Question about Dell (2336V) Motherboard
Dell Demension 4600 motherboard memory
I have a Dell Dimension 4600 I bought in 2004 . The only thing I know about this board is dells product code K3363.
Can I install 1GB sticks of ram in this board, if not what is the largest I can install and what type
  • 948 Answers
From the Dell specifications page for Dimension 4600:
Dual Channel DDR SDRAM
Memory connectors
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
Posted on Mar 09, 2009
No beeps but lights A B are orange
....and lights C, D are green, and your computer fails to boot up ? (you do not say) (on Dell PCs, which I don't have, the LEDs are usually described as yellow and green. There are four of them on rear of the PC ?).
First go to this webpage:
Product Support
if you are able run the Dell Diagnostics, or if not the ePSA.
Also read this manual - the only one available specifically for Dimension 4100 - especially the section on safety. If you have to open the case remember to properly earth yourself.
To the answer to your question, if the 4600 model has the same codes as the 4100 see the service manual for the Dimension 4600 (or get the corresponding manual for the 4100 by contacting Dell support) look here
in the Advanced troubleshooting section. It tells you the problem may be with your memory module(s) and it suggests what to try. I favour checking to see if you get correct errors with no memory inserted then with each module in each slot until all 4 combinations have been exhausted. This likely to tell you what is wrong. You may have to replace a memory module, or work with only one module or replace the motherboard.
Apr 18, 2014 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Dell demension 4600 wont turn on
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Aug 07, 2012 | Dell Dimension 4600 PC Desktop
I need a Driver for my Dell Demension 4600 to enable my ethernet controller.
it should be available on the dell website, you may have to look it up by model and serial number and know what operating system you use.
see if this is the right driver-
<a href="">clicky</a>
Nov 06, 2010 | Dell Dimension 4600 PC Desktop
Front Panel help for Dell Dimension 4600
Go to dell site and query for *********** board specs. Then query for the pinouts on the board. Or goodle dell optplex+motherboard+hardwire connections. good luck
Jun 17, 2009 | Dell OptiPlex 170L PC Desktop
Upgrading memory
hi If you go to they will scan your pc & tell you what rams youhave & what you need. then buy from wherever. hope this helps blue51
Apr 14, 2009 | Dell Dimension 4600 PC Desktop
Seeking a diagram of what all the inputs on the rear of the 4600 are...duh
This Link below will take you to an online service manual for the Dell Dimension 4600. Click Here
Mar 14, 2009 | Dell Dimension 4600 PC Desktop
Ethernet Controller
E210882 is a number found on more than one Dell System Board. Dimension 8400 and 4600 come to mind. Possibly there are more. Secondly, E210882 is not a Dell Part number (DP/N or DS/N). While Dimension 8400 is a 775 socket, Dimension 4600 is a 478 socket. So they don't fall to the same family.
In any case the network controllers used on Dell System Boards are Intel and Broadcom.
To proceed, at least provide/confirm the system model. If this is not available, give the Dell Part Number.
Jul 10, 2008 | Dell (E210882) Motherboard
Here is a link for all the drivers you'll need.
Click HERE
Jun 06, 2008 | Dell Dimension 4600 PC Desktop
Dell (2336V) Motherboard Logo
342 people viewed this question
Alun Cox
