
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    It is failure of convergence out IC
    If you are conformable with TV repair and have prior experience then replace big black IC (STK) on D board of TV.
    Need further info, let me know exact model number of Sony TV.
  • Sony Master
  • 3,459 Answers
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 13, 2009
Picture is not focused, color is off. When we
this sounds like the convergence ic's need to be replaced that should fix the problem
Jan 25, 2010 | Hitachi 57F500 57" Rear Projection...
Projection tv colours out of focus
First look on back of your TV find Model# and chassis Then POST it again here! In the mean time you have a focus and screen drive control Block On your [Deflection Board the one that has FBT flyback Transfomer it will have 2 wires comin out of it one will fo to control box there will be 3 contros on top R/G/B for focus and 3 controls R/G/B below them for screen drive to each TUBE adjust them.
Nov 19, 2009 | Televison & Video
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Magnavox model 6P5440
You can turn up the Screen controls in back of set. Look for the focus block that has 6 controls on it. 3 are for the screen and 3 for the focus, in each color Red, Blue, Green. need to turn evenly to keep color balanced. On set turn color all the way down and then get a good black and white picture.
Sep 14, 2007 | Hitachi 57UWX20B 57" Rear Projection...
My picture is blurry or out of focus.
ake sure your subject is within the camera's range. You should be at least 20 inches away to take a picture without the flash, and 20 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close-ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. See Chapter 4 for more information about how to change the shutter speed from the LCD menus. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Picture blurry or out of focus.
Make sure your subject is within the camera's range. You should be at least 31 inches away to take a picture without the flash, and 31 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close- ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. For more information, see Chapter 6. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 750Z Digital Camera
What should I do if the picture is blurry or out of focus?
Make sure your subject is within the camera's range. You should be at least 20 inches away to take a picture without the flash, and 20 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode (2.3" zoomed to wide). When you take macro close-ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. On the PhotoPC 3000z you can also use Program (Sports Mode) or Manual (Shutter Priority) to increase the shutter speed. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
DSC-S75 focusing problems...
Without seeing a photo, here are a few possibilities. 1) Shutter speed too low (camera shake). 2) Camera is focusing on something in the foreground. 3) Focus not locked, low light, low contrast scene. Items 2 and 3 can be corrected by manual focus. Set the focus to 1 click below infinity, depth of field will insure everything is in focus. For item 1 remember that the shutter speed must be 1/125 sec or faster at full zoom to avoid camera shake.
Sep 11, 2005 | Sony Cyber-Shot DSC-S75 Digital Camera
S4 No Multiple Focus?
Acceptable focus depends on many things and an appreciation of aperture, lens, distance and shutterspeed is needed before understanding the finer points of 'depth of field' (what will and wont be in focus). Like all cameras, an auto focus camera cannot make everything sharp, it has to focus on one thing, usually in the middle, and the rest of the picture either falls in or out of focus, depending on the combination of the above points. For example, if you shoot on a wide-angle lens with a small aperture, say anything above f8, you should have everything you want in focus. In contrast, on a longer telephoto lens with a wide aperture (more light being allowed to hit the film or chip or whatever) the resulting picture will be sharp within only a few inches of the focus point. This can be really nice if you are shooting single portraits in bright light as the background will become extremely blurry and colourful. I am presuming that the shots you are concerned with had the camera settings set to wide aperture priority, possibly because it was dull or you had a 'sport mode' selected where fast shutterspeed is needed to catch rapid movement thus a wide aperture is needed to compensate and so shallow depth of field results. I don't know the camera you are using or whether you will understand any of the above. If you need a greater explanation of what is essentially a science, please let me know.
Sep 08, 2005 | Pentax Optio S4 Digital Camera
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
101 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
