Question about Canon PIXMA MP510 All-In-One InkJet Printer
Installed #8 M(magenta ink cartridge) New ink tank.
Display panel indicates ink tank cannot be recognized.  Old ink tank displays ink has run out.
  • Canon Master
  • 419 Answers
The problem can be one of the following:
  1. You have a faulty cartridge chip (return to purchaser and request a replacement)
  2. The chip is soiled (ink or similar is causing the connection to fail) so try cleaning the chip
  3. The chip is not properly mounted on the cartridge (maybe skewed slightly or similar). If so try straightening out carefully and then re-inserting.
Canon have been known to send out cartridges with bad chips so you should contact them if you bought a proper one and they'll sort you out.
Posted on Mar 09, 2009
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
I have a canon IP 4200 printer. The ink cartridge light on the Magenta ink cartridge doesn't work so it won't accept/recognize that a new ink cartridge has been installed. Is this something that...
It sounds as though you have a break in the carriage ribbon cable. A new carriage would hopefully cure it but its just possible the logic board has failed and is not sending any signal to the magenta ink tank. Its certainly repairable but you would need to know the costs and the labour charge to see if its worthwhile.
Aug 27, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
A canon ink tank is not being recognizd. Previously it was working fine. Then I added a new black cartridge. Now the magenta won't work. All Canon cartridges. Trina
All ink tanks has a memory chip.With this chip the printer recognize the ink tanks and the ink level.Sometimes this chip failed.Just replace the magenta ink tank.
Nov 24, 2009 | Canon Pixma MP950 All-In-One InkJet...
New black cartridge. won't print.
your housing may be not clean try to cllean it and clean the back of the tank carfully and erinstall the tank and reset the printe4r. if not try to use the old one again and see if you get the same error
Nov 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
Printer won't recognize the new ink cartridge
Each cartridge has a electronic chip pre-porogrammed at the factory.
If it is a reputable store they will exchange for the right color as they can return the PM to Canon as defective,
Mar 27, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Color print quality
You can clean the head from the printer software or take it out and run some warm water over the ink ports/ink jets.
Are the ink tanks securely clicked in place? they can come loose easily
Jun 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
New Magenta Ink is not recognized after installed
Hi, it sounds that the issue can be caused by a defective ink cartridge that installed or a printhead that can recognize magenta ink cartridge. To identify which causes this issue please try the following:
1. Reseat ink cartridge
2. Replace ink cartridge with a specified ink cartridge for your printer.
3. If above steps wont resolved that issue, please call your printer manufacture and ask for service referral or process warranty options.
Tirzo
Oct 21, 2007 | Epson Stylus CX6000 All-In-One InkJet...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
129 people viewed this question
old marine
old marine
