Nintendo DS Lite Logo
Posted on Apr 14, 2013
Does not load games properly
Some times it works ok and then when i insert a game it loads all the way to select a profile to insert a player and then locks on that screen. if i blown and keep trying to switch on and off it starts to work. it is the same with ALL games
paul_stone36
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 14, 2013
paul_stone36
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
1805
Points
10
Hi Gail, are they original ds games you are trying to load or from a r4 card??
paul
5 Related Answers
Anonymous
  • Posted on May 09, 2008
SOURCE: N5 Help me
listen guys, if u have n5 and u are using a 4gb SDHC you need to upgrade the firmware to 1.18 which is the latest right now. I had the same problem, updated the kernel and it works dam good. Here is the link.
http://www.linfoxdomain.com/nintendo/ds/
click on N5 and download the v1.18
try doing the same method for r4 but use the r4 kernel. Having the latest kernel can save u lots of problems.
The Machine
Dean Joly
  • 788 Answers
  • Posted on Mar 30, 2009
SOURCE: My Wii stopped playing some games.
Check the system menu for any system updates.
Dave Byrne
  • 58 Answers
  • Posted on Jun 20, 2009
SOURCE: r4 "loading" problem
Try re-installing the operating system onto the card. Go to www.r4ds.com download & unzip the kernel. This will create a folder with the operating system.Copy these files to the root of the SD card (There should be 2 files & 2 folders) After this, copy the .nds files also onto the root of the SD card, and the games should be visible & playable when you turn on the DS
NOTE: this will not work for the Nintendo DSi
Anonymous
  • 19 Answers
  • Posted on Apr 20, 2010
SOURCE: system date error! please check NDS system date
It's a bug issue in the firmware of the R4 cards. Won't work after 14 april 2010 unless you update the firmware of the R4 card.
For the time being you can set back the date before 14 april 2010 and it wil work directly.
gr
Anonymous
  • Posted on Jul 27, 2010
SOURCE: my cyclo ds game chip doesn't work and how do i fix it
All Nintendo ITEMS ARE UP TO 40% OFF SO DON'T MISS OUT!!
R4 SDHC Only $4.99, Acekard 2i $14.99
Cyclo DS $42, Acekard 2 $12.99, Micro SD Only $6.99
Super Fast Shipping from US
http://www.gameplayfun.com
How long does it take to start up a game? I have
Load times don't usually exceed more than a couple of minutes. Try restarting your Xbox and try playing the game again.
I just finished a season on nba 2k10 on my player mode but i can no longer load the profile its not the game because i can load another my player profile
j_cooldtown
if you are having trouble loading your game profile this is a sign that you my have some corrupted data on your hard drive.
The link below will help you try to recover your save but you may have to delete the game profile to even formatting the hard drive.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
I cant play any ps3 game
you know this happened to me too..
just call the sony company
My ps3 loads games when i insert the disk about 6 or 8 times
Your laser is going out again. The ONLY way you can fix it is by replacing it again.
Thanks Sony!
DVD player stopped working in my computer
the dvd player is not working and needs to be replaced
2helpful
Wii's quantum of solace errors goeeting online and single player
This is what I had to do:
After it froze up, I turned off the wii by holding the power button for approx. 10 seconds. Then, I powered it back up and started Quantome of Solace. After loading my profile, instead of selecting 'continue', I selected 'chapter select' and it let me start from the chapter it was freezing on. It did not freeze this time during the intro movie. Hope that helps!!!
5helpful
2answers
Crackdown freezes as it says loading profile.
You may very well have a bug in one of your saved files/downloads.
To fix this issue, what you will need to do, is delete your gamertag, basically to refresh your xbox HDD, then go to xbox live and go to RECOVER GAAMERTAG,place the email address you used to originally set it up, and recover it. this HAS happened to me once before, and this has a 99.99% of working, now before you start worring, you will not lose your gamertag altogether,....unless you forgot your email address. Let me know how this goes,
thannks
justin
Please rate me
Valkyrie profile 2 it freeze or stuck up when the battle starts
You will need a non analog PSX controller or a PS2 DVD remote to overcome the problem.
2answers
Micro sd loading problems
r4 with a 2 gb micro sd
1helpful
2answers
Logitech attack 3 joystick-does it work with my IL-2 Sturmovik game?
First, check your game documentation to see if your game supports the use of a joystick. Most First Person Shoot 'em Ups do not support joysticks, and only supports mice/gamepads.
If joysticks are supported in your game, please read on...
Make sure that your joystick is properly installed and detected by your computer. You can check in Device Manager or Control Panel > Game Controllers. Also make sure you have the latest software (LGS/WingMan) installed.
Next, you will have to create a new profile for your game in the WingMan Profiler:
  1. Open the Logitech Profiler™ by clicking "Start", "Programs", "Logitech", and then "Launch Logitech Gaming Software".
  2. Click "Profile" from the pull down menus.
  3. Select "New..."
  4. Type in the name of the game the profile is being created for.
  5. In the next field, type the path to the game's executable file. It the exact path is not known, use the "Browse" button.
  6. Select an icon for this game profile and click "OK"
A profile for the game has now been created; however, game commands must also be entered. For information on how to do this, please see Knowledege Base article 274.
Hope that helps.
Please dont forget a FixYa rating if this solution was helpful. Thanks in advance.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
