Question about Maytag MAH6700AWW Neptune Front-Load Washer
Washer skips softner - Maytag MAH6700AWW Neptune Front-Load Washer
  • 2 more comments
  • Anonymous Apr 22, 2009
    The cycle skips / never uses or doesn't empyty the softner
  • Anonymous Apr 23, 2009
    The washer washes clothes fine, but always leaves fabric softener behind after the wash and spin cycle.
  • Anonymous May 06, 2009
    I have the same problem no solution...
  • Anonymous May 14, 2009
    My washer skips both the bleach and softner dispensing.
  • 58 Answers
The dispenser valve needs to be replaced
Posted on May 18, 2009
I am having 2 issues. Most importantly, my front load washer/dryer is skipping drying time. I typically wash the clothes then put dryer sheets in and use the dry only on low heat option. It starts...
Your two issues may be related. A combo washer / dryer uses a fine spray of cool water to condense moisture out of the air stream while drying. This water is then pumped down the drain. Cold water is also used to fill the softner dispenser. If the inlet screen on the cold water connection to the machine is restricted, those are two of several things which could show up. Turn cold water valve supplying water to machine off. Unscrew cold water fill hose from machine. Remove screen from inside machine, clean, re-install, re-attach cold water fill hose, turn cold water valve back on and see if performace improved.
Mar 02, 2011 | LG WM3431 Front Load Washer / Dryer
The frabic softner dispensor is not releasing the softner in the washer.
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Sep 05, 2010 | GE WSXH208A Front Load Washer
Will not take softner?
clean the dispenser drawer, then using thin pipe cleaner clean the two outlets that fall over the softner drawer, its easier if water is flowing from them, to do this switch on the servvice cycle (no clothes in the machine) as u swtich it on, hold the start pause and skip button down and then press the fabric button repeatedly until the water comes through the outlets over the softener compartment.
to exit service cycle u must swtich the machine on and off twice
Dec 28, 2009 | Zanussi FJS1225W Front Load Washer
"fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
Last 2 loads didn't use fabric sofner
Top load washer? check the agitator. alot of times the softner will gum up the inside of agitator and make dispensing hard
Jan 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 44082 washer won't take in fabric softener
Remove hoses from fill valve, clean screens inside fill valve, if this does not fix problem, replace valve.
Jan 17, 2009 | Kenmore 44102 Front Load Washer
Adding Softner
try taking the dispenser off and cleaning it might have a build up of old softner
Oct 15, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Frabic Softner Dispenser
the water valve for the softner is not opening. depending on the model, you can put unit in a service mode. this will let you cycle through the valves.
May 22, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
The top half of the agitator (near the fabric softner comp) is skipping while it is in wash cycle
yes the top half seperates from the bottom half inside the top half are 4 little parts called dogs. the part number is 241341. replace the dogs to fix it
Nov 27, 2007 | Kenmore 22932 Top Load Washer
Fabric softner leakage
By opening upper machine's cover you will have an access to the detergent/softner drawer. Look for the place the water leaks from. Good luck !!
Sep 03, 2006 | Maytag PAV2300 Top Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
51 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
