Question about Maytag PYE2300AY Electric Dryer
Magtag Electric Dryer
Went to check my cloths and they were still wet. Dryer was off and HOT!! now it won't turn on and the light that comes on inside is also out. I check the link trap and outside vents and they are fine. Thanks for any help!! Sonia
  • Maytag Master
  • 3,361 Answers
Replace the thermal fuse and high limit switch located at the heating element.They come as a set.
Correct the blockage in the dryer connecting vent at the rear exhaust port.
Posted on Mar 10, 2009
Dryer inside gets hot but clothes still come out wet
The lint filter may be clogged or the dryer vent is clogged , preventing air circulation. If the vent goes outside, an animal may have put a nest in it.
May 19, 2015 | Kenmore 500 7.0 cu. ft. Electric Dryer -...
Takes to long to dry clothes
after checking and replacing the vent going outside still the air was not venting and inside my drier everything was wet although the air was hot. After removing the rear panel i saw the blower belt disconnected. it took me some time to get the belt on but everything is ok and the air is venting and clothes getting dried. Also note that the little pulley came off its positio too.
Feb 14, 2013 | Whirlpool Dryers
My Magtag dryer model#DG612 (series 05) stopped producing heat to dry the clothes. There was a flame for approx two minutes, and then the fame went out. What can I do to fix this problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 28, 2011 | Dryers
Electric dryer was running fine.had towels in there an opened door to check how wet an noticed it was really hot inside an then closed it an went to pull knob outward to start the dryer again an it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
I have a roper dryer Model RES7646KQ2. While I
Sounds like thermal cut off fuse has blown. That is indicative of airflow obstruction somewhere either internally in the dryer or venting from dryer to outside v
Nov 15, 2017 | Roper REX4634KQ Electric Dryer
My electric dryer gets hot but the cloths are not drying
Please check your dryer venting, all of it, or at least as much as you can. I would start at the discharge outside. May be full of lint, covered by plants. or a bird may have built a nest inside. If air is not flowing through the dryer and to the outside clothes get hot but stay wet. Is the case of the dryer hot? Another indicator your vent needs to be cleared. This should be done before you run the dryer again, or you could cause thermal fuses and other little gizmos to break.
Jun 14, 2009 | LG DLE2532W Electric Dryer
Kenmore 64672 dryer gets hot but clothes still wet
you have a clogged wall vent or clogged dryer vent or a clogged lint trap,you are trapping all the hot wet air in the dryer and that's why it's taking so lont to dry-mike
Apr 22, 2009 | Kenmore 64672 Electric Dryer
Did you check the breaker closely. Dryers work on 220 volts, usually 30 amps and that means TWO 110 breakers attached together must be good and putting out 110 volts each. One may be burnt or disabeled and the other working. Also check at the  dryer receptacle and make sure you have 220 or more volts.
Mar 11, 2009 | 2001 Yamaha V Star 1100 Classic
Burning smell coming from the dryer!
You have a serious clog somewhere in your dryer exhaust ventilation. I would recommend you STOP using the dryer immediately and clean both the interior and all the vent ducting from where it exits the dryer to where it exits the home. the burning is coming from lint build up in and around the heating element and its beginning to smolder. This is a potential fire hazard and may end up causing the heating circuits to fail. The condensation comes from the the inability of the hot air (which is mixed with humidity from your clothing) condensating inside the vent duct. The lint starts to collect and get wet to the point of saturation. Then it begins to cause water to form and leak out of the ducting and on to your floor. You do not want this condensation inside the dryer where the heating circuits are. The following link will provide with some guidance for future reference:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention the paragraph where it discusses proper dryer ventilation. I hope this helps you. Let me know if I can be of further assistance.
Sep 28, 2008 | GE DBSR453EBWW Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
